88whitemanche Posted March 15, 2014 Share Posted March 15, 2014 What's up guys I've been running across a lot of 4cyl 5speeds with 8.25s but I want to know what years would fit my comanche...I've seen 4 pre97 Cherokees and 2 97+ Cherokees with them.... What years best fits my comanche 4cyl 5speed 2.5 with 4.10 gears.... Link to comment Share on other sites More sharing options...
Incommando Posted March 15, 2014 Share Posted March 15, 2014 They are all the same width but none will bolt in. The spring pads and shock mounts are different. For one thing XJ's are SOA & MJ's are SUA. You can easily adapt one if you can weld. Look for a'97-newer to get the stronger 29 spline version Link to comment Share on other sites More sharing options...
Rockfrog Posted March 15, 2014 Share Posted March 15, 2014 Going from 27 to 29 spline is as easy as swapping spider gears and shafts ... so don't limit yourself. The switch to 29 spline occured in 96 so they'll be a mixer year. In any event a 8.25 is loads better than a D35. I also like that they used equal length shafts so only one spare for both sides. Link to comment Share on other sites More sharing options...
88whitemanche Posted March 15, 2014 Author Share Posted March 15, 2014 Ok I know about the spring pads... But the difference from 27spline to 29spline is just the axle shafts and spider gears? Nothing to do with the transfer case or anything correct? Link to comment Share on other sites More sharing options...
Rockfrog Posted March 15, 2014 Share Posted March 15, 2014 Correct ... but when you go from a D35 to an 8.25 you will need to shorten your rear driveshaft some. Link to comment Share on other sites More sharing options...
88whitemanche Posted March 16, 2014 Author Share Posted March 16, 2014 Oh that sucks.... How much would you think I would have to shorten it? And also even with a 3" lift would i need to change driveshaft? Link to comment Share on other sites More sharing options...
Incommando Posted March 16, 2014 Share Posted March 16, 2014 The side gears in a 29 spline carrier are physically larger than the 27 spline version. The axle shafts are larger. I think that you will find that the carriers need to be swapped as well. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 16, 2014 Share Posted March 16, 2014 On 3/15/2014 at 3:10 PM, 88whitemanche said: What's up guys I've been running across a lot of 4cyl 5speeds with 8.25s but I want to know what years would fit my comanche...I've seen 4 pre97 Cherokees and 2 97+ Cherokees with them.... What years best fits my comanche 4cyl 5speed 2.5 with 4.10 gears.... Well, how about you send one of them up here to E TN? Nothin' round here. Link to comment Share on other sites More sharing options...
88whitemanche Posted March 16, 2014 Author Share Posted March 16, 2014 This is actually the first time I've seen so many... And they are all 2wd Though..I would love some of these gears for my cherokee with 3.55 but it'll take longer to find front gears than rear Link to comment Share on other sites More sharing options...
carnuck Posted March 16, 2014 Share Posted March 16, 2014 Make it SOA and you probably won't need to shorten the drive shaft. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 17, 2014 Share Posted March 17, 2014 On 3/16/2014 at 8:40 PM, carnuck said: Make it SOA and you probably won't need to shorten the drive shaft. That's a simple solution to a complex problem. Or do I have that backwards? Who knows? Ever since the "event" things just ain't the same. Link to comment Share on other sites More sharing options...
carnuck Posted March 17, 2014 Share Posted March 17, 2014 Since he's welding on spring pads anyways, how much extra work is it? (I know. I know. He has to lift the front to match) Link to comment Share on other sites More sharing options...
Incommando Posted March 17, 2014 Share Posted March 17, 2014 On 3/17/2014 at 5:06 AM, carnuck said: Since he's welding on spring pads anyways, how much extra work is it? (I know. I know. He has to lift the front to match) You can buy a 4.5" kit for less then a good SOA if you do it right and it is complete. Granted some of the 4.5" kits aren't ver complete either. Link to comment Share on other sites More sharing options...
mvusse Posted March 18, 2014 Share Posted March 18, 2014 The nose of an 8.25" is an inch longer than a D35. If your yoke has at least 1" of rust that has never been inside the transfer case your rear driveshaft will work. The 29 spline ones are stronger than the 27 spline ones. The changeover was some time during the 1996 model year. Link to comment Share on other sites More sharing options...
carnuck Posted March 19, 2014 Share Posted March 19, 2014 On 3/17/2014 at 12:11 PM, Incommando said: On 3/17/2014 at 5:06 AM, carnuck said: Since he's welding on spring pads anyways, how much extra work is it? (I know. I know. He has to lift the front to match) You can buy a 4.5" kit for less then a good SOA if you do it right and it is complete. Granted some of the 4.5" kits aren't ver complete either. I just offered another option that "shouldn't" cost more. I did that myself putting an XJ axle in mine. I even run OEM shocks but the mounts I made weren't as elegant as I have found since. I also replaced my springs at the same time with Metric Tonne ones and converted to 4x4 so I could clear 33/9.50/15 tires. I even run stock ebrake cables. I just moved the floor brackets slightly. You have to add shock mounts when you do an 8.25 swap as well. I have swaybar plates from an early Jtruck (you can probably use CJ aftermarket ones. Test fit them to the shock lower bushing) which are flat plate with a mount stud. You will need a longer spring centering bolt to pass through the plate and into the axle's centering hole. I'm not one to re-use spring U-bolts, but the 8.25 is a wider tube and the spring plate off the D35 won't fit either. Link to comment Share on other sites More sharing options...
88whitemanche Posted April 11, 2014 Author Share Posted April 11, 2014 Ok to bring this thread back to life... I wanted to ask if I were to buy a 27spline 8.25 with 4.10 gears and if I grab some axle shafts from a 29spline (I do plan on buying a locker) is there any differences? Sorry if I sound newbie I'm just trying to set myself up the right way...thanks in advance Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 11, 2014 Share Posted April 11, 2014 On 4/11/2014 at 1:40 PM, 88whitemanche said: Ok to bring this thread back to life... I wanted to ask if I were to buy a 27spline 8.25 with 4.10 gears and if I grab some axle shafts from a 29spline (I do plan on buying a locker) is there any differences? Sorry if I sound newbie I'm just trying to set myself up the right way...thanks in advance http://tampa.craigslist.org/pnl/cto/4385838189.html This is the donor you want to look for. Link to comment Share on other sites More sharing options...
mnkyboy Posted April 11, 2014 Share Posted April 11, 2014 On 4/11/2014 at 1:40 PM, 88whitemanche said: Ok to bring this thread back to life... I wanted to ask if I were to buy a 27spline 8.25 with 4.10 gears and if I grab some axle shafts from a 29spline (I do plan on buying a locker) is there any differences? Sorry if I sound newbie I'm just trying to set myself up the right way...thanks in advance Depends on the locker, if you get a full case 29 spline locker you should only need the shafts. If you go with a lunch box locker you will need a carrier for a 29 spline axle. Link to comment Share on other sites More sharing options...
88whitemanche Posted April 11, 2014 Author Share Posted April 11, 2014 On 4/11/2014 at 2:00 PM, Jeep Driver said: On 4/11/2014 at 1:40 PM, 88whitemanche said: Ok to bring this thread back to life... I wanted to ask if I were to buy a 27spline 8.25 with 4.10 gears and if I grab some axle shafts from a 29spline (I do plan on buying a locker) is there any differences? Sorry if I sound newbie I'm just trying to set myself up the right way...thanks in advance http://tampa.craigslist.org/pnl/cto/4385838189.html This is the donor you want to look for. Yeah but I don't have a full size truck or trailer to bring it down to miami... Edit: oops sorry I didn't read what you wrote...yes I saw a few that I know had the 27spline when I went back to the jy I saw 2 29spline ones but one was already taken and I know the other one by now should be gone to.... Link to comment Share on other sites More sharing options...
88whitemanche Posted April 11, 2014 Author Share Posted April 11, 2014 On 4/11/2014 at 2:16 PM, mnkyboy said: On 4/11/2014 at 1:40 PM, 88whitemanche said: Ok to bring this thread back to life... I wanted to ask if I were to buy a 27spline 8.25 with 4.10 gears and if I grab some axle shafts from a 29spline (I do plan on buying a locker) is there any differences? Sorry if I sound newbie I'm just trying to set myself up the right way...thanks in advance Depends on the locker, if you get a full case 29 spline locker you should only need the shafts. If you go with a lunch box locker you will need a carrier for a 29 spline axle. Ok yeah I was planning to buy the lunchbox from lokka...so I'll have to be on a look out for a full case 29spline 8.25 Link to comment Share on other sites More sharing options...
Timeless Posted April 11, 2014 Share Posted April 11, 2014 And if you switch carriers for a lunchbox, you'll have to re-setup the gears. Same as with a full case locker. Link to comment Share on other sites More sharing options...
Incommando Posted April 11, 2014 Share Posted April 11, 2014 Research Lokkas even on this forum. The extra $45 for an actual Aussie might be worth it Link to comment Share on other sites More sharing options...
