UPDATE: I cleaned the chassis to engine ground and cleaned out the C101 with some electronics cleaner and a mechanical pencil, that's all I had in the garage. :dunno: Took it on a test drive only to see if it would possibly stall and it didn't. Then when I got it in the garage again, I proceeded to turn it off and on right away and it would start up, but when I went into the house and then back into the garage to start it, it won't now. When I start it, it seems to almost fire once, then after that attempt, it just turns over while the key is still turned. What else can I do? I'm running out of ideas. I will take the CPS out and do cruiser's tip, but I need to test it first. Just have to force one of my sisters to start it while I read the multimeter while holding the leads on the pins. :roll:
