I'm definately ordering some of these on friday, thanks for the link. The only other question i have is what length of shocks should i run? I'm already running 2" shackles from Rough Country and i'm guessing the SOA will get me 3-4" more?
Your soa will get you 5.5-6.5 more, depending on what perches you get. As for shocks, it depends what you do for shock mounts. If you just swap the stock mounts side to side, and re-use them, then you can run stockers, but your best bet is to get a set of shock mount tabs, and weld them to the axle tube. Then, just jack up the frame, and see how far your axle will droop, measure from lower mount to upper mount, and this will give you an extended measurement. Then just find a shock with a fully extended measurement that is a little longer than your full droop measurement, and you are good to go!
