Spare tire removal from underside of bed
I got all mine at the Pull A Part off a donor Cherokee. Jack, folding crank, and the lug wrench thats about 2 ft long, kinda L shaped, that's flattened on the end for removing hubcaps. That end will fit into the mechanism for lowering the tire. A big screwdriver will suffice.
So where would the bolt be that yoou use the tire tool to lower it?
If you have a stock bumper it is right above the left hand side of your license plate, it's not really a bolt, it'sm just a smashed piece of pipe designed to turn when you put a crank in it. a regular lug wrench works.
I have an aftermarket bumper which covers the hole, so I have to take my tailgate off to get to the hole. Just stick it in there and crank away.
I used a 3/8" extension of about 8" in length on a socket wrench. Worked rather well as it cleared the license plate (but not trailer hitch ball).
On a related note, will a full size mounted tire (235/75 R15) fit underneath in place of the compact spare? I don't have one to test it on, hence why I'm asking.
I have a 31x10.5 underneath and it fit quite nicely. It hangs down a bit, but nothing that'll get in my way and does not look weird.
It's tight up in there, I saw the "donut" that was there in the JY when I picked the spare holder up (yeah, they had donuts even then), pitiful.
I recommend spraying the HECK out of everything that is supposed to move under there with PB'Laster at least 24 hours before trying to drop it. It took just a minor bit of dinging under mine to get a 33/9.50/15 spare in (to match the rest)
