my friends restoring a 79' bronco and when he bought it came with a nice pair of front skyjakcer coil springs. he bought a whole lift kit though and didnt need them. so he said i could have the if i could use em. i said no they won't fit. then i went home and put them next to my old stock ones and theyre a little bit beefy but are damn close. might be a stupid question but will they fit?
i did read the ride will be stiff and its not a f250 its a f150. i hardly ever go far with the truck, just to work. also for a good portion of the year i have the plow on and i need a little more beef then stock springs. i know its not the right way to get it done but these springs off him are practically free. so i can take the good with the bad
With a good spring compressor it only takes a few minutes to swap springs,why not put them on and see what you think.
now i have spacers on the front giving me some lift. so putting these on will lift it even more like comanchekid45 said. so I'm gunna need to get my axle to set right, its got stock control arms. its already alittle tweaked. do i need to go as far as adjustable control arms or would a drop arm kit do any good?
what you need to do depends entirely on how much lift you get. anything over 2-3" and you're going to need to look into brake lines, track bar, control arms, sway bar links, shocks, etc.
whatever you do, if it turns out that you can use stock length control arms, I highly suggest dumping the stockers for some WJ arms. they are much beefier. :thumbsup:
You'll be sorry. It will ride pretty much like you removed the shock absorbers and welded solid rods in their place.
I thought you said he was restoring the Bronco. Your (and his) idea of "restore" must be different from mine.
Like a fat girl in short shorts and tank top.... SMH
You mean a BUFF?
Big Ugly Fat Flocker? :banana:
