mvusse Posted March 7, 2014 Share Posted March 7, 2014 My apologies if this has been covered before. So the last couple of years the my valve cover breather has been deteriorating fast, and the rubber elbow completely fell apart last week. Went looking about the store at my new job (Autozone) and came up with the following solution: -Help #42059 AMC PCV valve grommet (although the package says Chrysler). This fits perfectly in the Renix 25mm valve cover breather hole. $2.99 -Help #47046 Ford PCV elbox. This fits inside the grommer and takes a standard 19/32 PCV hose on the other end. $3.99 -Goodyear #50282 19/32 PCV hose. This is sold by the foot, you will need about 2 feet. 2 x $2.09 = $4.18 Grand total of $11.16 plus tax. The grommet goes into the valve cover, the elbow goes into the grommet, and the hose goes from the elbow to the port on the air cleaner. Notes: Although the grommet and elbow are Help parts, they were not in the Help section. Instead they were with the PCV valves (which in my store is between the oil filters and the fuel filters). The hose is in the back of the store and has to be cut by an employee. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted March 7, 2014 Share Posted March 7, 2014 Pictures? :brows: Link to comment Share on other sites More sharing options...
Blue88Comanche Posted March 7, 2014 Share Posted March 7, 2014 Pictures? :brows: :needpics: Link to comment Share on other sites More sharing options...
mvusse Posted March 8, 2014 Author Share Posted March 8, 2014 I'll try to get some tomorrow. Link to comment Share on other sites More sharing options...
mvusse Posted March 10, 2014 Author Share Posted March 10, 2014 Link to comment Share on other sites More sharing options...
88whitemanche Posted March 10, 2014 Share Posted March 10, 2014 Does this also work for the 4cyls? I think mine need replacing...getting a little oil residue in the air box Link to comment Share on other sites More sharing options...
danbyrambler Posted March 11, 2014 Share Posted March 11, 2014 -Help #42059 AMC PCV valve grommet (although the package says Chrysler). This fits perfectly in the Renix 25mm valve cover breather hole. $2.99 -Help #47046 Ford PCV elbox. This fits inside the grommer and takes a standard 19/32 PCV hose on the other end. $3.99 -Goodyear #50282 19/32 PCV hose. This is sold by the foot, you will need about 2 feet. 2 x $2.09 = $4.18 Grand total of $11.16 plus tax. The part numbers are good to know - - - Hope you get an employee discount - - Advance has been hard to beat inna last few months - - Order online - pick up in store - - TRT30 code for 30% off - - The 40% off code has expired - - - - - - http://shop.advanceautoparts.com/web/OrderItemDisplay?orderId=26925059&langId=-1&calculationUsageId=-1&calculationUsageId=-7&updatePrices=1&userIdentifier=&catalogId=10051&errorViewName=OrderItemDisplayView&promoCode=TRT30&storeId=10151&taskType=A :thumbsup: Link to comment Share on other sites More sharing options...
BryceOJ Posted May 26, 2014 Share Posted May 26, 2014 Does this also work for the 4cyls? I think mine need replacing...getting a little oil residue in the air box Yeah I am wondering the same question Link to comment Share on other sites More sharing options...
llhat Posted December 7, 2024 Share Posted December 7, 2024 On 3/7/2014 at 7:26 AM, mvusse said: My apologies if this has been covered before. So the last couple of years the my valve cover breather has been deteriorating fast, and the rubber elbow completely fell apart last week. Went looking about the store at my new job (Autozone) and came up with the following solution: -Help #42059 AMC PCV valve grommet (although the package says Chrysler). This fits perfectly in the Renix 25mm valve cover breather hole. $2.99 -Help #47046 Ford PCV elbox. This fits inside the grommer and takes a standard 19/32 PCV hose on the other end. $3.99 -Goodyear #50282 19/32 PCV hose. This is sold by the foot, you will need about 2 feet. 2 x $2.09 = $4.18 Grand total of $11.16 plus tax. The grommet goes into the valve cover, the elbow goes into the grommet, and the hose goes from the elbow to the port on the air cleaner. Notes: Although the grommet and elbow are Help parts, they were not in the Help section. Instead they were with the PCV valves (which in my store is between the oil filters and the fuel filters). The hose is in the back of the store and has to be cut by an employee. hate dragging this up from the dead, but... as the images are no longer available, is this the front (nearest radiator) port on the valve cover? and feeding to the air box? seems like a potential solution for the non-fitting J hose on the dorman harnesses.... Link to comment Share on other sites More sharing options...
89 MJ Posted December 7, 2024 Share Posted December 7, 2024 8 minutes ago, llhat said: hate dragging this up from the dead, but... as the images are no longer available, is this the front (nearest radiator) port on the valve cover? and feeding to the air box? seems like a potential solution for the non-fitting J hose on the dorman harnesses.... Might want to post this over in tech where more eyes will see it with a link to this thread Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted July 15, 2025 Share Posted July 15, 2025 If this is still holding up, please drop in pictures! If not, has a new solution taken it's place? Link to comment Share on other sites More sharing options...
llhat Posted July 22, 2025 Share Posted July 22, 2025 try this not sure if correct pics are there.. Link to comment Share on other sites More sharing options...
llhat Posted July 22, 2025 Share Posted July 22, 2025 this may cover 'something'... Link to comment Share on other sites More sharing options...
