Preston Posted July 27, 2011 Posted July 27, 2011 I have a 1988 jeep comanche 2x4. I got the 4x4 axles and drive shafts. The only thing I need is the transmission and transfer case but it has an auto in it. I need to know what 4x4 transmission I can put in it and where I can get the transmission?
64 Cheyenne Posted July 27, 2011 Posted July 27, 2011 Easiest swap would be from a XJ and an auto. Cherokees are pretty much identical to MJs from the doors forward and many parts interchange. If you search 88 Cherokee transmission and transfercase you might find what you need or possibly post in the wanted and a board member might have what you need. And welcome to CC
64 Cheyenne Posted July 27, 2011 Posted July 27, 2011 Yup. Just make sure you grab ALL the linkages and brackets that go with it, saves on later parts hunting trips.
Preston Posted July 27, 2011 Author Posted July 27, 2011 No I have the 2.5L. Would the transmission still fit?
shelbyluvv Posted July 27, 2011 Posted July 27, 2011 AX/4 or AX/5 manual trans or a 904 automatic are the only true bolt ins for your truck. The bad part is they all are junk. I would find a good running 4.0, 4X4 XJ and swap all the parts over to the MJ.
jimoshel Posted July 28, 2011 Posted July 28, 2011 It did. I believe the AW4 was the only auto trans available to Jeep Comanche in 1988 and I'm not sure but i believe it was also the only automatic available for the XJ.
Geonovast Posted July 28, 2011 Posted July 28, 2011 Ok, gotta ask.. What gearing is in your "4x4 axles"?
1tonMJ Posted July 28, 2011 Posted July 28, 2011 Ok, gotta ask.. What gearing is in your "4x4 axles"? 2.58's :nuts: :rotfl2:
Preston Posted July 28, 2011 Author Posted July 28, 2011 So would the auto tranny out of a 4x4 I6 Cherokee fit in my 2.5L Comanche? or can I just use the one I got and somehow make it 4x4?
jimoshel Posted July 28, 2011 Posted July 28, 2011 The automatic transmission in 1988 XJ and MJ was the AW4. Only one offered by the factory. Don't overlook the fact that a PO could have swapped something. The trannies are the same. The bell housings are different, being the 2.5 and 4.0 used different bolt patterns. A 2wd transmission can be converted to 4wd by removing the ext housing and bolting on a transfer case, making sure the output shaft spline count is the same. 21 or 23 spline count. The front drive shaft from any XJ, MJ will fit. Only a rear drive shaft from a MJ will fit. They're out there. Just finding one. Best bet will probably just have one made. :wrench:
terrawombat Posted July 28, 2011 Posted July 28, 2011 A 2wd transmission can be converted to 4wd by removing the ext housing and bolting on a transfer case, making sure the output shaft spline count is the same. It's not that simple. Output shaft lengths are different.
jimoshel Posted July 28, 2011 Posted July 28, 2011 And as usual, you are correct. Had something else on my mind and wasn't thinking. Read my latest post in the Pub. Jim
UnionMJ Posted September 10, 2014 Posted September 10, 2014 Will the 4x4 AW4 work with a 2wd AW4 tcu or do you have to find one of those too? :dunno:
Incommando Posted September 10, 2014 Posted September 10, 2014 TCU will work unless your donor was a very late model XJ IIRC. Assuming you get the correct tranny most of this should apply: http://comancheclub.com/topic/44377-2wd-aw4-to-4wd-aw4-swap/?p=451681 Spending a couple of minutes reading that may be of aid to you. I don't know if everything applies to the 2.5 but it is a good start and covers many of the bases.
88comanchemj Posted September 29, 2020 Posted September 29, 2020 I gotta Manuel 88 comanche short bed what other jeeps 4x4 will work for my truck ?? That will interchange with my 88 really want to keep it a Manuel
Pete M Posted October 1, 2020 Posted October 1, 2020 On 9/28/2020 at 10:08 PM, 88comanchemj said: I gotta Manuel 88 comanche short bed what other jeeps 4x4 will work for my truck ?? That will interchange with my 88 really want to keep it a Manuel the link in my signature has a ton of swapping info in it.
