when i first got it
the new front clip from a 89 Cherokee Donor Jeep lol
started going red then changed my mind
on a Chevy 3/4 ton on 35" tires
flexed
John Deere Green! LOL
Headache rack w/ led lights and CB antennas
engine out with transmission and transfer case
the motor
visor on
what she looks like right now
the rear axle all it says is Dana on the cover. i don't know what rear end but all my friends say its a 44 and i know for sure i got limited slip
front control arms and drop arm kit
hopefully more pics soon!!! i got a comp cam for the engine and .20 over pistons! bad news is the engine won't be done till i have a head that's good. the machinist said the head was cracked in several places.
  • Replies 98
Truck Stats
1990 Jeep Comanche
Engine- 4.0L I6 (getting bored out Piston size .20 over)
Transmission-?
Transfer case- 231 and own a 242
Rear Axle- Dana 44 w/ limited slip
Front Axle- Dana 30?
Whats LOW COG? and its a 6" from Rocky Road Outfitters.
tires are 33x12.50x15 Big O XTs and rims are Ion Alloy 15x10" wide.
o ok and that paint i went to the dealer and got it a quart for $20.00 or u can go to Lowes and get it in the can i have done both
thanks man. i got it from a guy who custom made it for a datsun or something small like that and we just added a plate to the bottom of it and mounted it it was like 1-2in short on each side. with the plate perfect fit and then used square bumper bolts to mount it. its not coming off anytime soon lol. the led lights are for semi trucks they were expensive tho. the brackets i used came with 2 yellow lights for each bracket and i bought the red individually and changed them out. I'm still going to put led red running lights on the back on the support arms. and led yellow on the side.
looks good, but imo u should pain the engine compartment since the motor is out. I'm a bit if a detail freak tho. how did your rocky road brackets fit? i had them on my xj and the quality wasnt that great. where the bracket and brace bolt together there was a big gap. needed to make shims so they would tighten up together right. also with the 6" lift and 33"s do u need the fenders trimmed??
haha yea but i really don't want to take all the stuff out and redo all that stuff you know. i believe in if it aint broke don't mess with it. every time i do touch something it breaks when it wasnt broke in the first place. that my luck haha. well my shims went in and filled the gap. and suspension wise it doesnt seem bad not soft or hard. umm i don't know about having the fenders trimmed with the lift but i cut them before and with me parking on some ones tires i would recommend it for more flex. tho when i do i have cut the tire but never popped so u need to find out how much u have and trim so you don't cut your tire. i did the motor and lift at the same time. so how the suspension is i don't know yet havent got the motor back yet. i need a new head for the motor. 4.0l I6 1987-1990 (if anyone wants to know). so thats as far as i got. one day i will do the whole truck like u said cuz it does bother me a lil. i want a cowl hood tho and possible a 97 front head panel.
i got a cheap 97+ header on ebay for $40 composite plastic or sumthin. then i got a real one, like $220 with lights ect. they both fit nearly the same but the ebay one didnt have the threaded inserts for the grill. they were either square or round i forget but they were diff then my mj inserts. havent checked the 97+ to see if they just changed design of the inserts. cowls hoods are badass but being a penny pincher i can't justify pain $400-500 for a darn hood. ive seen a few places that alabama cylinder head makes really food heads, theyre $500 tho. you get what you pay for somtimes.
by the way thats a cool name you have :yes:
well if anything i regret doing is i should found a cherokee with the 91 newer 4.0 high output and then bore that one out. and i need lights and everything harness and all but really don't want to spend a pretty penny like u said and the hood would be bad @$$. maybe after deployment. ill get one and add a couple of scoops we'll see how much money i got haha. i live in az so alabama is a long way from az. it would be more to pay just to get it sent when i could go to autozone and get one for 450 something you know.
oh ya i understand lol but maybe compare prices, the alabama head is gusseted where the stock one crack and i think they come with some of the valvetrain, just me but id pay an extra 50 to 100 for a quality part for sumthing important. and you could use the old wiring harness just find and swap out the blinker and parking light connectors. itd be a little work but either way you have to mess with wiring
  • 2 months later...
just shooting an up date on the jeep!! found a head in Pheonix, AZ. i got it for $35.00 perfectly good the guy was parting out his jeep. what a steal. got it checked out its good. now just putting the motor back together thats just gonna take some time. i got a bigger cam from comp cams, pistons (0.20), and all new top end if anyone could help me out iuno how much bigger i made it but if u can please tell me how to figure it out.
How to measure a cylinder
sounds like you got a good deal on that head :thumbsup: what year is it ?
hope you had it professionally Cleaned & magnafluxed to check for cracks! visual inspection is not enough
1990 and yea was a deal and yes I had the block bored out professionally and cyclender head checked out for 300 and new lifters and valve springs installed.
  • 1 month later...
well i got some new pics of the engine and the truck a lil more organized.!!!! and pics of the parts as well!!!
The Manche now
Goodies for the Manche
The Block
The crown of the piston
Almost done
Finished the block and did my rims and tires
The rearo
6.5" Coil Spring from Rustys Offroad
The Donor Jeep Comanche
1991 4.0 HO, auto, 2wd
New water pump
Oil pan painted
Goodies
Timing set
Comp Cams Oil for the Comp Cam read the bottom LOL
Gasket kit
Thermostat
Valve cover
Header
New head liner
Extras the light goes anywhere on the truck and magnetic too and pa system
the rear axle in the donor Dana 35?
Header panel
The cylinder head
the gauge cluster on the donor
the rim that on the rear and on the front driver side i have a complete set. and why not fram they the best filter and i had awesome oil pressure
