Everything posted by Dechion
For starters, this is not on my MJ, though it has it's own problems as well. This particular problem is on my XJ ('94, 4.0, 5 speed, 4wd) Of all the little clips that could break it had to be to be one that keeps my clutch release arm on it's pivot ball. Without the clip the clutch slave keeps shifting off the arm and not letting me shift. I know that the drivelines are the same and was hoping someone here had some insight. I didn't come here just to complain though, I came to ask if anyone has managed to replace that clip thru the starter mounting hole without dropping the tranny. (or any other way that means I don't have to drop it) I am pretty sure I am looking at pulling it apart, but if there is an easier way i am all ears. Hell, if you are in the area and know how to pop one on without a teardown I'll buy you a beer or twelve to stop by and show me. Already had the tranny off this damn thing once, and don't want to go there again if I can help it.
Thanks for the input folks, I'll keep poking at it. Who knows, maybe i'll get lucky.
Good morning folks, been kinda quiet here for a while for me. Mostly because i'm eyeball deep in my XJ getting it back on the road. Just havn't had much time for the interwebs. Anyhow, I'm back and starting back in on the MJ now. The question of the day is what would cause the MJ to die just when it's first starting out? It starts up just fine, and idles just fine. If I leave it idle for a few minutes then it's fine. Once it's actually moving it's fine, even if I have to stop after a block or so. If it's still warm from running everything's fine. The problem is when first shifting into gear (drive or reverse) after a fresh startup it will die. :hmm: Generally once it starts back up it usually runs fine. :dunno: I'm sure it's something simple, but I just can't seem to figure it out. Wondering if anyone else had a similar problem. The MJ in question is an '89 4.0 2WD automatic.
Not exactly what you are looking for but I have a swb fiberglass cap i'd part with in SE wisconsin.
The clutch on my XJ has started slipping a bit on me, looks like it's time to plan a swapout before winter hits. I'll probably end up ordering one off Rock Auto, but figured I would stop by and ask here first. Anyone have a clutch kit for one sitting around the garage that will fit a '94 XJ 4.0 4wd that they would like to part with?
without seeing the side plates, I am going to say it mounts to the bumper bolts. At least I think thats where all the drawtites mounted. I think I remember reading about some 1/4" plates that neede to be installed as well, but I don't really know for sure.
Nice find. :cheers: For what it's worth, I was asking myself the same question a few years back. I have a 100 amp wirefeed that I use for small projects and a 300 amp stick welder I use for the big stuff. In my case I use the wirefeed for most of what I do. If it can't handle the job then I mock up with the wirefeed and burn it together with the stick welder for more/better penetration. Thats just me though, I'm a cheapskate. :yes:
It depends on the hitch you have. I believe the stock ones used the bumper bolts, as do most if not all) of the aftermarkets. Do you have pics of the hitch by chance?
What year/motor/etc on that JK? It just so happens I work maintenance for the Post Office (though not on the vehicles). With a bit more info I can go ask our auto tech if he knows what to do. I have see some of our vehicles at other offices converted with a shelf for carrying mail where the passenger seat used to be. No guarentees, but it won't hurt me to ask the guy.
fuel sending unit full/empty resistance?
Dechion replied to big66440's topic in MJ Tech: Modification and Repairs
Do you recall offhand were to take the reading? I am thinking from the violet wire at the fuel pump connector to ground, right? (I still havn't been out there to work on the MJ, both the XJ and my wifes minivan needed my attention this week) -
Actually it could be argued that the firefighters originaly riding in the back were not covered by the design clause (B) but were actually covered by the exception in (C-1) as they were employees engaged in activity necessary discharge of the thier duty. Not trying to shoot you down, but if I was the prosecuter that would be my argument.
Well, It just so happens that I picked up a JY sending unit off a renix today for install tomorrow. (Hopefully it works, I would love to know how much gas I have) Assuming I remember when i'm out there working on it I can put a meter across it and check. Then again I won't be able to test it till Friday when the alternator get here. I know I am wanting to test both and compare them agains each other anyhow. -
thanks much
I'm in the market for a fuel sender for my '89 short bed. Is there a difference from year to year? Shortbed to long bed? I know from my search results that and XJ one is not compatible, I am just trying to find out what is before I go junkyard shopping (probably tomorrow) Thanks, Brad
What Universal Trailer Hitch are you running?
Dechion replied to 91coMANche's topic in MJ Tech: Modification and Repairs
there is also one here for abotu 240 thats made for the MJ, though I didn't call to make sure they still have any stock. http://www.hitch-web.com/vhitch.asp?CLI ... 340&BPID=6 -
well the one in the first post of that article would work if you drilled holes in the frame for the mounting. Other than that there are a few places you might find one for sale online, but they are far from cheap if made just for the MJ. If time is more of a problem than money U-Haul told me that they would make me one from the old plans and install it for something like $500. -
There's been a lot of talk about hitches in this topic, though not much lately. I am still waiting for a drawing of the reese hitch side plate so I can make a pattern for the adapret I was talking about in the post. Edit: Lol, a link would help right? viewtopic.php?f=2&t=28315 -
Well, it's a bit far or i'd just let you borrow it for the weekend and sell it afterward. Unfortunately Reno is a hellava haul from Wisconsin. Good luck in the service.
brake lines after rear proportioning valve removed
Dechion replied to hoggz's topic in MJ Tech: Modification and Repairs
I have seen it done two ways, without changing over to a XJ proportioner that is. One was a guy who brought the two lines out to a "T" tied them together, and ran one line from there back. The other simply put a pipe plug of the appropriate size into one of the two holes on the distribution block and ran a single line from the other. (the furthest forward one is the one being used and the second from the front being capped if I remember correctly) Both setups worked. -
thanks for all the input folks. I am still working on deciding exaclty what to do with mine. I might just keep the MJ as a daily driver and lift the XJ as the toy, since it's already 4WD. Much to think about.
Or depending on where you are located I have one I am looking to get rid of.
Alrighty, this may sound like a complete oddball question. Why would one want to lift their Jeep? (or anything else for that matter) I understand the concept of making larger tires fit being one reason, and I understand that those would be of use in mud holes to reach through the mud and find something to grab underneath. I don't see the need for them other than that really. I just don't understand why lifting seems to be more prevelent than simply tubbing out the wheel wells to accept a larger tire. After all, the ground clearence would be the same lifted or tubbed, it's set by the size of the tires and size and shape of the differential. I am not trying to sound like a smart @$$, I am genuinely curious. I am new to the 4WD scene, and would kind of like to understand why I am doing things beyond "thats what everyone else does" Why is it that big tires and a lifted truck is more desirable for off roading? Can I go trail running with my stock setup, or would that just be asking for trouble? (The 4WD is a '94 XJ for now while I slowly accumulate what I will need to do a 4WD conversion on the MJ, but I want to plan that properly, and thats why I'm asking.)
I have a set of Upcountry XJ coils you can have. Out of a '94 with 110K. Rob L. Thanks much, I'll have to get together with you one day soon. Harvard isn't that long of a haul from Kenosha.
Looks like I will probably end up picking up a set of either stock V8 ZJ or XJ Upcountry ones to get a bit bloser to a level stance. That should give me about 18.5 front and 20.5 rear. I may even put in a 1" spacer to bring the front to about 19.5. I should probably replace the front shocks as well if I do that though.
Ok, for what it's worth I went out and put a tape measure across the outside (too late at night to crawl underneath) and here is what I came up with. 2WD MJ 16.25 front 20.5 rear 4WD XJ 17.5 front 17.0 rear measurements are center of the rim to the bottom of the fender flare, and were taken without a square by the light of a streetlamp, so call them +/- a quarter inch or so.
