86jeep
Everything posted by 86jeep
  1. 2.5 i put new BWD Ignition Coil , new Xact Spark Plug Wire Set, new Autolite Single Platinum Spark Plug's , new BWD Distributor Cap , and BWD Distributor Rotor, all about 4 months ago. Last week i put new Champion Spark Plug's, Denso Oxygen Sensor Direct Fit, and clean the throttle body. it still doing it
  2. Ok i change the 02 i put new plugs and clean the throttle body. It help for a few days. Now it back to poping in the exhaust again when u cut the truck off
  3. 86jeep
    1JTHA6672GT108165
    Year / Make / Model 1986 Jeep Comanche X Engine / Transmission / Drive / Bed 2.5L TBI, auto, 2WD, LWB Build can't read Current Location Wilkesboro NC Status I drive it every day History I m the second owner. The guy bought brand new and he died. A car dealer that i buy a lot from got it from the family. Then i got it. the dealer don't count 160k Image Not Found
  4. 2.5 fuel-injection to 350fuel-injection. Since my 2.5 is FI when i switch to 350. I wonder how hard it would be to keep the FI. I got a 91 burb that is throttle body. what is ya opinion on that topic. I know the 4cy fuel pump might not carry enough fuel. And i know i would need the computer from the burb . I got my 78fsj narrow track passger side drop Axel. My motor will be a 91 burb motor. Tranny And Tcase from the 91 burb. Thanks
  5. i would buy the cup holders in the parts bin if they are forsale
  6. i have had 1750 lbs in the bed of my mj 86 2.5 auto 2wd slow but steady
  7. 1 919 218 6232 his name is eddie he my brother and a great mechanic lives in wake forest close to the lake he got a triler he can come get it tell him pedro gave u his number
  8. at low speeds it don't do it only when u going over 40
  9. I bought a nother set of axel. 78 cherokee narrow track.
  10. got my front axel 78 grand waggy narrow track passer drop so my 350 sbc and 700r4 will work just eed to find a rear i bought one allready out what gear ratio will u think it will be it was a 360 auto quard track
  11. when i shut my 2.5 off the cat and muffler pops like raw fuel being dump in it and it ignited. what would cause that
  12. what truck will i need to get the flat top knuckles from
  13. then it will work with my 350 700r4
  14. 1978 Jeep Cherokee Narrow Track will this work
  15. the reason i ask my 91 chevy burb has a 242
  16. what all does a 242 comes in
  17. so what would be the the axles to find
  18. the axles I found is a j20 heavy duty 44 up front a dana 60 out back i think these would be a good choice are they a way to swicth these to 6 lugs i will get the flat top kunckles for high steer
  19. well i want to go up to about 6 inch lift and i just rather get away from junk steering. I just wondering what axles will be the best. I don't want real wide ones. I all ready got the motor tranny and Transfer case my Transfer case is right side drop. so my axles has to be right side drop
  20. could it all be switch to right side drop i found a j20 with a hd 44 a a dana 60 out back that is right side drop
