89JeepMJ
Everything posted by 89JeepMJ
  1. I'm looking for a layout with dimensions. Point to point measurements of a Comanche frame. Did some looking and couldn't find anything. Thanks guys.
  2. really shouldn't be that hard. I'm going to order one and get it done.
  3. That's pretty amazing that everything works and by 180ing everything. I'm deffintly going ahead and doing this. Thank you for your help everyone
  4. Do you have to change the wire plug or did you hard wire it?
  5. So a cherokee one would work with modifications?
  6. Shops that specialize in that?
  7. I know they don't make them anymore. I've been getting by with the gauge reading a quarter tank off. Jumping to full or empty or not reading at. Adjusted the needle a couple times so it's reads right. Just a pain not getting accurate readings. I know most guys are going to say get one from the junk yard. Has anyone done anything else though. Like maybe a cherokee tank swap and converting it. I don't know. any ideas would great thanks.
  8. Thanks for the reply. I'm not against tinting. Just not on my headlights. Don't want to restrict my light. Want to go the opposite way haha
  9. I got everything I need besides the fittings for the radiator. I got some ideas but the thread on the radiator would be extremely helpful.
  10. Okay thank you.
  11. That's exactly what I was looking for! Is there a special kindof line just for the tranny fluid because I know they have fuel lines and everything made from them.
  12. Lines need to be replaced. Want to do them in those build it yourself lines. With the blue and red fittings. Made by crown? I think. Just wondering if anybody has done this and send pics. Wondering the thread size on the tranny and radiator too
  13. Okay thank you
  14. not specfic. just in general
  15. will a tranny off a 4 cyl bolt up to 6 cyl or are they completely different?
  16. Okay. I was just going by what I was told. Of course you can't trust everyone.
  17. I have a 1989 jeep Comanche 4x4 6 cyl Was wondering if a ax15 out of a 95 yj 4 cyl would bolt up I've been planning on a swap for awhile Done some research. Got a good deal on the ax15 comes with the transfer case I'm just not wise on all the ins and outs of what will bolt up to what So I need some input thanks guys
  18. Can you put a 91+ throttle body which is four bolt onto the renix three bolt. I know they make a adapter plate to it. Is it worth it and what involved. Maybe there's a thread out there. Thanks
  19. Has anyone built their cooler lines with braided lines and fittings or over all upgraded the lines. Pictures and info would be great thanks.
  20. I emailed a guy about a ford 9 inch. ill see what specs he gets back to me with.
  21. Ford 9 inch not an option?
  22. all valuable points ha. looks like i gotta do some searching
  23. I know zackcj7 already answer it but just to double check. for the D44 and D30. i need a carrier though to go that low right?
