Maintenance Required Light?
The '91 & 92 HO's do not have a mechanical timer, it is actually integrated into the on-board computer. The only way to get it reset is to have a shop do it that has the OBD1 scanner. It serves no purpose in the functionality of the truck (in other words pull the bulb it will save you time & money).
Do not confuse the Maintenance required light with the check engine light:
Maintenance required light is only the O2 sensor timer.
Check engine light means you have a problem that can actually affect the operation of the vehicle.
:thumbsup:
In California you will get "fail" on your smog test if one removes the "bulb" for the MAINT REQ light (or any other bulb that flashes at startup), I tried that trick one time. The smog technicians around my parts actually test the bulbs at start up. I purchased the DRB II scanner shortly after to reset the light. I can't help but wonder what RENIX folks do here, since those emission timers cost so much.
Just one of the many paybacks you Cali guys have to suck up and shell out for the privilege of living in "Paradise" Joe. :D Although I can see the need for the DRB2 since you have an HO if you got it cheaply. There are times I'd like to have one too. I pulled the MAINT REQ lamp many moons ago...............
The price I gotta pay for good eaten' I guess. :cheers:
The PO of my Comanche had tried in vain to color over the light with black sharpie to make it go away! I removed the bulb and used it to replace my burned out "BRAKE" lamp (which now stays on constantly due to a bad ebrake switch) and I removed the module and mounting bracket and threw them away. Problem solved permanently.
The ebrake sets off the light? Guess I'd never would have known that (seeing as I don't have a functional ebrake in the fleet).
