What I had in the works.
Automan2164
Well, it came up in a thread awhile ago about someone looking for an FSJ, and I said thanks, but I had "Something in the works". While on the search for a tow rig, I found this little guy in our classifieds, as well as on CL...
Hi I have a 87 jeep comanchee long bed 1 metric ton pickup. 4.0 leader 102000 miles on engine. body is shot, 23.5 gal gas tank leaks, brakes have a broken line. Well sell best offer for parts. Ron
He wanted $600 on CL, so I just kept on him, emailed him everyday for a week, until he finally called. After talking for a bit, I realized something. He had had a cap on CL last spring, off of a "1 Metric Ton" Comanche. I called and asked about the truck, but at the time since he had used it for plowing, wanted $12,000 (Yes, twelve-thousand) and I said thanks, but no thanks. Now a year later, the truck blew out a brake line and the tank started to leak. Faced with the repair bill, he decided to sell it, and move the plow on to his Cherokee. The truck has a new radiator, water pump, heater hoses, back slider, catalytic converter, muffler, and tailpipe. The air filter was marked as a year old, and it has absolutely NO OIL on it! 8) The engine is still nice and tight, not even a hint of blow by. :yes: The trans fluid smelled good, and generally, mechanically in immaculate shape. Overall, the drive home was awesome. Straight, rode nice, and cruised like a dream. I had no problem giving the full price. Its an '87, 4.0L, AW4, 231, D30/D44. 101,000 Miles. It has some questionable body work, but the he even included a pint of professionally matched and mixed Jeep blue paint. The guy who owned it is a definite Jeep fan, and is the original owner of an 1984 Cherokee Chief.
This solved my MJ quandary, as I want to build a wheeler, but needed something that could use the factory MJ plow I have in the winter. Something tells me that a truck with a 6.5" lift and long arms wouldn't be a good plow. I have also been looking for a tow vehicle for pulling around XJ/MJ projects. And with this being a Metric Ton, it has the ground to be capable of that. Little brake upgrades, electronic brake controller and some trans cooling add-ons should put it on par for the course. Here are the pics:
And now for the Business end of my new tow rig: :clapping:
The baby blue interior will have to go, as well as the threaded rod antenna. :shake: The truck will get a good going through, as well as a new brake line, and assessment of the tank. But the tank isn't a problem, as I have half of an '87 Metric Ton Comanche in the garage, complete with good LWB gas tank! :brows: Overall, I am very pleased with the latest acquisition, and am proud to welcome it to the family! :yes:
Rob L.
Almost forgot... Any of you cool dudes that work at the Jeep dealer... Could you run the VIN for me, and get an equipment list? Also, any of you other cool dudes with autocheck/carfax want to run it for giggles?
1JTMR65F3HT168828
Thanks fellas. :cheers:
Rob L. :D
The only way that could have gone better would have been "free" and found out it was the last 92 to roll out of the factory.
Congratulations!
Nah, thats a whole other horrid story... For the story on the '92, go here... viewtopic.php?f=3&t=19547
This thread is the one I started for my metric ton. The '92 under the cover is no more good than an organ donor.
Rob L.
Sorry, Chrysler don't have much info on the 87 models, you might be able to look up the codes somwhere else.
23583 - LOU'S JEEP-EAGLE INC Sales Type: 1 - DIRECT RETAIL
City: GENEVA State/Province: IL
Country: USA Telephone: (630)232-4016
Year/Model: 1987 DESC NOT FOUND
Last Odometer: 0 Miles on
Body Style: MJJL62
In-Service Date:
Engine: ERB-DESCRIPTION NOT AVAILABLE
In-Service Odometer: 0 Miles
Transmission: DGQ-DESCRIPTION NOT AVAILABLE
Odometer Type: Miles
Color 1: PXF-DESCRIPTION NOT AVAILABLE
Car Line: XX
Color 2: QXF-DESCRIPTION NOT AVAILABLE
Build Date: May 20, 1987
Current Market Register: Hour: 24
*X8 DESCRIPTION NOT AVAILABLE -
Q8 DESCRIPTION NOT AVAILABLE
AHL DESCRIPTION NOT AVAILABLE
APA DESCRIPTION NOT AVAILABLE
CAC DESCRIPTION NOT AVAILABLE
CGW DESCRIPTION NOT AVAILABLE
CKA DESCRIPTION NOT AVAILABLE
CLE DESCRIPTION NOT AVAILABLE
CUF DESCRIPTION NOT AVAILABLE
DGQ DESCRIPTION NOT AVAILABLE
DMR DESCRIPTION NOT AVAILABLE
ERB DESCRIPTION NOT AVAILABLE
GAC DESCRIPTION NOT AVAILABLE
GEC DESCRIPTION NOT AVAILABLE
GFD DESCRIPTION NOT AVAILABLE
GSC DESCRIPTION NOT AVAILABLE
HCC DESCRIPTION NOT AVAILABLE
JHA DESCRIPTION NOT AVAILABLE
JJA DESCRIPTION NOT AVAILABLE
LMA DESCRIPTION NOT AVAILABLE
MBJ DESCRIPTION NOT AVAILABLE
MDA DESCRIPTION NOT AVAILABLE
NAA DESCRIPTION NOT AVAILABLE
NFA DESCRIPTION NOT AVAILABLE
NHM DESCRIPTION NOT AVAILABLE
PXF DESCRIPTION NOT AVAILABLE
QXF DESCRIPTION NOT AVAILABLE
SBA DESCRIPTION NOT AVAILABLE
TBB DESCRIPTION NOT AVAILABLE
WJD DESCRIPTION NOT AVAILABLE
XEA DESCRIPTION NOT AVAILABLE
Z1B DESCRIPTION NOT AVAILABLE
Special Equipment
Code Description Code Description Code Description
No Special Equipment Available
Dealer Installed Equipment
No Dealer Installed Equipment Available
I was too lazy to go under it and find the tags today, but while paging through the owners manual, I found that for some odd reason, someone had written down the front axle code. After going through my archive, I found that it is referring to an '87 D30 (MJ), disconnect, with 3.55 gears. I am going to assume that's what it has. Be a little odd for someone to write down a ten digit number and it be that precise without actually finding it on the truck. Just wish they had written down the rear so I could see if it had a darned trac-loc. :D
Rob L.
I would assume that with the AW-4 it would have 3.55 gearing, but with it being a MT and a D44 what gears does it have??
MT trucks tended to come with the same gearing as the truck would have otherwise.
Nice snag Rob!
Stick with the Renix, it will treat you well if you give it a chance!
This thing runs way too well for me to start messing with it. I love how smooth this thing runs... It's not broke, so I have no plans on fixing it. :D
Rob L.
