lifted_xj Posted February 22, 2012 Share Posted February 22, 2012 I just picked up a ford 8.8 with 4.10 for my comanche and have a buddy that has a 98 Wrangler axle with 4.10 gears I can get off him and be way cheaper than gearing mine. But am I better off keeping mine or just swapping over for around 100$ Link to comment Share on other sites More sharing options...
SW86 Posted February 22, 2012 Share Posted February 22, 2012 is its a low pinion i wouldnt do it. take the gears out of it yes but the housing no. high pinion, grab it. the axle shafts would be a nice upgrade though. maybe buy it and put gears and shafts in the old high pinion axle Link to comment Share on other sites More sharing options...
xjrev10 Posted February 22, 2012 Share Posted February 22, 2012 HP axles are a smigin stronger then the LP30s. But every TJ that rolled off the line had a LP30. Personally, if I could keep the HP I would, but to get the truck on the road, and possibly help out a buddy off load his axle, I would run it. Link to comment Share on other sites More sharing options...
lifted_xj Posted February 22, 2012 Author Share Posted February 22, 2012 Hes got a set of 4.10 gears laying around from his upgrade I can get for 50 but then I have to buy a install kit and pay a guy to regear mine. Link to comment Share on other sites More sharing options...
Motion Offroad Posted February 22, 2012 Share Posted February 22, 2012 is its a low pinion i wouldnt do it. take the gears out of it yes but the housing no. high pinion, grab it. the axle shafts would be a nice upgrade though. maybe buy it and put gears and shafts in the old high pinion axle HP and LP gears are not interchangeable. LP's use standard-cut gears. HP's use reverse-cut gears. The only thing of value on the TJ D30 is maybe the shafts for the other axle the OP says he has. -Adam Link to comment Share on other sites More sharing options...
lifted_xj Posted February 22, 2012 Author Share Posted February 22, 2012 is its a low pinion i wouldnt do it. take the gears out of it yes but the housing no. high pinion, grab it. the axle shafts would be a nice upgrade though. maybe buy it and put gears and shafts in the old high pinion axle HP and LP gears are not interchangeable. LP's use standard-cut gears. HP's use reverse-cut gears. The only thing of value on the TJ D30 is maybe the shafts for the other axle the OP says he has. -Adam Thanks for the info looks like I gotta start saving Link to comment Share on other sites More sharing options...
lifted_xj Posted February 22, 2012 Author Share Posted February 22, 2012 Do I need to get anythign with my original gears being 3.07s? Link to comment Share on other sites More sharing options...
Motion Offroad Posted February 22, 2012 Share Posted February 22, 2012 Do I need to get anythign with my original gears being 3.07s? Yes you will need a new carrier as well to run 4.10 gears. The break point for the D30 is 3.73. -Adam Link to comment Share on other sites More sharing options...
lifted_xj Posted February 22, 2012 Author Share Posted February 22, 2012 haha I figured I would this is gonna cost a little, but be worth it when done. thanks Link to comment Share on other sites More sharing options...
Pete M Posted February 22, 2012 Share Posted February 22, 2012 If it's cheap enough, I'd run that TJ axle. Is it slightly inferior to a similarly equipped HP axle? sure. Is it the end of the world? heck no. :thumbsup: Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 22, 2012 Share Posted February 22, 2012 Yes you will need a new carrier as well to run 4.10 gears. The break point for the D30 is 3.73. -Adam Not if you get the "thick" gears. Link to comment Share on other sites More sharing options...
mnkyboy Posted February 22, 2012 Share Posted February 22, 2012 Yes you will need a new carrier as well to run 4.10 gears. The break point for the D30 is 3.73. -Adam Not if you get the "thick" gears. Are they even available for the D30? I went thick on my D44 but I had to buy a new carrier for my D30 Link to comment Share on other sites More sharing options...
cody4359 Posted February 22, 2012 Share Posted February 22, 2012 i would say put in the tj 30. for $100 you can't beat the price, and with having 4.10 I'm guessing your on 31" tires and youll be fine. but its your $$ Link to comment Share on other sites More sharing options...
Motion Offroad Posted February 22, 2012 Share Posted February 22, 2012 Yes you will need a new carrier as well to run 4.10 gears. The break point for the D30 is 3.73. -Adam Not if you get the "thick" gears. I'm not aware of any "thick" D30 Reverse-Cut gears in the 4.10 ratio (only 4.56). Maybe they are available now but last time we looked for a set nobody was making them that we are aware of. -Adam Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 22, 2012 Share Posted February 22, 2012 You're probably right Motion. I remember on another forum (NAXJA I think) someone was asking about them and one of their vendors said they had D30 thick reverse cut 4.10 R&P available, but can not find it now............. Link to comment Share on other sites More sharing options...
SW86 Posted February 22, 2012 Share Posted February 22, 2012 is its a low pinion i wouldnt do it. take the gears out of it yes but the housing no. high pinion, grab it. the axle shafts would be a nice upgrade though. maybe buy it and put gears and shafts in the old high pinion axle HP and LP gears are not interchangeable. LP's use standard-cut gears. HP's use reverse-cut gears. The only thing of value on the TJ D30 is maybe the shafts for the other axle the OP says he has. -Adam :doh: brain fart! glad somebody caught it Link to comment Share on other sites More sharing options...
ODrab88Mj Posted June 14, 2012 Share Posted June 14, 2012 Sorry to :hijack: hijack thread but is the dana 30 from the TJ a bolt in affair or is there fabbing involved to make it fit in the MJ? I have similar deal on a local dana 30 from a 98 TJ for $75. My dana 30 is on its way out and this deals kinda hard to pass up. Thanks in advanced. :wrench: Link to comment Share on other sites More sharing options...
shelbyluvv Posted June 15, 2012 Share Posted June 15, 2012 It's a bolt in. If I was running 33 or smaller tires I would dump a LP30 in my truck for $100 or less. I have a D35 in my truck with 4:56s because it was cheap and they were factory installed in the XJ it came from. I have a D44 waiting to be upgraded to 4:56 once the 5.2 eats the D35. Link to comment Share on other sites More sharing options...
ODrab88Mj Posted June 15, 2012 Share Posted June 15, 2012 Sweet sounds good I really appreciate the help. 33" is what I am running and 4.56s are on the way. :bowdown: Link to comment Share on other sites More sharing options...
