New Shocks, Monroe Sensa Track Load Levelers
One of the biggest complaints I had with the Comanche is you put anything in the back and it will drop.  Well I think I found the solution.  Rockauto $62 delivered.  These shocks gave my truck about 3/4" of lift.  They ride is SMOOTH, no bounce.  When I sit on the back of the tailgate the truck will drop about 1/4".
  • Replies 82
Advanced Auto sells Monroe, you should be able to look them up there.
Not Auto Zone or Pep Boys -- they sell Gabriel. Gabriels are also excellent shocks, but I don't think they have a coil-over load-carrying shock.
  On 4/22/2013 at 6:35 PM, Blue88Comanche said:
was the ride height stock to begin with?
What he said ^
  On 4/23/2013 at 1:28 AM, airspeed said:
The Monroe p/n is 58497.  Why they don't cross this p/n over to the Comanche, I don't know.  They have the 5/8" loop fittings on both ends, it must have something to do with the min - max travel dimensions.
did this give you 3/4" lift over factory?
Because that would look at perfect with 3/4" in the rear and 2" lift in the front. Let alone a stiffer rear because mine droops why down with me just sitting in it lol
Yes I had stock ride height to start with.  I had a heck of a time trying to install them.  I jacked the truck up by the rear differential and took the old shocks out.  Put the new shock on the top pin and thought how on earth will I ever compress this shock to mount on the lower pin.  I felt like a fool for about 15 minutes then I lifted the truck from the frame and let the axle hang down, they went right on.
Here is the data from the Monroe application guide.      58497 L1 L1 14.000 23.375 9.375 V/R P829
  On 4/24/2013 at 2:39 AM, Minuit said:
Glad I saw this, been looking at new shocks. Just to be clear, the price RA lists is for both, right?
Correct both sides, I think mine came out to ~72 shipped.
Advance Auto was like 90
Amazon was 75
I bought these, installed today.  I measured before and then measured after.  When I lowered the truck, it appeared that they lifted the rear about 1.5".  Then I got up on the bumper and jumped up and down on it several times.  Measured again, and it sat at only about 1/2" higher than originally.
So took it for a ride.  Shocks felt firm, but not hard, nice actually.  Much better than the Gabriel Ultras I had on there (only about 2,500 miles old) Took it down one of the bumpiest streets around and they worked well, not nearly as bouncy.
Parked it right back in the driveway and measured again...the final height was more like 5/8", which is fine, I wasn't looking to boost it, we'll see what happens when I go get a load of wood, see if they really "level" the load.  So far, so good.
PLUS, most importantly...they LOOK cool.
Getting ready to order all new shocks for my rig and I'm going to run these on the rear, but not sure what to run up front. Not looking to spend a lot, $62 for the pair was one reason I like these as well as them being black. The rig is mostly just driven on the road and is stock height. So what is everyone here using up front?
If you are putting the SensaTrac load levelers on the back, I would think that putting regular SensaTracs on the front would make sense.
I just put all new SensaTracs on the XJ after a lot of research. Seems that people like them for what they are, a cheaper stock replacement that helps the ride a bit without blowing the bank. If I would have had a bit more scratch, I would have gone OME because I plan to lift it at some point, but for now, the Monroe's work fine. Rock auto has a rebate when you buy Monroe shocks also... My purchase of four got me $30 back, which means one shock was free. Oh, and Monroe's are lifetime replacement IIRC.
Rob
  • 5 months later...
