kansashogan Posted January 2, 2015 Share Posted January 2, 2015 Looks good! I love the way it sits. Link to comment Share on other sites More sharing options...
BlackBeast Posted January 2, 2015 Share Posted January 2, 2015 Nice job..how did u do the headliner and what did you use as far as adehesive? I plan on a expedition rack eventually myself. Link to comment Share on other sites More sharing options...
Assman603 Posted January 2, 2015 Author Share Posted January 2, 2015 The headliner is just a roll of mossy oak material. It can be found in the automotive section at walmart. And the adhesive I used was some loctite brand spray adhesive. I used this same spray glue to replace the vinyl door panels in my Datsun pickup. I just cut slits in the corners to allow the material to overlap. It came out pretty nice and hasn't shown any signs of peeling. As far as the rack goes, I plan on putting a roof mouned tent over the back portion, and making canvas sides to enlose the back during inclimate weather. I've also thought about building a rear swing gate to mount a jerry can and a spare tire on. Also, does anybody have recomendations for a winch? Looking to get the best bang for my buck as I am on a budget. Should I also add a second battery? I've read that a second battery, like a deep cycle marine battery, to run the winch is a good idea. Also, what's the best high output alternator for the renix era comanches? Any assistance is greatly appreciated! Link to comment Share on other sites More sharing options...
MuddFoot Posted January 2, 2015 Share Posted January 2, 2015 100amp i got mine for 47 bucks i just googled this http://www.partsgeek.com/gbproducts/MC/2222-07136303.html?utm_content=MC&utm_term=1987-1990+Jeep+Cherokee+Alternator+Pure+Energy+7902611+87-90+Jeep+Alternator+1988+1989&fp=pp&gbm=a&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=CJL9tZDo9cICFURo7AodXUIA3Q then google a coupon code some times rock auto has them cheap too. when i had my orange xj i used a smitybuilt xrc i think it was a 10k from Amazon.com paid 360 with free shipping it was a verygood winch. i also got my battery from amazon.com 34-78 dual post yellowtop optima for 140 shipped. i used the side post for the start and charging and main ground then used the top for the winch and other accessories and a secondary ground. Link to comment Share on other sites More sharing options...
Assman603 Posted January 2, 2015 Author Share Posted January 2, 2015 I'm currently running a red top Optima, but I was thinking about adding a second battery and the dual battery isolation kit. So I can use the red top battery to run the truck itself, and whichever second battery I plan on using to run the winch, lights, and other high draw accessories. My friend recommended a deep cycle marine battery, like what they use on RV's, because that's what he used to run his trailer winch, and he said it worked great. Link to comment Share on other sites More sharing options...
MuddFoot Posted January 2, 2015 Share Posted January 2, 2015 yellow top is considered a deep cycle battery but you could use there blue top rv/ marine Link to comment Share on other sites More sharing options...
Assman603 Posted January 3, 2015 Author Share Posted January 3, 2015 That's what I was thinking. The r/v / marine battery just has more storage capacity. Which is what I'm looking for. Link to comment Share on other sites More sharing options...
Assman603 Posted September 9, 2015 Author Share Posted September 9, 2015 It's been a little while since I've posted up pics of the old MJ. She has gone through some slight changes over the summer, and there are many more to come... New snorkel, LED bar. flex testing weight reduction... and rust repair... Link to comment Share on other sites More sharing options...
Assman603 Posted September 9, 2015 Author Share Posted September 9, 2015 anybody have any recommendations on fuel cell/pump combos that work successfully with the 4.0? Link to comment Share on other sites More sharing options...
89eliminator Posted September 10, 2015 Share Posted September 10, 2015 I'm running an RCI cell with built in 0-90 ohm sending unit and an external generic fuel pump. its just spliced into the existing harness, very easy to do. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 10, 2015 Share Posted September 10, 2015 I'm running an RCI cell with built in 0-90 ohm sending unit and an external generic fuel pump. its just spliced into the existing harness, very easy to do. Care to elaborate Wade? Or is there a writeup elsewhere? Link to comment Share on other sites More sharing options...
89eliminator Posted September 10, 2015 Share Posted September 10, 2015 I'm running an RCI cell with built in 0-90 ohm sending unit and an external generic fuel pump. its just spliced into the existing harness, very easy to do. Care to elaborate Wade? Or is there a writeup elsewhere? elaborate on which part? i didnt really take many pics except for the actual cell mounted in the bed, but can take any pics/explain whatever you want. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 10, 2015 Share Posted September 10, 2015 Just the model external pump you are using. I can lookup it's specs on line. Thanks. Link to comment Share on other sites More sharing options...
89eliminator Posted September 10, 2015 Share Posted September 10, 2015 Just the model external pump you are using. I can lookup it's specs on line. Thanks. http://www.summitracing.com/parts/atx-e2000 Link to comment Share on other sites More sharing options...
Assman603 Posted October 28, 2015 Author Share Posted October 28, 2015 I ended up replacing my stock tank with another stock tank... temporarily. I needed to maintain daily drive-ability as my Subaru just blew a turbo. Hopefully it won't have to touch the salt... but it's got 4WD, so how can I not drive it in the snow? How do you guys feel about cutting the bed sides? I really like how they came out, and it should make it quite a bit easier to clean off the top of the frame to keep it free of sand/salt/rust etc. Stay tuned, big plans for the Comanche over this winter. Link to comment Share on other sites More sharing options...
zetabird Posted October 28, 2015 Share Posted October 28, 2015 I'm actualy thinking of that kinda rack myself, once i get the truck reliable ill need to track down some tubing to play with Link to comment Share on other sites More sharing options...
MancheKid86 Posted October 29, 2015 Share Posted October 29, 2015 diggin the build, it has defiantly grown a bit! you should slap in an onboard air system via stock a/c compressor! and toss some tanks in, then you can air down when ever, and trust me it comes in handy, air tools in the bush is nice rockin a mj and subaru as well hey? i want to do a turbo swap on mine to snag a bit more power out of it, but no where to do a dyno retune after Link to comment Share on other sites More sharing options...
thesman727 Posted October 29, 2015 Share Posted October 29, 2015 diggin the build, it has defiantly grown a bit! you should slap in an onboard air system via stock a/c compressor! and toss some tanks in, then you can air down when ever, and trust me it comes in handy, air tools in the bush is nice rockin a mj and subaru as well hey? i want to do a turbo swap on mine to snag a bit more power out of it, but no where to do a dyno retune after I believe the word you're looking for is definitely Link to comment Share on other sites More sharing options...
MancheKid86 Posted October 30, 2015 Share Posted October 30, 2015 diggin the build, it has defiantly grown a bit! you should slap in an onboard air system via stock a/c compressor! and toss some tanks in, then you can air down when ever, and trust me it comes in handy, air tools in the bush is nice rockin a mj and subaru as well hey? i want to do a turbo swap on mine to snag a bit more power out of it, but no where to do a dyno retune after I believe the word you're looking for is definitely lol i blame auto correct and being up too late! haha you were able to figure out what i meant Link to comment Share on other sites More sharing options...
Assman603 Posted December 27, 2015 Author Share Posted December 27, 2015 I blew the turbo on the Subaru... so I actually am in the process of swapping that, and now I'm stuck running the Manche in the salt, hooray... Anybody who's interested feel free to follow me on Instagram, @Granite_State_Ordnance for more frequent updates on my projects. I will do a more detailed update on the Comanche when I have some free time. Link to comment Share on other sites More sharing options...
Assman603 Posted January 10, 2016 Author Share Posted January 10, 2016 diggin the build, it has defiantly grown a bit! you should slap in an onboard air system via stock a/c compressor! and toss some tanks in, then you can air down when ever, and trust me it comes in handy, air tools in the bush is nice rockin a mj and subaru as well hey? i want to do a turbo swap on mine to snag a bit more power out of it, but no where to do a dyno retune after I actually don't have factory A/C in this truck. lol. But i will be swapping in the A/C compressor out of my parts Cherokee to do on board air at some point. I'm going to be re-designing the rack and adding an actual cage, as well as some more suspension modifications. Considering a 4 link in rear. As well as rock sliders, new floor pans, and a lot of lights. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted January 11, 2016 Share Posted January 11, 2016 I haven't logged in since just after thanksgiving. So I figured I would give a quick update as to the progress being made with my build. I picked up a new steering box spacer and a DIY winch bumper kit from JCR off-road, as well as a set of Rugged Ridge TJ bushwhacker style flares, and so far I'm very pleased with the outcome. All ready for a face lift. New vs. old steering box spacer. The JCR spacer is much heavier duty. Uni-body tie in bracket. I actually mounted it upside down in this picture, but corrected myself before welding the bumper together. Installing the steering box spacer: Finished product: I still need to do the finish welding on the bumper, as well as paint it, and install the rear flares, and the new shoes and pads that I ordered. The Comanche is still progressing and I hope to be posting up more frequently as the weather gets warmer and I have more time to work on it. Does that rack add much noise when driving down the free way? When I had a light bar it was terrible. Link to comment Share on other sites More sharing options...
Assman603 Posted January 11, 2016 Author Share Posted January 11, 2016 I don't get any noise at all from the rack, but it does squat pretty hard under any load. I do however get a hellish whistle from the allen screws on the LED lightbar brackets. Link to comment Share on other sites More sharing options...
Assman603 Posted January 10, 2017 Author Share Posted January 10, 2017 Just a brief update on some of the progress of the Comanche over the past year or so.Decided to lose the roof rack, too much weight, not enough benefits. Updated to the new (er) style mirrors off a '97. Started a set of half doors. Added a push bar to the bumper, as well as some Hella's. A few interior mods. AX15 swap parts. Not to mention the Wagoneer nose. A few other odds and ends as well. I will be updating for a more consolidated and comprehensive build thread in the next few months or so as I continue to make progress. In the meantime, enjoy some jeep porn. Link to comment Share on other sites More sharing options...
Wiggilez Posted January 11, 2017 Share Posted January 11, 2017 Will your bag storage be a part of the comprehensive update cause that looks cool. Link to comment Share on other sites More sharing options...
