JeepcoMJ Posted May 23, 2011 Posted May 23, 2011 picked this up today. 1999 cherokee classic TWO DOOR! factory CD/tape deck a/c power windows power locks tilt cruise keyless entry fog lamps front and rear tow hooks factory skid package (front, tcase, gas tank) up-country coil package (1" over stock, no rear sway bar) color match trim package 4.0 5 SPEED! jeep has 250,000 miles on it, and driver's floor rot engine has a wrist pin knock (I've isolated it down to wrist pin, number 4 or 5, once I got the hood open....special thanks to PeteM on that one!) solution...i'm building a stroker for my '87 comanche, and this motor will be the base for the stroker. going to put my .030 bore mopar reman with 2001 intake, 62mm Tb, neon srt4 injectors, borla header in this jeep, and build the motor up for my other one. best part...I purchased it from the original owner. came with the window sticker, purchase reciept, build specs, all repair reciepts, etc. anyways, pics. need it done by the weekend...crown vic is about to lose it's trans, so it's gotta go. little bit of rust clean up and repair, it will be a fun little DD. -Pat
JeepcoMJ Posted May 23, 2011 Author Posted May 23, 2011 oh. rear defrost/rear wipe, heated mirrors. all for $625
offroader461 Posted May 23, 2011 Posted May 23, 2011 youll end up selling this one too for a profit...... :clapping: just kidding looks like a good score...been trying to find a late model 5speed xj
SW86 Posted May 23, 2011 Posted May 23, 2011 good score. that rust really makes me cringe everytime but I'm sure you northerners are used to it :shake:
JeepcoMJ Posted May 23, 2011 Author Posted May 23, 2011 Lol thanks guys....this is easy rust, and the skids is in. the cargo area
JeepcoMJ Posted May 24, 2011 Author Posted May 24, 2011 Got three motor and trans out last night, went smooth. Neighbor is painting and blending some dings and small trust repair today as well as color matching the new motor to the body while I prep the trans and repair the floor
JeepcoMJ Posted May 25, 2011 Author Posted May 25, 2011 and no, the optima didn't come with it...the battery in it was the original from when the PO bought it... those are pics from yesterday...today I seperated the engine/trans, undressed the motor, pulled the bellhousing off the trans, and pulled the flywheel and clutch from the engine. taking all of those parts in to work to acid wash them tomorrow.
terrawombat Posted May 25, 2011 Posted May 25, 2011 Looks like a fantastic time to degrease and powerwash that engine bay and trans tunnel! Since daily driver builds aren't ever that exciting, I gave myself the task of creating the cleanest XJ engine bay when I swapped motors in my '01XJ. When I lived at home, my father always complained that my '88MJ would leave oil stains in his driveway and that every 4.0L engine leaked oil, no matter what, even from the factory. It cost me hundreds of dollars in gaskets, seals, and o-rings, but my '01XJ hasn't put a drop of anything on the ground in 30K+ miles. Are you going to do any touch-up paint over the surface rust spots in the engine bay?
JeepcoMJ Posted May 25, 2011 Author Posted May 25, 2011 Yep, touching up the whole jeep, and color matching the new motor....new motor is pretty built and re sealed with a mild cam borla newer intake all seals and is bored .030. Just acid washed the trans, too
JeepcoMJ Posted May 26, 2011 Author Posted May 26, 2011 well, motor did not get color matched...neighbor was not feeling well so he didn't do it. oh well...don't have time to wait, so I got it all dressed back up, put the new flywheel, pilot bearing, clutch, and pressure plate back on the motor. mated the engine back to the trans, and it's *almost* ready to drop in. I'm putting my sealed output np242 on the trans, for the simple fact that this is a daily driver, and it has every option except for sun/moon roof, overhead console, leather, or power seats. basically it has every creature comfort that I want, except for the overhead console. may as well put the np242 in it just to one up the factory. I'll have it running and driving tomorrow night :D
JeepcoMJ Posted May 28, 2011 Author Posted May 28, 2011 well, last night I had a much deserved heavy drinking night...followed by a late return to my house, drunk, and I installed the motor/trans while drunk, got them hooked up, and got it running. now it's time to go back outside and check over all of the bolts in case I didn't tighten them, and then to do up the exhaust.
JeepcoMJ Posted May 29, 2011 Author Posted May 29, 2011 she's running and driving, but a little rough. tank has year and a half old fuel in it. mixed with high octane to run this tank through. the exhaust is sort of shotty...the xj uses 2 and 1/4 OD pipe, but the borla is 2 and 1/8. the tail pipe is/was rusted off, the muffler is pretty crappy, but the catalytic converter is OK. i'm running low on funds, so I will have to run it like that for the week. doing the body work on everything but the floor tomorrow, detailing the interior, plugging the leaking tire, and putting the center console back in. pretty happy with it...for now
JeepcoMJ Posted May 29, 2011 Author Posted May 29, 2011 nice work. diggin that oil fill cap thanks. i bought a box of billet machined oil caps just like it...keeping them for rainy days..but they only work on the older style aluminum valve covers.
JeepcoMJ Posted May 29, 2011 Author Posted May 29, 2011 Wow! You work fast. Good job Pat. thanks, Bo between work and the xj, i've been wrenching a solid 15-18 hours a day this past week. i'm not happy that I wasn't able to make it a nice clean build and pay attention to detail. it will look nice, it does run and drive nice, but I just wish the engine bay was nicer.
philbert001 Posted May 29, 2011 Posted May 29, 2011 Nice truck, clean bay or no! I don't think I've ever seen a 97-01 2 door!
JeepcoMJ Posted May 30, 2011 Author Posted May 30, 2011 thanks. put just over 100 miles on it yesterday with no issues. other than the loud annoyingly droning exhaust, it was a nice easy drive. need to find a high flowing, stock sounding muffler. this thing is definitely restricting my motor.
JeepcoMJ Posted June 20, 2011 Author Posted June 20, 2011 got the first oil change in today...did a 2000 mile change. looks brand new still. also did up the exhaust finally. went with a dynomax ultra flow series, with 2.5" in and outlets, stock catalytic converter, and a band clamp up front with a turn down out back rather than a tailpipe. I may reduce the turndown pipe size to get rid of the mild drone when using cruise control. I went with a 2.5" just because they had that in stock. I'm overall happy with the exhaust. it's throaty, while being quiet at every day speeds. not too shabby at all. aside from that, the jeep has done a very good job of being a DD, getting a solid 19mpg. painting it this week, since I have a loaner car to drive from a friend. pearl flames are in the plans.
JeepcoMJ Posted June 21, 2011 Author Posted June 21, 2011 31's off my '86 yup, they rub at lock or when hitting decent bumps. 3.5" lift is going in. I had to put something in it for now to get rid of the horrible wobble from stock tires.
JeepcoMJ Posted November 18, 2011 Author Posted November 18, 2011 installed a yakima roof rack, built a class 3 hitch, bought a factory swing out, and in a couple weeks I will be replacing all of the springs with some HD ones, adding air shocks, and putting the plow on it. winter's a-coming!
