No Dash Lights On My 88
my 88 Comanche has no dash lights on anything, they did work at one point but for some reason now they don't, the fuse checked out visually but I replaced it anyway, could it be a hidden ground strap or something??? :dunno:  :hmm:
Same problem with my 86...checked fuses, bulbs, replaced my dimmer switch, still nothing. I'm told theres a ground wire, near the ebrake(?) or brake pedal...I'm not sure though, havent been able to find out anything more on it...Check the ground first, unless you have tiny hands and an extra joint in your forearm, the dimmer switch is a royal pita to replace
I think its by the brake, If I remeber corretly.
Saw a wire on the brake...but I'm 98% sure thats for brake lights...i'll have to look again tomorrow
Improving the Instrument Panel Ground
The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it.
This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things.
The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple.
Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal.
Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other.
Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely.
**Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.**
Revised 11-29-2011
Not to thread jack, but do the HVAC controls even have lights on an 89 MJ?  My dash is fine but there is just darkness from the middle.  Is that the way they were built or do I have another thing to add to my list of needed repairs?
x2
Tried the ground today...still no lights. Tested lights, new switch, still nothing.
Sounds like you just need to replace a bulb.
  • 4 months later...
Would love to find a solution to this problem as well. On my '92, all dash lights, minus turn indictors, fuel and upshift light, went out after I pulled my carpet. I assumed that I had knocked something loose, but have checked multiple times and I can't find anything wrong.
