Zebvance Posted January 30, 2015 Author Share Posted January 30, 2015 Little bit of a update. since I graduated, got an engineering job & attempting to do my best to grow my bussiness I havent had much time for the Mj.... I have done a few things here and there and drive it from time to time.. But, I need to try to get this thread up to date on where I'm at with it. I still have not put on the long arm lift, new front axle, or tires. Me and some buddies were planning on hopping back on this thing this weekend to try to fab up the crossmember in the attempt to hopefully have it lifted and 4x4 back in it for the summer months ahead. Unfortunately weather is not going to cooperate. SO now the plan is to work on it 3rd weekend in Feb. The cross member fab is the major stepping stone. after that everything else is ready to bolt up.I also just recently blew out the rear main seal. Since at this point my time is more valuable than money is I plan on taking it to a shop and have them button up every leak on this thing. That will be the first thing that happens after the lift is on.Then Its a alignment, fluid changes, and then Ill have measurements to order the front drive shaft.Man I'm ready to get this thing back off the pavement where it is suppose to be... Link to comment Share on other sites More sharing options...
BlackBeast Posted January 30, 2015 Share Posted January 30, 2015 I have the same bumper on my 1991..Nice build .. Link to comment Share on other sites More sharing options...
Zebvance Posted January 30, 2015 Author Share Posted January 30, 2015 I have the same bumper on my 1991..Nice build .. Thanks I love it, I had to wait almost 3 months from the time of order to get it but it was worth it. Link to comment Share on other sites More sharing options...
Zebvance Posted February 13, 2015 Author Share Posted February 13, 2015 A bit of a quick update, trying to really give the mj the attention it needs. Dropped off the truck at the shop and had them put a new rear main seal in, along with a new oil pan and oil pan gaskets. Buttoned up a few things here and there and then I told them it has started to lose power over the last year but I figured it had to do with the TPS acting up. Just haven’t got around to replacing it. Well here is the bad news. They did a compression test and here are the results. Dry Test Cylinder 1 - 125 psi Cylinder 2 - 100-105 psi Cylinder 3 - 145 psi Cylinder 4 - 130-135 psi Cylinder 5 - 140-145 psi Cylinder 6 -140 psi Then they did a wet test on #2 by putting a few drops of oil in first and it jumped to 150 psi. So that confirms bad ring in #2. He suggested putting some stuff called CRL Restore in it and rocking it. They have used that stuff before and said it really works. They did a compression test after the put it in and #2 read 155-160 psi… Considering the rate at which I drive this thing ( 2000 miles a year),I’m going to rock it with the CRL restore every oil change. The plan is to get a craigslist 4.0 and start building a 4.7 stoker in the garage over a length of time as funds allow. Enough with the bad news and on to the good news. This weekend I have a couple buddies coming to help get the long arms, new dana 30, and 35s on. There is some fabrication that will need to be done to the cross member before we can install it and the motor has shifted sideways a bit from the sketchy trans drop that’s on the truck, so it will need to be man handled some to get it lined up right. Then its bolt on time. There is a lot of work to be done. My goal for the weekend is to have the cross member fabed up and bolted on by the end Sunday. My buddies seem to think we can get the whole lift on. Regardless, progress will be made which Ill be happy with! :banana: :banana: Link to comment Share on other sites More sharing options...
Kickinmule Posted February 18, 2015 Share Posted February 18, 2015 Official Jeepin weekends start on Thursdays! Link to comment Share on other sites More sharing options...
Zebvance Posted March 13, 2015 Author Share Posted March 13, 2015 Empty Post Link to comment Share on other sites More sharing options...
BlackBeast Posted March 13, 2015 Share Posted March 13, 2015 Sweet looks beefy and solid.. Could t help but see extensions! Dang! Link to comment Share on other sites More sharing options...
Zebvance Posted March 16, 2015 Author Share Posted March 16, 2015 Sweet looks beefy and solid.. Could t help but see extensions! Dang! Thanks! :laughin: Link to comment Share on other sites More sharing options...
Zebvance Posted March 16, 2015 Author Share Posted March 16, 2015 This past weekend I was able to get the side frame bolts drilled and in. It was a pain in the @$$. 8 drill bits later everything was bolted up. I don’t have pictures but I put a piece of flat bar on the inside of the frame rail and drilled two holes though it to sandwich the fame in between. Figured that would keep the nut from possibly punching through the unibody.I also was able to get my Hazards working again (which have never worked since I have owned the truck. While at it I mounted two new horns but haven’t wired them yet. The old horn is busted. This was all done in the attempt to get it back street legal to get it inspected. However I still have to tighten up my e-brake cable, as it has loosened up since I installed the 8.8.Since it is going to rain this weekend I I’m going to work on replacing dash bulbs with LEDs and wiring up a few other things.Next weekend we are going camping at Llano State Park right outside of junction. I am seriously thinking about taking the Comanche on this road trip. I have made plenty of trips in it to Huntsville, and Matagorda (2.5 hours) but this makes me kind of nervous because it’s a 4.5 hour drive…I also haven’t driven the truck that much over the past year ( maybe 500-1000 miles) but I have replaced a TON of parts…So the plan is try to get all the little things buttoned up this week and next. Insurance, Inspection, registration, Alignment, Washed and probably take it on its first long road trip. After that the next clear weekend I can get some extra hands the new Long arms, axle, trac bar, coils, and shocks, and 35’s are all going on it.I am really excited about getting this thing going this summer. The hardest part (cross member fabrication) is over. Side note: This weekend I noticed the rockers are getting some rot. So I’ll be doing some research on doing some boat sides or 2x6 sliders. I would like to tastefully incorporate a step on them or something. The old lady already complains that it is too tall for her to get into, so when this thing goes up another 4-6 inches she will really be fussy then lol. Link to comment Share on other sites More sharing options...
Kickinmule Posted March 17, 2015 Share Posted March 17, 2015 Somebody get me a mop! i'm standin in a pool o'drool! oh and keep liftin and eventually she won't have to ride with you at all! Bless her heart... Link to comment Share on other sites More sharing options...
Zebvance Posted March 17, 2015 Author Share Posted March 17, 2015 Somebody get me a mop! i'm standin in a pool o'drool! oh and keep liftin and eventually she won't have to ride with you at all! Bless her heart... LOL, she is not a huge fan of the mj, She said when it gets a paint job she will like it a lot more. So she will prob be happy not ride in it right now....... WOMEN THEY JUST don't GET IT! Link to comment Share on other sites More sharing options...
Kickinmule Posted March 17, 2015 Share Posted March 17, 2015 Somebody get me a mop! i'm standin in a pool o'drool! oh and keep liftin and eventually she won't have to ride with you at all! Bless her heart... LOL, she is not a huge fan of the mj, She said when it gets a paint job she will like it a lot more. So she will prob be happy not ride in it right now....... WOMEN THEY JUST don't GET IT! If that's all it takes I might just leave my rust... Link to comment Share on other sites More sharing options...
WiscoXJ Posted March 18, 2015 Share Posted March 18, 2015 I don't know why I haven't looked at this thread before but quality work man :thumbsup: Link to comment Share on other sites More sharing options...
Zebvance Posted March 23, 2015 Author Share Posted March 23, 2015 I don't know why I haven't looked at this thread before but quality work man :thumbsup: Thanks!!!! Well now you have and keep on looking! Link to comment Share on other sites More sharing options...
Zebvance Posted March 23, 2015 Author Share Posted March 23, 2015 I’m currently working on a lot of wiring in the cab of the truck which I will post a update of when I’m done. This weekend I plan on taking the truck to Llano State park to go camping for the weekend. This past week I got it inspected, insured, and registered. It’s about a 4.5 hour trip, the longest trip I have ever attempted to take with the truck. Kind of nervous.As soon as I get back I’m ripping the front axle and suspension and going to start on the lift. However, until then I still have some things that I have done over the past few weeks to get this tread 100% up to date. I went ahead and gave the truck a FULL tune up. New plugs, wires, rotor, distributer, cap, and coil. Went a bit overboard on the wires, but I got a good deal on them. They are OML 10mm racing wires. After some research, I realized why I had such bad blow by. The flute stems in the valve cover of the stock renix 4.0 sat way to low, sucking up oil and dumping it into the oil filter, just a bad design. Now, since I recently found I have a bad ring in piston #2 I knew that this would not fix the problem but hopefully help to contain the oil enough to get me by until the stoker build. So I ordered a newer style aftermarket cover that did not have the flutes in it. I have since put about 100 miles on the truck and NO BLOW BY! And here it is all done! Link to comment Share on other sites More sharing options...
Zebvance Posted March 23, 2015 Author Share Posted March 23, 2015 Next up, I wired up a little boom boom for the trails. I had a hard time finding a subwoofer enclosure small enough to fix behind the seats of the cab. After I finally found one what should fit I had to add some wood to the bottom of the box for it to sit level in the cab. I had a real problem trying to figure out how I was going to secure it and the amp in place without it rolling around. I was tiring to avoid screwing in to the back wall of the cab at all cost. So with some brain storming I came up with a idea. I went to harbor friend and got some of their bar magnets and screwed them to the back of the box. PERFECT! They stick to the wall of the cab and don’t move a inch! I also did the same set up for the amp and put it to the left of the sub. I don’t have any pictures of the amp right now but I’ll try to t get some tonight.That’s not the end though… I have never been a fan of no name cheap electronics but this time I was forced into buying a no name brand because It came with a box that would fit the cab. Well once again I learned my lesson. 3 Days after I installed the 600 watt max “audio pipe” sub on an OLD 300 watt pioneer amp (not bridged), I blew it. Started smelling and them made some god awful racket. I just bought a 1500 watt max Pioneer shallow sub to replace it which I hope to get to tonight. Link to comment Share on other sites More sharing options...
Zebvance Posted April 8, 2015 Author Share Posted April 8, 2015 Empty Post Link to comment Share on other sites More sharing options...
Zebvance Posted April 8, 2015 Author Share Posted April 8, 2015 Now on to the bad news. I did all that work in preparation to take the truck camping at Llano State Park in Junction, Texas about 5 hours away. I got done with all the work on Wednesday and planned on driving the truck around for a couple of days to give it a shake down before I took it on the trip. With all the work that had just been done to it I thought I needed to. New rear main seal, distributor, engine ground, ground and power cables to the starter and alternator, and then of course all the upgrades I did inside. Well the thing was finally not leaking a drop of oil. Sure enough, drove the truck to work Thursday morning, came out to it to go to lunch and noticed a oil leak. I immediately took it back to Car Docs hoping that they just didn’t do a good job installing the rear main seal and it would be covered under warranty. They called me back and said that both the rear main seal and distributer gasket was leaking again. He said the remembered about the low compression in cylinder #2 and decided to do what they called a “pressure” test and run it up the road. They told me that before he hit 30mph the crank case pressure was up to 3 PSI. They said they won’t replace the rear main seal again because the crank case pressure build up from the worn cylinder rings was the cause of blowing out the seals again. To me it adds up when I think about it. Over the past two years every time I would replace a leaky gasket or seal and new leak would pop up from a place that was not previously leaking. I ended up not risking taking the truck on the trip. But this past weekend I did attempt to see how bad the issue really was. I drove it to my buddies deer lease 100 miles away in Sheridan, Texas. On the way there the rear main seal and distributor gasket leaks got worse and worse, I also believe I developed another leak at the oil pan. From the trip there and back I lost well over a quart of oil. Not to mention I averaged 11.8 MPG on the highway…I hate to say it but I have to call it. The engine is done for. No more Band-Aids. I still plain on getting the lift done to finish that project. After that I am going to start looking for a 96+ motor to build a stroker. I will buy the parts as funds allow and then drop the donor motor and parts off to a very reputable machinist that I trust doing the machining and assembly in my home town. I plan on leaving the current engine in the truck until the stroker is built and ready to drop in. Since it still can move under its own power I feel it’s best to do that if I need to move the truck from time to time. I did consider a V8 swap also, but there are a lot things that offset the benefits of how cheaply I can get a SBC. Here is a list of major concerns with that. - Keeping it cool.I have seen plenty of these swaps done on Cherokees and I always hear the frustrating stories of trying to keep it cool in the small engine bay. The only way I have seen it work is with a $1000+ custom cooling set up. Which I don’t want to have to deal with - Firewall ModificationsA good bit of fabrication will have to be done to the firewall to make the V8 fit. - Mounting the MotorIt will take custom motor mounts not to mention I would need to plate the unibody around the motor to deal with the additional weight. - Transmission set up2 options, buy a high dollar adapter plated to keep my current transmission or buy a TH350 and a adapter plate to mount it to the NP231 - Computer CompatibilityI don’t want to even look into what it’s going to take to make the renix computer and SBC computer talk to each other. - The want for a fresh engineAt the end of the day I want a fresh rebuild. So that will mean I will get the SBC rebuilt regardless. All of these reasons add up to me not perusing it. I think It will end up taking longer to get the truck back running again, cost more than a stroker when it’s all said and done, and be more of a headache. All for what? When the stroker will be putting out the same numbers maybe even better than a stock vortec 5.3 or something. I have started doing research on the renix 4.0 to the 96+ 4.0 HO motor swap and it doesn’t look that bad. The plan is to go with a 96+ because of the better flowing head, intake, exhaust, and bigger throttle body. I will probably get work done on the head or buy one that has already been ported and polished along with a better valve train. They run about $600-750. Or get the new all aluminum head that edelbrock just released for the 4.0, but it runs about $1500.00. In addition I will also have to buy a new header to match up with the 96+ exhaust ports. Also I pain on getting a bored 68mm Throttle body. I want this thing to have plenty of air. As far as fuel goes, I’m going to need to get a better fuel pump and the hesco adjustable fuel pressure regulator along with ford #24lb+ fuel injectors depending on the size of the stroker. I will also like to get an air to fuel ratio gauge to dial it in, but I know they are pricy, if I have that though I should be able to get the mixture right by adjusting the resistance on the MAP sensor.As for the build in all I would really like to stay under $3000.00 in just the motor. I know I can probably add another $1000 in injectors, fuel pressure regulator, fuel pump, header, and Throttle body. I think these are realistic numbers and might even come out under 4k total. I would love to do a 4.9 stroker but I feel it will be more costly and problematic, so I will most likely just go the route of a 4.7. I haven’t picked out the recipe of the build yet because I want to get deep into some more research. However, I did talk to the person that will be doing the assembly and he said to stay away from Keith Black Pistons and Eagle cranks. Both of their quality has really fallen off. He said his experience with SCAT over the past few years has gotten better and better. I trust this guy because he has been doing this for over 30 years and has built hundreds of motors. Furthermore, from the research I have done I should at minimum be looking at 270HP and 300Tq with a stock 96+ 4.0HO head. I am hoping for more like 300Hp and 330Tq though. Which I think are possible numbers. I’m sure I could attempt to throw this thing together myself and probably save a grand but at the end of the day I am willing to pay more to know it was built right by someone that has a good rep and a tremendous amount of experience. With all that said…. LET THE FUN BEGIN! :banana: :banana: :banana: :banana: . :MJ 1: . . :MJ 1: . . :MJ 1: . . :MJ 1: . Link to comment Share on other sites More sharing options...
A-man930 Posted April 8, 2015 Share Posted April 8, 2015 I dig that X-member Link to comment Share on other sites More sharing options...
Zebvance Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks!!! Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 8, 2015 Share Posted April 8, 2015 There will be no firewall modifications required or custom mounts and plating required. The cooling issue is from clowns trying to retain the factory radiator. A aluminum 3 core will keep it cool. You won't need the RENIX ECU if you do a TBI swap. You have a lot of bad information about the SBC swap. The trans issue is not that bad either. Chevys use a drivers side drop transfer. Link to comment Share on other sites More sharing options...
Zebvance Posted April 8, 2015 Author Share Posted April 8, 2015 could you please explain more about no need for new motor mounts? Also I have a aluminm CFS 3 row radiator and It has a hard time cooling in Texas 100 degree weather on the beach in 4wd. Also? so I really want to replace the engine, trans, and transfer case, just because my engine took a dump? not trying to argue just legit concerns? Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 8, 2015 Share Posted April 8, 2015 Advanced Adapters sells mounts. No need to got custom mounts made. I lived in the desert and never once had my rig overheat. If yours is getting hot you have other problems besides the radiator. Probably sludge build up of dirty coolant passages. So you want to spend $2500+ on a stroker? I don't see the logic there either. You can get an entire running chevy truck for less than $1000. Throw in the mounts and knick nacks to do the V8 conversion and you are looking at about another $600. I don't like strokers. They cost too much and unless you get them perfect they blow up way too easy. A 350 is damn near indestructible. Your truck, your money. Good luck with what ever you decide to do. Link to comment Share on other sites More sharing options...
ggcnash Posted April 9, 2015 Share Posted April 9, 2015 ^This^ Link to comment Share on other sites More sharing options...
ggcnash Posted April 9, 2015 Share Posted April 9, 2015 My vote would be SBC buddy has a XJ he did it to wasn't that bad he said he had just under 3k in it. It is bad @$$ he has no regrets with snap your neck power! If you have never driven an XJ or MJ with a SBC do so nothing compares. Link to comment Share on other sites More sharing options...
