1987Comanche Posted June 23, 2013 Author Share Posted June 23, 2013 Put POR-15 on the pass floorboard. They were in good shape overall, with one nickel size hole in the pass floor pan Also cleaned up the pass fender. Removed the black vinyl tape stripe, the "sport" decal, and panted the bottom of the fender red (as opposed to black from the donor Cherokee sport). Not perfect but a lot better: Before: After: Also a glamour shot with the '91 I found for sale: Link to comment Share on other sites More sharing options...
1987Comanche Posted July 14, 2013 Author Share Posted July 14, 2013 Finally had a chance to clean & POR-15 the driver's side floor. There was a fair amount of rust hiding under the seam sealer and the clutch MC had been leaking for quite a while but, overall, the floors were pretty decent. Note the random corner of sharp steel Toledo #2 left sticking out of the floor: Finished product: Link to comment Share on other sites More sharing options...
zackcj7 Posted July 14, 2013 Share Posted July 14, 2013 Did adding the foam to the bench help? My bench is in great shape, but when I sit in the drivers spot I sink a good 4 inches. The passenger side still sits like new. :) And before any comments about going on a diet I only weigh 160. Link to comment Share on other sites More sharing options...
mvusse Posted July 14, 2013 Share Posted July 14, 2013 In order to make the new pump fit you have to cut 2 tabs off the top retainer for the fuel pump. When finished the retainer should look like this: I had to make the same modifications to fit my Airtex "direct replacement" pump. Link to comment Share on other sites More sharing options...
1987Comanche Posted July 14, 2013 Author Share Posted July 14, 2013 Did adding the foam to the bench help? My bench is in great shape, but when I sit in the drivers spot I sink a good 4 inches. It helped to a certain extent (no more hole to sink into) but the seat was less pliant with all the foam filling the hole. I think I added too thick a piece of foam. I took the bench apart and it turns out the bottom cushion is replaceable (seat back foam is bonded directly to the frame). The ideal solution would be to find the bottom foam at the jy and replace just the foam. The fabric can be ripped/stained as long as the foam is ok. Link to comment Share on other sites More sharing options...
1987Comanche Posted July 14, 2013 Author Share Posted July 14, 2013 I had to make the same modifications to fit my Airtex "direct replacement" pump. I'll be curious to see how the Airtex pump performs over the long haul vs. the Bosch. Did your instructions chronicle the need to trim the retainer plate? The Bosch instructions were *&%^ Link to comment Share on other sites More sharing options...
1987Comanche Posted August 11, 2013 Author Share Posted August 11, 2013 Changed out Georgia's diff stock this weekend. The side gears & diff pins were starting to give out but the R&P looked good. I was debating what to do with the axle but decided that with stock tires & no thoughts of towing dropping some parts into the OE D35 was an ok option. Also the Yukon Gears kit uses redesigned side gears & diff pins for greater strength. Yukon gear kit: New side gears have greater support in the backface & a bigger radius at the root of the gear. Diff pins (spiders) are about 0.015" thicker in overall height too: 0 New diff stock installed. R&P look pretty good: Diff pins were spalling out. Georgia had a hitch when I got her so I wasn't surprised: Link to comment Share on other sites More sharing options...
FrankTheDog Posted August 11, 2013 Share Posted August 11, 2013 How much was the yukon spider kit. I have a stock 92 D35 in good shape sitting on the floor with broken spiders. I'd like to be able to throw it in while I change the gears in my D44 over to 4.10's. Link to comment Share on other sites More sharing options...
1987Comanche Posted August 11, 2013 Author Share Posted August 11, 2013 How much was the yukon spider kit $135 shipped Link to comment Share on other sites More sharing options...
1987Comanche Posted August 13, 2013 Author Share Posted August 13, 2013 Came out of work today and found that Georgia was the victim of a hit & run. The damage is confined to the rear bumper but, prior to this morning, my bumper was mint :fs1: . I may ask security to review footage and see if they can figure out what happened: Link to comment Share on other sites More sharing options...
1987Comanche Posted August 18, 2013 Author Share Posted August 18, 2013 Put new ball joints in Georgia this weekend. The OEM lower ball joints were scary (3/16" play :eek:). Took her for a short test drive and she tracks a lot better. Unfortunately there's still some popping in the front, though the scary (deep) pops seem to be gone. I was thinking about grabbing the drag link & tie rod assy at the jy if I find a nice one. Link to comment Share on other sites More sharing options...
1987Comanche Posted August 19, 2013 Author Share Posted August 19, 2013 Scary looking ball joint :ack: . I was originally worried that the upper pass ball joint wasn't 100% seated but, looking at the old ball joint, it appears part of it had a small gap on the top of the knuckle too (0.005" on one side, flush on the other). Must be machining variance in the axle. Link to comment Share on other sites More sharing options...
1987Comanche Posted August 22, 2013 Author Share Posted August 22, 2013 Update on Georgia's popping in the front end. I'm hesitant to say I completely fixed it but she hasn't made any popping/clunking noises in 24 hrs :banana: I found 3 different issues: 1. Tie rod boot on driver's side was broken and the grease was gone. The TRE casting would periodically hit the steering knuckle. New polyurethane boots (and a thorough flushing of the joint with grease) took care of that. (more clunking than pop but quite loud) 2. Scary looking ball joints. (popping on expansion joints, uneven driveways, etc) 3. Defective track bar :doh: . That was one of the first things I changed but the bushing was C*&^. (popping on turns, start/stop) Link to comment Share on other sites More sharing options...
1987Comanche Posted September 4, 2013 Author Share Posted September 4, 2013 Hit the jy this past weekend and found a few things for Georgia. Her old wiper transmission was shot (replaced the bushings, wipers still slapped the cowl) so I picked up a nice tight one from a 2000XJ. Put new bushings in it and dropped it in: Also grabbed an accelerator cable (throttle sticking shut), gray console lid, & a few other odds and ends. Also happy to report that the popping is still gone :banana: Link to comment Share on other sites More sharing options...
1987Comanche Posted September 21, 2013 Author Share Posted September 21, 2013 Have to pick up a few appliances this weekend and noted that, with the OE bedliner, there are no provisions to reach the cargo tie downs. After some measurements, partial bedliner removal, and some drilling with a 1/2" bit I now have access to the tie downs :D In case anyone is wondering, the tie down hooks are level with the 5th molded rib in the OE bedliner. Also, surprisingly, the front tie downs are about 3" back from the front corner of the bedliner Link to comment Share on other sites More sharing options...
1987Comanche Posted October 7, 2013 Author Share Posted October 7, 2013 Hit the jy this weekend and found a few interesting things. Saw this '89 4X4 in the parking lot at the U-Pull-it and spent a few minutes talking with the guy. Went to the 2nd U-Pull-It (only 20 min drive from the first one) and found an XJ Waggy with a nice front clip. It was too nice to leave behind...this one is going to OneOverZero for his MJ. Pulled the woodgrain dash trim from the Waggy for Georgia and put it in tonight: Link to comment Share on other sites More sharing options...
1987Comanche Posted October 31, 2013 Author Share Posted October 31, 2013 Georgia is the first MJ I've owned with decent paint so it only seemed right to give her a wash & wax. This is the first time I've ever waxed an MJ and I'm on #3. Other than the white road paint (from the PO) I'm pretty happy with how she turned out. Some glamor shots: Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 31, 2013 Share Posted October 31, 2013 Pretty! :thumbsup: Link to comment Share on other sites More sharing options...
1987Comanche Posted November 1, 2013 Author Share Posted November 1, 2013 Thanks :D Considering that I found her totaled and covered in pine needles I'm happy (and a bit surprised) to see there was that much shine left in the paint. She was worth saving... Link to comment Share on other sites More sharing options...
westypoo Posted November 4, 2013 Share Posted November 4, 2013 For the white paint try and dab some paint thinner on a rag and see if the white paint comes off. I'm a painter in the winter months, so I can say it's safe to try and I bet it might take it off. When you get it all off, re-wax the affected area. Link to comment Share on other sites More sharing options...
1987Comanche Posted November 5, 2013 Author Share Posted November 5, 2013 I tried household paint thinner, lacquer thinner, Sherwin Williams "Shur Will Clean" paint prep, and kerosene. Nothing touched it. The only thing that seems to work is the passage of time...ever so slowly it seems to get brittle and crack/come off. At the current rate it will take about 50 yrs for it to all come off :doh: Link to comment Share on other sites More sharing options...
1987Comanche Posted December 8, 2013 Author Share Posted December 8, 2013 Fixed 2 of my 3 interior squeaks/rattles. Picked up another glove compartment latch at the jy which cured the squeaky glove box door. Also grabbed the 2 plastic spacers and metal receiver for the horn button which fixed the rattling center. Still trying to figure out what the center console lid needs to stop squeaking... Georgia has been pulling her weight around the house. Had to pull the trans out of the car to get it rebuilt and she's been hauling parts for me. Pulling a RWD trans is soooo much easier than FWD. Link to comment Share on other sites More sharing options...
1987Comanche Posted December 27, 2013 Author Share Posted December 27, 2013 Santa brought Georgia a USA made clutch master cylinder to replace leaking Chinese clutch master #2. I can now change Georgia's clutch master cyl in 45 mins though I'm trying to get out of this particular business. I sent the Chinese one back to the mainland via Auto Zone with my regards: Link to comment Share on other sites More sharing options...
revmaynard Posted December 27, 2013 Share Posted December 27, 2013 Loving it, nothing quite like a clean OE build! Where near Atlanta did you pick this one up at? Link to comment Share on other sites More sharing options...
1987Comanche Posted December 28, 2013 Author Share Posted December 28, 2013 Thanks! I picked her up from a guy in Snellville, GA and could see Stone Mountain in the rear view mirror as I was trailering her home. I like the subtle, OE look as well. Though the build sheet doesn't reflect all the options on the truck she could have been ordered the way she's sitting now... Link to comment Share on other sites More sharing options...
