1J7F2617KL530470
Dechion
Well, I was at the JY this weeend getting parts for both my Jeeps and I came across an MJ. I was already out of time and had to get home, so all I had time to do was grab the VIN. If someone could run a build sheet for me (or at least give me a year) I will get it listed.
1J7F2617KL530470
From the really quick look I was able to get it's (probably) '89 long bed, 4wd, bench seat, silver or grey, pretty sure it was a pioneer. It had been picked over pretty good, but did have a decent aluminum camper top and bed mat.
The 10th digit is the year. It follows the alphabet. Starting at 1986:
1986:G
1987:H
1988:J
1989:K
1990:L
1991:M
1992:N
'89
I don't believe they use the letter "I" in VIN's or the letter "o" due to easy confusion with its number counterpart, so that's why its skipped.
Rob L.
  • 9 years later...
  • 1 month later...
*B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT
-SA Charcoal
155 Zone 55-Milwaukee
1AA U.S. Dealer Retail
4HC Special Scheduling Condition III
5AL Low Series Tracking
APA Monotone Paint
BAY 105 Amp Alternator
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT  Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HAA Air Conditioning
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JKB
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX
LAF Seat Belt Alert-Driver Seat only
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3
QS3 DOVER GREY MET C C SECONDARY PAINT - HS3
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Steering
SCB  Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TAE
TBC Compact Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJM 15X7.0 Chrome Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z67 Left Front Spring Group XVI
Z86 Right Front Spring Group XV
Build date 2/6/89
Body code JL62
  • Pete M changed the title to 1J7F2617KL530470
  • 4 months later...
