james750 Posted October 11, 2009 Share Posted October 11, 2009 Read in the owners manual that I need 75w-90 GL-5 grade lube. But I remember reading somewhere on here that it changed due to synchro problems with that lube, but I'm not entirely sure. Should I put 75w-90 into my trans or is there a different fluid I should use? Link to comment Share on other sites More sharing options...
Pete M Posted October 11, 2009 Share Posted October 11, 2009 current Chrysler rules call for 10w30 motor oil. :thumbsup: Link to comment Share on other sites More sharing options...
ncgamedog Posted October 11, 2009 Share Posted October 11, 2009 Not to contradict, but better read this: http://www.amsoil.com/articlespr/2007/a ... asics.aspx I have been doing some digging on this subject and it looks like the bottom line is you need a GL-3 (if you can find it) or GL-4 compliant GEAR LUBE. They lack the sulfur additives that GL-5 gear oils have, which is what protects your brass syncros. The GL-5 adds sulfur for the added shear protection and high pressures found in hypoid (ring and pinion) gears. The engine oils DO have nearly the same viscosity (SUS not kinematic) as these types of gear lubes but not the additives that will withstand the pressures experienced in a gear on gear situation like in your tranny. There is a property of fluids called "bulk modulus", which is simply the compressibility of a fluid. In general practice, fluids are considered non-compressible (why hydraulics work), but in extreme pressures they can be. Haha, taking a fluids/hydraulics class in school right now. Link to comment Share on other sites More sharing options...
Pete M Posted October 12, 2009 Share Posted October 12, 2009 Yup, I concur. Yet Chrysler says that the engine oil is fine in this particular trans. I went with full synthetic 10w30 in my 90 AX-15. Link to comment Share on other sites More sharing options...
james750 Posted October 12, 2009 Author Share Posted October 12, 2009 I'm pretty confused at this point. I've found many contradicting statements on this matter. I'll stop by Pro Jeep on my way home on Tuesday and see what they have to say about it. Link to comment Share on other sites More sharing options...
Pete M Posted October 12, 2009 Share Posted October 12, 2009 Jeep used to carry a GL3 fluid specifically for the AX-15. They discontinued it and now say that 10w30 is what you should put in it. After all the problems early on, I gotta imagine they were careful about it. Also, for the short time I drove the 90, everything worked just fine. The shifting was much improved, but then the oil that came out was pretty nasty. Link to comment Share on other sites More sharing options...
akamcbird Posted October 12, 2009 Share Posted October 12, 2009 i switched to the 10w30 in my '90 and it is much happyer. i do change it often as tme tranny is starting to get old under my heavy foot, and it doesnt come out like new Link to comment Share on other sites More sharing options...
james750 Posted October 12, 2009 Author Share Posted October 12, 2009 My trans was rebuilt about a year ago, so it should still be in good shape. I have no idea what fluid was put in after the rebuild (I didn't do it as it was beyond my ability at the time) but it is about time to change out the oil, and I had no idea what to put in it. I don't really want to rebuild the trans again because of eaten synchros, so I am hoping that GL5 fluid wasn't put in after the rebuild. Link to comment Share on other sites More sharing options...
kar120c Posted October 12, 2009 Share Posted October 12, 2009 I use nothing but Redline MTL for my manual transmissions. Both my Cherokee and Wrangler have the 3550, and the Comanche has an AX-5 waiting to be installed. Safe for brass synchros. http://www.redlineoil.com/product.aspx?pid=45&pcid=7 Both 3550's have over 125k on them with this fluid and they both still shift and drive "as new". :thumbsup: Link to comment Share on other sites More sharing options...
500 MJ Posted November 11, 2009 Share Posted November 11, 2009 I'm going to be changing out the fluid in my 4wd trans soon. Does anyone know how many quarts I'll need off hand? - I don't have my book accessible right now. Thanks in advance. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted November 11, 2009 Share Posted November 11, 2009 I'm going to be changing out the fluid in my 4wd trans soon. Does anyone know how many quarts I'll need off hand? - I don't have my book accessible right now. Thanks in advance. I just changed my transmission oil to the Redline MT90, and it took a little over 3 quartz. BTW it now shifts flawlessly with no cold reverse grind, or difficulty getting it in first gear. Link to comment Share on other sites More sharing options...
jeepcoma Posted November 12, 2009 Share Posted November 12, 2009 If you don't want to pony up for the MT-90, Penzzoil Synchromax is also supposed to be synchro safe. I used it in my last change to flush what the previous owner had in there (smelled like ATF coming out), I had lots of grinding and difficulty getting it into first. It's smooth now. In the future I think I'll try the MT-90 to see if it improves further. Link to comment Share on other sites More sharing options...
james750 Posted November 12, 2009 Author Share Posted November 12, 2009 I think I am going to just use 10w30, since chrysler recommends it, it should be ok. Link to comment Share on other sites More sharing options...
Tri_X_Troll Posted November 12, 2009 Share Posted November 12, 2009 10w30 in the ax-5 as well? Link to comment Share on other sites More sharing options...
Pete M Posted November 12, 2009 Share Posted November 12, 2009 AX-5 gets regular ol' gear oil. :thumbsup: It's only the AX-15 that can't take the sulfur compounds. Link to comment Share on other sites More sharing options...
DodgeFan01 Posted November 13, 2009 Share Posted November 13, 2009 AX-5 gets regular ol' gear oil. :thumbsup: It's only the AX-15 that can't take the sulfur compounds. I'm assuming by regular ol' gear oil you mean 75w-90? This is a big help, I was wondering the exact same things. Link to comment Share on other sites More sharing options...
Pete M Posted November 13, 2009 Share Posted November 13, 2009 yup. Straight GL-5 works fine. Link to comment Share on other sites More sharing options...
