MtnClimber
    Wayne, Maine
  • Interests
    Overlanding
883 profile views
MtnClimber's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. There's one in Minot, Maine. Fella wants it gone pretty bad too.
  2. bono is in the process of buying mine. It's all packaged up, just waiting on fundage from him to come thru.
  3. Hey Minuit, I have some right here in the Northeast. 5 of them, 4 with great tires!
  4. I have one in great shape that's already removed. Text headed your way!
  5. I couldn't give my 88 Wagoneer away. Well, for $300 anyways. Ended up going to the scrap yard. Had the quad headlights secured in pretty damn good condition grille/header assembly. 4.0, auto, 4x4 w/a hitch and good leafs and even the A/C worked.... The only thing I kept was the wood grain dash (and lower filler piece)...and even that's for sale..
  6. I have this. Nothing wrong with it, just high miles.
  7. I have a pair of buckets in an 87 Wagoneer if your interested. Not grey tho :doh: Or get these: http://nh.craigslist.org/pts/4167744056.html Or these: http://nh.craigslist.org/pts/4167694697.html Unless their yours....... Nevermind....just read the "for sale" section.......
  8. .o2c; If you do need to get a new cable, I purchased mine thru AutoZone. (I have a 88, 4.0, AX15, 4wd) I believe RockAuto has a select few as well.
  9. Redwolf, I had my antenna mounted to the driver side of the bed due to the frequent use of the sliding glass window. You basically want to use the roof of the truck has a plain. Think of a satellite dish. The 4' allowed the tip a higher reach above the roofline and it helped transmit/receive better. I also tune mine w/a SWR meter. Agree w/the 18' min of coax with no loops and away from the engine (or atleast the ignition) if you can help it. I also use the 4' Firestick on my XJ, for the height. But I've also use the 102" for when we go way up North and I know my group may get more spread out due to dusty conditions.
  10. Here's my Uniden Pro520XL mounted to the shifter console. It does not interfere with the passenger or any shifting. The CB display is directed towards the driver so you don't hafta strain your eyes to see it. The dials are w/In easy reach too. I usually just leave the mic in the center cubby between the 2 cupholders. Mounting it here allows easy access to 12V & ground and easy routing of the coax and power/grounds w/out having to run it down the A-pillar (if mounted to the roof) and it keeps it off the dash w/in the eyes of potential thieves. Plus the dash mounted CB's just looks sloppy/lazy.
  11. 3' tunable Firestick on a simple antenna mount:
  12. Or just buy this: http://boston.craigslist.org/bmw/pts/4164567303.html
  13. You'll probably need the headlight/blinker wiring harness. I believe the wiring harness connector is near the airbox/radiator support. You'll want all the light assemblies too.
  14. Sounds like the headlight switch is bad. It has a rheostat type switch for the dimming the instrument panel lights. They usually go bad in Jeeps. Yes they're a PITA, but if you like dash lights, I'd replace it.
