Preston
Everything posted by Preston
  1. I'm having trouble finding a throttle position sensor for a 1988 jeep comanche 2.5L auto. It is the one that has wires coming directlly off of the sensor with 2 plugs. Anyone know where I can find it or a part number??
  2. The fuel pump and filter are new and I don't think it is the o2 sensor.
  3. Any body know what would cause the left turn signal to come on, solid, when I turn my lights on. The front left park light will be off when this is happening but all the other park lights and flashers work.
  4. I have a 2.5L engine that is giving me some trouble. When it gets up into high RPMs, when it is supposed to shift but I'm forcing not to because I have my foot on the gas, it jumps back and forth sputtering acting like it is not getting enough gas or something. It runs fine all the rest of the time except sometimes when it is cold I will take off in it and the engine will just randomly almost die while I have my foot on the gas. It only does that when it's cold. Please post anything that could help. I don't know if these problems are related or not.
  5. Thanks the diagram helped out a lot!
  6. I have a 1988 jeep comanche 4x4 2.5L and I tore it apart and i need to know how much torque the bolts on the connecting rods. please help!
  7. I’m in: Regular T-Shirt, Large, Ash Grey, Forest Green logo. I will be paying with PayPal just email me where. Also I am interested in the hat. What colors will the hat come with and what type is it going to be?
  8. I have a 1988 jeep Comanche 2.5L 4x2 and the linkage is missing that connects to the Hight ride proportioning valve. I need to know how long it is or where I can get it at. If someone could please measure theirs or take a picture and post it that would be great. The part number is 52002964. I can take a picture of where it goes if needed. The valve is mounted on the rear axle of a dana 35 axle. Thank you!
  9. Okay thanks but there are 2 sizes of bolts. There are two bigger bolts. What about them?
  10. I have a automatic aw4 transmission and I need to know how much to torque the bolts. Please help! The bell housing came out of a 1988 jeep comanche 2.5L if that helps. I had to swap two bell housings.
  11. I think that it is a longbed.
  12. How long should the rear drive shaft be on a 1988 jeep Comanche 2.5L auto (AX-4). Was 2x4 changing it over to 4x4.
  13. So would the auto tranny out of a 4x4 I6 Cherokee fit in my 2.5L Comanche? or can I just use the one I got and somehow make it 4x4?
  14. No I have the 2.5L. Would the transmission still fit?
  15. Would an auto out of a 88 cherokee I6 fit?
  16. I have a 1988 jeep comanche 2x4. I got the 4x4 axles and drive shafts. The only thing I need is the transmission and transfer case but it has an auto in it. I need to know what 4x4 transmission I can put in it and where I can get the transmission?
