Blue88Comanche Posted May 6, 2011 Share Posted May 6, 2011 I am looking to buy a Warn winch for my Comanche, but i am not sure how much a MJ weighs.. I think its around 3000 lbs.? is the general rule for winch cap. 1.5x the MJ weight, so i am looking for at least 4,500 lb or better winch. Thanks Link to comment Share on other sites More sharing options...
dfreeman616 Posted May 6, 2011 Share Posted May 6, 2011 3300 lbs or so for my long bed, so you're about right. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 6, 2011 Share Posted May 6, 2011 You'll want an 8K winch. Link to comment Share on other sites More sharing options...
xjrev10 Posted May 6, 2011 Share Posted May 6, 2011 You'll want an 8K winch. minimum. they use the 4500k winches on UTVs and big ATVs. With my XJ, my 9k worked great. Link to comment Share on other sites More sharing options...
Comanche County Posted May 6, 2011 Share Posted May 6, 2011 My MJ is 4400 lbs unless the scales were wrong. But that's with 35s and heavier bumpers, axles and a cage, tools, a couple of Dr Peppers and a can or two of Copenhagen. Link to comment Share on other sites More sharing options...
H3RESQ Posted May 6, 2011 Share Posted May 6, 2011 No less than an 8000lb!!! Link to comment Share on other sites More sharing options...
87mjdriver Posted May 7, 2011 Share Posted May 7, 2011 you can't go wrong with the warn M8000. It is a good winch. less money then the rest and it works for what most of us use it for. unless you are doing a lot of long winching evolutions every day it will hold up. is this going on a DD or a off road only? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 7, 2011 Author Share Posted May 7, 2011 is this going on a DD or a off road only? Yes it is my dd and some off road. And my only vehicle... Link to comment Share on other sites More sharing options...
Blue XJ Posted May 7, 2011 Share Posted May 7, 2011 My XD9000i has served me well on my xj and mj. Link to comment Share on other sites More sharing options...
Incommando Posted May 7, 2011 Share Posted May 7, 2011 Sriously, 8,000 #'s is widely considered to be the minimum for any 4wd vehicle. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 7, 2011 Author Share Posted May 7, 2011 I had been looking at the m8000. Guess I will get it then. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted May 7, 2011 Share Posted May 7, 2011 If you’re going to all the trouble to mount a winch, you might as well get something you can depend on. I’d suggest a 9k, no less than a 8k. Link to comment Share on other sites More sharing options...
89eliminator Posted May 7, 2011 Share Posted May 7, 2011 i have a M8000 and sometimes wish i had gotten a 9k winch. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 8, 2011 Author Share Posted May 8, 2011 Anyone use the warn vr10000? http://www.gowarn.com/prodDetail.aspx?partNo=WAR86255 It's about the same price as the m8000 Link to comment Share on other sites More sharing options...
87Warrior Posted May 10, 2011 Share Posted May 10, 2011 I purchased the VR8000 for my MJ. I choose the 8000# winch because I need it to fit behind the cross member in front of the harmonic balancer for a hidden winch. The MJ is also light weight and will primarily be my DD. Not to mention Warn quality at a value price. I have a SuperWinch EPi 9.5 on my TJ and have only used it on the trail a handful of times. If you ever think the load will be too much for your winch, pull out the snatch block and double up the pulling capability. Why somebody wouldn't have this in their trail bag is beyond me. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 10, 2011 Author Share Posted May 10, 2011 what is the difference between the M8000 and the VR8000? Link to comment Share on other sites More sharing options...
87Warrior Posted May 10, 2011 Share Posted May 10, 2011 It is a value winch. I think it has a slightly different motor and solenoid pack. Typically value winches are slower and create more amp pull from the battery than their higher end brothers. I opted for the warn value winch because I know I will not be using it everyday, more like a few times through out the year. It carries the same warranty as other warn winches too. Link to comment Share on other sites More sharing options...
87mjdriver Posted May 11, 2011 Share Posted May 11, 2011 I had no idea they had a value line of winches, the only reason i went with the m8000 was the price of the winch. Link to comment Share on other sites More sharing options...
87Warrior Posted May 11, 2011 Share Posted May 11, 2011 I had no idea they had a value line of winches, the only reason i went with the m8000 was the price of the winch. They were introduced 3 weeks ago :brows: I was all set to buy the M8000, then this new thing came out :idea: Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 11, 2011 Author Share Posted May 11, 2011 i think they has a vr10k winch for about 570 something and the vr8K for 470 something i can't remember i need to look again.. i am thinking about getting the 10k.. it cost a little more but will be better in the long run i think. Link to comment Share on other sites More sharing options...
87Warrior Posted May 11, 2011 Share Posted May 11, 2011 i think they has a vr10k winch for about 570 something and the vr8K for 470 something i can't remember i need to look again.. i am thinking about getting the 10k.. it cost a little more but will be better in the long run i think. Warn is currently offering an $80 rebate on most of their winches, ending sometime in June I think. You can find the list for qualifying winches and forms on their website. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted May 11, 2011 Share Posted May 11, 2011 i think they has a vr10k winch for about 570 something and the vr8K for 470 something i can't remember i need to look again.. i am thinking about getting the 10k.. it cost a little more but will be better in the long run i think. Sometimes, you get what you pay for Link to comment Share on other sites More sharing options...
