Recommendations for spark plugs
I put the new plugs on and that took care of the missing. The old plugs are just BAD. A yellowish-white hard buildup on them and almost none of the metal electrode post left. I'm surprised it ran at all. I've been looking for pictures to show me what might have caused what I had and I can't find any. My haynes manual got flooded when my truck flooded and I haven't replaced it. Anybody have pictures of different fouled plugs and an explanation of what causes it?
not only would you likely not see any benefit over new copper plugs, some guys have had the 4.0 get worse with non-copper plugs. :(
e3 spark plugs are what I would use, they won't open up like regular plugs so the gap will stay consistant. Horsepower TV tested them and got more power better mileage and lower emmissions by using these plugs. They are not overly expensive like the Bosch platnium plugs either.
http://www.autopartswarehouse.com/details/QQJeepQQCherokeeQQE3QQSpark_PlugQQ19782001QQPYRE358.html?apwcid=P1135867996W43b3f85c7ab9e&apwid8I1V365
Oh well thats not good :( I don't think i could ever see my self spending $44 on spark plugs. I just thought it would be cool to have. Thanks for the info tho
Brandon
Why would you want to do that, and what makes you classify those plugs as an "upgrade"?
Local shop sold me a set of the Bosch platinum plugs for less than the copper plugs would have cost. They work fine.
I'm not sure why folks say to stay away from them. :dunno:
Because the platinum tip breaks off and grenades the piston. And they don't produce any better fuel mileage than standard NGKs, so why spend the extra money?
Because Bosh makes great products and thought that there best product in spark plugs would be an upgrade. but that is a bad way to consider an upgrade i know.
My MJ came with Bosch platinums in it. It ran like crap. New Champion copper plugs got it running like a champ.
If anyone likes the platniums you can have them. Come pick them up or pay shipping and they are yours!
Thanks now i know i took it off the "list" :thumbsup:
Brandon
I went with the recommendation in the repair manual. The stuff on the plugs appears to be normal wear but lots of it. I'm sure the plugs should have been changed long ago.
My mileage seems better. It's not missing anymore. No rattle on acceleration and the temp in running normal now.
Go figure.
