project 1988 Pioneer My first project
well with the tires on order and the jeep just sitting, I decided it was time to paint it we had 75 as a high temperature two weeks back so I decided it was perfect weather to paint it wasn't going to get any nicer this year and i didn't want to wait till spring. (short of hanging poly in my shop which would have been way to much work.) So I dug out the ol' spray gun and the used the remainder of the shopline primer I had, So I taped it off,
Then I primed all the rough or unprimed stuff
Then i sanded the rough stuff, and wiped it all down and painted it olive drab
this is after the first coat,
It turned out looking great and I really like it!
That is all for now...
more to come :thumbsup:
  • Replies 83
well i got the jeep all back together, also threw on the bushwackers, i bought 6 months ago when i must have had money to burn
it isn't much of an update but it is all i have, I am still very impatiently waiting for my tires and wheels...
Looking real good! :thumbsup: The paint job seemed to turn out good.
Which brand spray can bed liner did you use on the underside of the bed? I thought I saw a Dupli-Color can in one of the pics, but I couldn't tell for sure. Also, was the olive drab rattle can or spray gun?
  JeepcoMJ said:
and the control arms don't look too beefy.
Rock Krawler has the "beefiest" arms on the market.
Lower arms are made of 2" SOLID STOCK
Uppers arms are made of 1 5/8" SOLID STOCK
No welded bungs; as the arms themselves are machined to accept the joints. I don't think you'll find something stronger anywhere....
well it has been a while since I posted, school has been busy but I have gotten some serious work done on the ol' jeep, well the first thing that i did was paint the jeep letters black
after 24 hours
well after the jeep was painted i decided that now would be a great time to fix the only thing that was truly wrong when i bought, the jeep it was leaking brake fluid from the slave cylinder.
shifter hole looking down
and after an hour of fighting the whole rear of the drive terrain came out;
here is the said to be bad throwout bearing/slave cylinder
this thing was absolutely gross so me and my dad took it to the quarter car-wash it was 7degrees F out side i don't think i have ever been so cold in my life when that water hit. here the drive-terrain all clean :D
i also took this opportunity to scrape all the gunk of the bottom of the trans tunnel so it started looking good
before
after
here is the new and old slave cylinder
it cost $130 stupid expensive puegot tranny
here it is cleaned needing a slave cylinder ready to go back in
then it all went back in (making sure to grease the shaft)
then we also rebuilt the master cylinder which was really simple it came out
ran a (hone)sp down it
then installed the rebuild kit it cost me $9
then we started to bleed the freshly built system and discovered that the line between the slave and master cylinder was leaking :headpop: the main thing i hope is that it wasn't just that line all along. a new one has been ordered and is on its way in...
And in other news these came in :banana:
still waiting on tires...
well I have been busy with school and such but... I finally got my tires!!!
they are guard dogs purchased at treadwright in South Dakota
they are 285/75/16
here they are under my jeep
i also got this in the mail it is my replacement line between the slave and master cylinder
I installed it, here is the old line and the split
then i started it up and the clutch worked!
there are still some odds and ends that need to be finished: not in any particular order:
a brake line
mirrors
alignment
vacuum leak
and bumpers and rocker guards
and some sort of interior
that is all that is left i think...
also as to the Joop, i will hand paint the inside
Well i decided it was time to build a rear bumper for the JOOP. So i took a piece of 4x4 1/4 wall tubing and added some tow shackles and a receiver hitch and ended up with this
thats me putting it on
oh and what is this?
Stay tuned more to come :thumbsup:
  • 4 weeks later...
well with one bumper done i decided it was time to start on the front, so i started with this
i used the cardboard to make the mounts then copied them onto steal, i used this hole and the steering box to mount the bumper
I then added a winch mount
this is what it turned out looking like
i then cut the plate at an angle to finish off the look
I then painted the bumper
And this what it turned out like i am very happy with the look
  cody4359 said:
you sure thoes welds are going to hold that winch on when you put a load on it?
yep, the corner guard welds turned out looking like garbage because i had to add a filler piece and there were some tough gaps to fill; but the winch plate is welded solid on both sides with excellent penetration and a cross brace, the bumper would tear off the frame before the welds failed.
well today i tore out the rear prop valve and ran one brake line back there and threw away the return line and capped it so all brakes are now done
new line
i also installed the mirrors
the weight of the snow really dropped the bed down in this last pic
that's all for now more to come :thumbsup:
those bushwack flares start growing on me, should I get one for my mj with my future 35" or 36" tires?
looks good on your mj :thumbsup:
