STERLING STINGER Posted December 20, 2009 Posted December 20, 2009 man my 88s engine blew today. plowed all night with it, worked great. driving down the road today for about 6 miles....no warning...POOF! RAT TAT TAT called AAA towed it home oil leaking from the bottom sounds like there is a socket set thrown in the engine @ 278,369 miles on it man I'm really screwed now since that was my work truck now I'm going to try to put the plow on the 92 i don't want to but i have no choice....need to keep company making $ also the add a leafs front coils all 4 shocks tires and its gonna snow within the next week maybe smitty can come help!!!!!!! :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :fs1: :fs1: :fs1: :fs1: :fs1: :fs1: :fs1: :fs1: :fs1: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop:
freakjeep93 Posted December 20, 2009 Posted December 20, 2009 man thats a PITA but why don't you just get another engine for it and swap? instead of destroying your 92. mauybe its related to the trouble youve been ahving lately?
Geonovast Posted December 20, 2009 Posted December 20, 2009 I agree... just get another motor to toss in there.
STERLING STINGER Posted December 20, 2009 Author Posted December 20, 2009 man thats a PITA but why don't you just get another engine for it and swap? instead of destroying your 92. mauybe its related to the trouble youve been ahving lately? i can do some stuff, but an engine is way too big of a project for me i wouldnt even know where to start, even to buy one for the right price, you know not getting ripped off and where to get it installed its a shame too, theres alot of $ invested in it, everything is new except the body and engine i dig my 92 so much.....i don't want to turn it into a work truck at all......but i think i have no choice :wall:
Geonovast Posted December 20, 2009 Posted December 20, 2009 Where to get it installed? Do it yourself. Engine swaps really aren't that hard if you're swapping an identical, complete engine without doing anything to the donor motor.
STERLING STINGER Posted December 20, 2009 Author Posted December 20, 2009 Where to get it installed? Do it yourself. Engine swaps really aren't that hard if you're swapping an identical, complete engine without doing anything to the donor motor. i wouldnt even know which bolt to take off first. I'm not ignorant with vehicles, but that seems very intimidating. i need to take it somewhere to get it done....I'm not comfortable doing it myself, i understand that it would be easy, but i have no puller, or any right tools where would i go to get another engine? would i need an 88, exact as the other one? or maybe buy another 88 or above for a work truck....there like below 2000..... man I'm freakin out
Geonovast Posted December 20, 2009 Posted December 20, 2009 Any 4.0 out of an XJ/MJ from 87-90 will be a direct dump in.
STERLING STINGER Posted December 20, 2009 Author Posted December 20, 2009 thanks, I'm gonna check the classifieds on this site......
87Warrior Posted December 20, 2009 Posted December 20, 2009 Sorry to hear about your 88! Motor swap won't be hard. Start by unplugging eveything and labeling evething with masking tape. Remove the engine accessories like AC and power steering and lay them to the side. Unbolt the exhaust manifold from the down pipe. Break the motor mount cross bolts loose as well as the belhousing bolts. Sippet the front of the transmission with a stable floor jack and remove the belhousing bolts in order. I stick them in the top of a cardboard box to keep them in order. Get the engine hoist chains hooked to the head/block and remove the engine mount cross bolts. Pull forward the up to get the engine out. Get the intake and exhaust manifolds bolted to the head. Repeat backwards to get the new engine in.
freakjeep93 Posted December 20, 2009 Posted December 20, 2009 a really easy way to hook up your chain on the manifold side is to take the manifold off then put the bolt back in through the link in you chain
sinkrun Posted December 20, 2009 Posted December 20, 2009 don't look at it as one big job just several small ones. I have done several on old cars from the 70`s and was scared to do one with all the crap these 4.0`s have but once I started it was no problem quite simple. And remeber theres allways tons of help on here! It may be less work than pulling all the items you listed.
Pete M Posted December 20, 2009 Posted December 20, 2009 check your local craigslist for cheap 87-90 XJs. :D then you'll have LOTS of spare parts. :D and you'll gain valuable experience taking out the XJ engine. plus you can probably find a running-but-rusty XJ for as much as a separate 4.0. At the very least, buy yourself a Haynes shop manual. :thumbsup:
Geonovast Posted December 20, 2009 Posted December 20, 2009 When you get ahold of a replacement motor, just start a thread on it, and we can walk you through it.
STERLING STINGER Posted December 20, 2009 Author Posted December 20, 2009 any suggestions where to find engine?
Geonovast Posted December 20, 2009 Posted December 20, 2009 Doesn't hurt to put up a WTB thread in the classifieds. There's a lot of New England guys on here who might have one/know where you can get one.
HOrnbrod Posted December 20, 2009 Posted December 20, 2009 Doesn't hurt to put up a WTB thread in the classifieds. There's a lot of New England guys on here who might have one/know where you can get one. Yeah, but he's from PA. :D Lots of CC members there; stick a post in the WTB and you'll probably get a good engine very reasonably. You can rent an engine puller too. That's what I did when I put my stroker in. :cheers:
Pete M Posted December 20, 2009 Posted December 20, 2009 if you can swing the funds, maybe buy a running XJ and use that for plowing. XJ for parts: $250 if it's still available in Lafayette, NY http://syracuse.craigslist.org/cto/1508841545.html
sinkrun Posted December 20, 2009 Posted December 20, 2009 Try posting a ad here (http://classifieds.pennswoods.net/classifieds/index.cgi) in the wanted to buy and remeber to look for cherokees also a rusted up running xj is your best bet right now. I am about 3 hrs away and will keep a eye out around here.
Geonovast Posted December 20, 2009 Posted December 20, 2009 Yeah, but he's from PA. Last I checked, PA was part of New England. At least, it is in my book. All those states combined over there are about as big as my back yard.
Wildman Posted December 21, 2009 Posted December 21, 2009 I didn't see a WTB add yet......... But, your about 5 hours Southeast of me, I know it takes 4 hours to get to Binghamton :brows: I have a '88 re-man 4.0 in a XJ with about 40K on it, with the paper work :D But, if your in the neighborhood............stop by, I got everything for doing an engine swap :yes: PA, like NY are part of the "Mid-Atlantic" states.
STERLING STINGER Posted December 21, 2009 Author Posted December 21, 2009 and unless someone has a garage i can use with tools and a engine lift in the scranton area :wall: :wall: :wall: :wall: :wall: :wall: :wall: ....I'm pretty much done
kro10000 Posted December 21, 2009 Posted December 21, 2009 if you can swing the funds, maybe buy a running XJ and use that for plowing. :agree: Buy a torn up xj and mount your plow stuff up to it, fix the work truck and have two MJs as toys :thumbsup:
