huck731 Posted December 26, 2012 Share Posted December 26, 2012 even better, that means I don't have to cut it all on a plasma table. thanks for the link. Link to comment Share on other sites More sharing options...
redcomanche Posted December 26, 2012 Share Posted December 26, 2012 Awesome truck, i hope one day i get the balls to do the same thing. Link to comment Share on other sites More sharing options...
Rymanrph Posted December 30, 2012 Share Posted December 30, 2012 Mike, I just noticed in your first couple pictures that you had a factory light bar; what happened to it? Also, the Mopar interior paint that you used, how has it held up? I have some interior panels on my new TJ that are faded that I'd like to re-dye. What prep work did you do on the panels before spraying? I'm assuming it was pretty expensive since it came from the dealer. Link to comment Share on other sites More sharing options...
Backdraft Posted December 30, 2012 Author Share Posted December 30, 2012 Mike, I just noticed in your first couple pictures that you had a factory light bar; what happened to it? Also, the Mopar interior paint that you used, how has it held up? I have some interior panels on my new TJ that are faded that I'd like to re-dye. What prep work did you do on the panels before spraying? I'm assuming it was pretty expensive since it came from the dealer. I still have that light bar in my barn. It isn't factory though. I'm not sure what it was made for. When I got the truck, it was in the bed, but not bolted down. It looks like it had been bolted to the wheel wells at one time though. There were bolt holes and flat spots on the wheel wells that I've since repaired. The Mopar paint has held up great. It still has the same shade with no fading. Granted, its only been in there for a little over a year and a half. I prepped the panels by washing them down with soap and water to get them cleaned up. After that I sanded them down with 320 grit sandpaper to get them scuffed up. After sanding them, I washed them one more time to get the dust off them, then blew them dry with an air hose. Wiped them down with mineral spirits then went over them with a tack cloth and finally shot them with the paint. As for the cost. Well, I wasn't pleased at all. They are 5 oz cans and ran somewhere in the neighborhood of $13 per can. Fortunately each panel I painted in the truck got 3-4 coats from one can. I grumbled when I bought them just because I'm pretty cheap. But after I finished, I was pleased I spent the money. Link to comment Share on other sites More sharing options...
buffalob Posted December 31, 2012 Share Posted December 31, 2012 holy $#!& batman!!!! I just spent a substancial bit of my coffee drinking time this morning reading your complete build thread. Awesome transformation, awesome work, awsome truck.... Link to comment Share on other sites More sharing options...
92tanMJ Posted January 6, 2013 Share Posted January 6, 2013 Damn dude you have such a good lookin rig! Link to comment Share on other sites More sharing options...
Dirteatr717 Posted January 7, 2013 Share Posted January 7, 2013 :O where did you get those LED license plate bolts? I'm in need of such a fancy thing! Btw bumper came out awesome :thumbsup: Link to comment Share on other sites More sharing options...
Backdraft Posted January 8, 2013 Author Share Posted January 8, 2013 Thanks guys! Nick, here's the fancy pants LED bolts: http://www.amazon.com/gp/product/B004PC49ZQ/ref=oh_details_o00_s00_i00 Link to comment Share on other sites More sharing options...
Backdraft Posted January 19, 2013 Author Share Posted January 19, 2013 I was going through my desktop earlier and stumbled across some old pictures of the Comanche from when i first got it. I completely forgot all about these. Most are pictures from the seller and a couple are when I got it back to the property. I thought it was nostalgic and had to share. Link to comment Share on other sites More sharing options...
Backdraft Posted January 26, 2013 Author Share Posted January 26, 2013 Thanks to a thread from Sir Sam a while back, i decided i needed another little doodad in my truck. Link to comment Share on other sites More sharing options...
turner-2000tj Posted January 27, 2013 Share Posted January 27, 2013 :thumbsup: :thumbsup: I like it! Link to comment Share on other sites More sharing options...
jpdriver1 Posted January 28, 2013 Share Posted January 28, 2013 beautiful job :bowdown: :bowdown: --- dumb question, what did use to hang the overhead console ?? Link to comment Share on other sites More sharing options...
Comanche County Posted January 28, 2013 Share Posted January 28, 2013 Damn it, I've followed this forum far enough. Its time you proved your MJ's worth by robbing a bank or something like that. Jay Link to comment Share on other sites More sharing options...
Rymanrph Posted January 29, 2013 Share Posted January 29, 2013 Mike, the outlet is cool, but how is it connected/wired? Link to comment Share on other sites More sharing options...
Backdraft Posted January 29, 2013 Author Share Posted January 29, 2013 beautiful job :bowdown: :bowdown: --- dumb question, what did use to hang the overhead console ?? The headliner is from Steve at SMS Headliners. The backboard is pretty thick and stout. I lined it up where I wanted it and marked it. Then cut a hole in the headliner for the hanger on the console to slip into. On the front. Its held up with two screws. I just used the two from the donor when I pulled it. Link to comment Share on other sites More sharing options...
Backdraft Posted January 29, 2013 Author Share Posted January 29, 2013 Mike, the outlet is cool, but how is it connected/wired? Ryan, the outlet is powered using the same wires from the power socket I pulled out. I cut the OEM plug off and crimped female blade connectors on to the wires. I picked that side because the fit was better and it was also switched power. Link to comment Share on other sites More sharing options...
Backdraft Posted January 29, 2013 Author Share Posted January 29, 2013 Damn it, I've followed this forum far enough. Its time you proved your MJ's worth by robbing a bank or something like that. Jay Haha, Jay. I have a few days off. I'll have to see what I can come up with using all my scary black "assault weapons"! May go annoy some liberals and chase them down the streets in the truck. Because, you know, I'm a terrorist with those guns. I drive a gas hog that destroys the environment. All those horrible things! Link to comment Share on other sites More sharing options...
imstuck Posted February 12, 2013 Share Posted February 12, 2013 Wow! very impressive. Link to comment Share on other sites More sharing options...
92tanMJ Posted February 13, 2013 Share Posted February 13, 2013 Oh my lord I wish I would/could find one this nice :drool: Link to comment Share on other sites More sharing options...
High2by Posted February 24, 2013 Share Posted February 24, 2013 Backdraft, my hat's off to you sir. You have really done some amazing work and given me some great ideas for my own MJ. Keep up the great work, a Jeep is never done!! Link to comment Share on other sites More sharing options...
martin809 Posted August 17, 2013 Share Posted August 17, 2013 Truck looks Amazing!!! I know what your lift is but how bad did the 33s rub when you only had 4.5 lift in front.I have that front and rear and want to try 33s. Link to comment Share on other sites More sharing options...
platinum5.9 Posted August 24, 2013 Share Posted August 24, 2013 We need updates..... Its been way to long! Link to comment Share on other sites More sharing options...
86 mj Posted September 29, 2013 Share Posted September 29, 2013 very nice job Link to comment Share on other sites More sharing options...
daking Posted October 20, 2014 Share Posted October 20, 2014 Very good build. any updates? Link to comment Share on other sites More sharing options...
Backdraft Posted October 20, 2014 Author Share Posted October 20, 2014 No sir,not really. Just maintenance. Shamefully I haven't given it much attention lately. Work and family has taken the lions share of my time. But shes still trucking along. I kissed the rear end of a Mitsubishi Eclipse a couple of weeks ago on the way home. Back end of their car was dented in pretty bad. My front bumper didn't even have a scratch. I guess that's karma for you when you cut someone off and slam on your brakes! Link to comment Share on other sites More sharing options...
