fbtased2002 Posted January 1, 2012 Share Posted January 1, 2012 Hey guys got a new project for the new year! I picked up a NP242 out of an 89 XJ replace the NP231 in my 89 MJ 4.0 auto. The issue is I'm being told I can't do the swap without removing the CAD! Is this true? Link to comment Share on other sites More sharing options...
Geonovast Posted January 1, 2012 Share Posted January 1, 2012 The NP 242 doesn't have the vacuum fittings for the CAD, so it can't control it. Also, because of the way the NP 242 functions while in Full Time 4wd, a CAD failure could grenade the case. It doesn't cost anything to permanently lock your CAD. You don't have to do anything fancy like replace your axle or get do a one-piece shaft conversion, although it would be a good idea down the road. viewtopic.php?f=9&t=18415 Link to comment Share on other sites More sharing options...
cruiser54 Posted January 2, 2012 Share Posted January 2, 2012 Here ya go: http://www.cherokeeforum.com/f51/free-d ... 1-a-38629/ Link to comment Share on other sites More sharing options...
Eagle Posted January 2, 2012 Share Posted January 2, 2012 As noted above -- just slide over the slider in your CAD and lock it in place. Link to comment Share on other sites More sharing options...
fbtased2002 Posted January 2, 2012 Author Share Posted January 2, 2012 Thanks for the quick response guys! Link to comment Share on other sites More sharing options...
brubakes Posted January 2, 2012 Share Posted January 2, 2012 sorry, not to hijack, but when was the CAD done away with? Link to comment Share on other sites More sharing options...
FrankTheDog Posted January 2, 2012 Share Posted January 2, 2012 sorry, not to hijack, but when was the CAD done away with? 1992 was the first year with out the CAD. After 1989 any XJ with ABS has the larger 297/760 size ujoints, also after 95 they all have the larger joints. Link to comment Share on other sites More sharing options...
flint54 Posted January 2, 2012 Share Posted January 2, 2012 To the OP, let's keep in touch. I'm getting ready to begin that swap myself within the next month or so. I'm also going to switch to the external slave bell housing, will probably refresh the clutch parts, and also add the Novak cable shifter while I have it all apart, plus a new rear rubber mount. While I can, I'm also thinking of seeing whether I can take out some if the shifter freeplay. It's not a lot, but would like less. The first headache I forsee is dealing with those lousy "nutserts" where the crossbar mounts to the frame. I know they can be replaced but I'm going to think about whether there's a more substantial solution, like welding in real nuts. Also a new CPS and grommet while it's free access. Link to comment Share on other sites More sharing options...
fbtased2002 Posted January 2, 2012 Author Share Posted January 2, 2012 Yeah I'll let you know how it goes... I close on my first home in two weeks! So the project will begin in my new shop shortly after that. I got the 242 off CL for $70 with all the linkage and bezel, and now that I know I don't need to budget for a front axle swap I gonna try and stay under $100 for full time AWD! Link to comment Share on other sites More sharing options...
86jeep Posted January 6, 2012 Share Posted January 6, 2012 what all does a 242 comes in Link to comment Share on other sites More sharing options...
fbtased2002 Posted January 6, 2012 Author Share Posted January 6, 2012 As far as I know xj from 87-01, zj 91-98, and I have heard the liberty but I'm not sure what years. Some have different spine counts though. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 6, 2012 Share Posted January 6, 2012 dad's 05 liberty has the 242 Link to comment Share on other sites More sharing options...
86jeep Posted January 6, 2012 Share Posted January 6, 2012 the reason i ask my 91 chevy burb has a 242 Link to comment Share on other sites More sharing options...
brubakes Posted January 7, 2012 Share Posted January 7, 2012 what all does a 242 comes in my 00 TJ, but that was a custom swap. ;) Link to comment Share on other sites More sharing options...
fbtased2002 Posted January 7, 2012 Author Share Posted January 7, 2012 Dodge also used it in the Dakota and durango... Didn't know chev used them though. What side drop its it? Link to comment Share on other sites More sharing options...
86jeep Posted January 7, 2012 Share Posted January 7, 2012 passager Link to comment Share on other sites More sharing options...
carnuck Posted January 13, 2012 Share Posted January 13, 2012 '87 to 08/90 is 21 spline in XJ and MJ. 23 spline after that and usually only on automatics. the reason i ask my 91 chevy burb has a 242 If it's a 700R4 or TH350 then it's 27 spline. TH400 is 32 spline usually but some came with 27 spline. Link to comment Share on other sites More sharing options...
comanche87 Posted January 20, 2012 Share Posted January 20, 2012 I have a 242 tcase in my truck and still have a 90 xj axle under the front. I installed a cable lock kit for the front axle for now. My axle has been leaking for a while out of both sides. I will eventually replace it with a 98 and up dana 30. I love having all wheel drive. I just set it and forget it when either winter is here or when I go offroading. Link to comment Share on other sites More sharing options...
carnuck Posted March 7, 2012 Share Posted March 7, 2012 As far as I know xj from 87-01, zj 91-98, and I have heard the liberty but I'm not sure what years. Some have different spine counts though. "91/'92 ZJs are only found with the '96 TJs. :popcorn: Spline count changes are '87 to '90 21 spline and '91 up 23 spline (they swirled the splines in the late '90s) I put an AW4 and NP242 in mine (and it'll be finished hopefully end of this week while I have access to a garage!) Link to comment Share on other sites More sharing options...
mvusse Posted March 7, 2012 Share Posted March 7, 2012 the reason i ask my 91 chevy burb has a 242 Late reply, but I doubt it, as full-time 4wd was not available in the Burb. It should have a 241 (bigger brother to the 231). Link to comment Share on other sites More sharing options...
mvusse Posted March 7, 2012 Share Posted March 7, 2012 I just swapped a (94?)ZJ 242 into a 96 XJ that was 2wd until then. The shifter bezel (obviously) but also the shift gate for the 242 is different from the 231. Where the handle has to go sideways to go to neutral is further back, and I believe the overall range from 2wd to 4-low is longer. It is located directly underneath the bezel and screws to the transmission tunnel. Link to comment Share on other sites More sharing options...
flint54 Posted March 7, 2012 Share Posted March 7, 2012 "(but also the shift gate for the 242 is different from the 231. Where the handle has to go sideways to go to neutral is further back, and I believe the overall range from 2wd to 4-low is longer.)" Very helpful observation! Do you think the 231 gate can be easily modified/trimmed to permit correct 242 shifting or do you think the 242 gate is a must have? Thanks! Link to comment Share on other sites More sharing options...
mvusse Posted March 7, 2012 Share Posted March 7, 2012 While it may be possible to modify the 231 one, in my case I think it's easier to find the correct one in a junk yard. Link to comment Share on other sites More sharing options...
flint54 Posted March 7, 2012 Share Posted March 7, 2012 I sure wish so. I scour JY's often, and it is rare I find a 242. I could kick myself for not knowing about the shift gate difference when I got my 242. Anyways, I'm on the lookout now - thanks! Link to comment Share on other sites More sharing options...
