88whitemanche Posted June 3, 2013 Share Posted June 3, 2013 Does this work in the front of our trucks? This'll be a great and cheap mod Link to comment Share on other sites More sharing options...
valis Posted June 3, 2013 Share Posted June 3, 2013 I've snapped those bolts on every XJ I've owned. I'm pretty sure those bolts are made of pudding. Link to comment Share on other sites More sharing options...
Pete M Posted June 3, 2013 Author Share Posted June 3, 2013 ok, so I'm going to be doing the BPE conversion using the swaybar bracket trick. what shocks do I buy? I've found tons of info online for lifted XJs, but none for stock height XJs. :( Link to comment Share on other sites More sharing options...
Automan2164 Posted June 4, 2013 Share Posted June 4, 2013 I bought Monroe Sensa-tracs. After all the research I did on the forums, it seemed to be the best budget shock replacement for a factory style ride. Rob Link to comment Share on other sites More sharing options...
Pete M Posted June 4, 2013 Author Share Posted June 4, 2013 They are a good choice and likely what I'll be going with. :thumbsup: But what I meat was; what model of vehicle with give me the correct length shock for a stock height XJ with a BPE installed? (for example, Comanche rear shocks seem to work for a 3" lift) or am I over thinking this and should just get stock ones and push out the pins. maybe that's why there aren't any examples out there in internetland. Link to comment Share on other sites More sharing options...
Alexia Posted June 4, 2013 Share Posted June 4, 2013 Bar pin eliminators are about 0.5" of difference. Nothing to worry about it unless rear up travel is critical. Link to comment Share on other sites More sharing options...
Pete M Posted June 4, 2013 Author Share Posted June 4, 2013 gotcha. :thumbsup: Link to comment Share on other sites More sharing options...
Pete M Posted June 7, 2013 Author Share Posted June 7, 2013 New shoes!! found a good deal on some 245/70/16 tires and wrapped them around my rubicon rims. :D though the new rubber has made it dreadfully obvious that the rear of my XJ is sagging. :( I think I'll throw on some MJ shackles for now until I put together a plan for beefier springs. Link to comment Share on other sites More sharing options...
Pete M Posted June 8, 2013 Author Share Posted June 8, 2013 that was a surprisingly hellish project, but the shocks are now mounted. :banana: and if you're wondering why there are two nuts on the left side, it's because the bolt refused to stop spinning and tighten down all the way. it's all good now. :D Link to comment Share on other sites More sharing options...
dfreeman616 Posted June 8, 2013 Share Posted June 8, 2013 nice. although if you don't already have a long enough list, that fuel filter looks nasty. Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2013 Author Share Posted June 9, 2013 It's part of the next phase. :thumbsup: also on that list are fixing the A/C, new valve cover gasket, tracbar (little loose), alternator (squeals sometimes), etc. on the plus side, the bolts to the broken rear bumpstop came right out. :eek: should be a cinch to replace it now. :D Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2013 Author Share Posted June 9, 2013 I don't have the words to describe how awesome it is to be daily driving a Jeep again. :D (even if it is just an automatic) Link to comment Share on other sites More sharing options...
mpace6a Posted June 12, 2013 Share Posted June 12, 2013 I don't have the words to describe how awesome it is to be daily driving a Jeep again. :D (even if it is just an automatic) My manches down for the moment...driving a 2nd gen dodge...I miss my jeep. Nothings near as fun as dd'ing a jeep! Link to comment Share on other sites More sharing options...
