1990 Pioneer 4x4 Posted September 28, 2009 Share Posted September 28, 2009 I searched but can’t find a thread for fender flares. I went from 30” BFG AT’s to BFG MT’s and that little change now has my front tires rubbing. I’ve seen folks remove them, move them up, cut them squared off, angle cut, and replace them with various products like Bushcrackers. So, If there isn’t already a thread: What Have You Done? Link to comment Share on other sites More sharing options...
reson46 Posted September 28, 2009 Share Posted September 28, 2009 I moved them up to the body line. Willy Link to comment Share on other sites More sharing options...
lostissues Posted September 28, 2009 Share Posted September 28, 2009 cut the hell out of the fenders and replaced the flairs with rear flairs off of a TJ Link to comment Share on other sites More sharing options...
Eagle Posted September 28, 2009 Share Posted September 28, 2009 I searched but can’t find a thread for fender flares. I went from 30” BFG AT’s to BFG MT’s and that little change now has my front tires rubbing. I’ve seen folks remove them, move them up, cut them squared off, angle cut, and replace them with various products like Bushcrackers. So, If there isn’t already a thread: What Have You Done? Where are your tires rubbing? Do you have a lift? The usual place where 30s or 31s rub is on the lower control arms at full steering lock, and that has nothing to do with the flares. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted September 28, 2009 Author Share Posted September 28, 2009 I searched but can’t find a thread for fender flares. I went from 30” BFG AT’s to BFG MT’s and that little change now has my front tires rubbing. I’ve seen folks remove them, move them up, cut them squared off, angle cut, and replace them with various products like Bushcrackers. So, If there isn’t already a thread: What Have You Done? Where are your tires rubbing? Do you have a lift? The usual place where 30s or 31s rub is on the lower control arms at full steering lock, and that has nothing to do with the flares. You’re right; I guess more clarification is needed. When my wheels are compressed and turned either direction, the tires hit the front, bottom side of the fender flares. I don't have a lift but i did get some stiffer springs up front. I guess i'm fortunate that the tires don’t hit the LCA’s. But I hear that the stock LCA’s are another weak link, so that probably needs to be upgraded down the road. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 28, 2009 Share Posted September 28, 2009 You’re right; I guess more clarification is needed. When my wheels are compressed and turned either direction, the tires hit the front, bottom side of the fender flares. I don't have a lift but i did get some stiffer springs up front. I guess i'm fortunate that the tires don’t hit the LCA’s. But I hear that the stock LCA’s are another weak link, so that probably needs to be upgraded down the road. Are you running stock Jeep wheels? If not do you know the backspace of the wheels you do have? Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted September 28, 2009 Author Share Posted September 28, 2009 You’re right; I guess more clarification is needed. When my wheels are compressed and turned either direction, the tires hit the front, bottom side of the fender flares. I don't have a lift but i did get some stiffer springs up front. I guess i'm fortunate that the tires don’t hit the LCA’s. But I hear that the stock LCA’s are another weak link, so that probably needs to be upgraded down the road. Are you running stock Jeep wheels? If not do you know the backspace of the wheels you do have? They’re American Racing, Outlaw wheels. At the time I bought them (20 yrs. ago) I didn’t even know what backspacing was. I just searched on-line and apparently the backspacing is 3 ¾. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 28, 2009 Share Posted September 28, 2009 They’re American Racing, Outlaw wheels. At the time I bought them (20 yrs. ago) I didn’t even know what backspacing was. I just searched on-line and apparently the backspacing is 3 ¾. There's your problem. The B/S is causing your wheels to stick too far out in the wheel wells. Best is 4.0 - 4.5 for our MJs. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted September 28, 2009 Author Share Posted September 28, 2009 They’re American Racing, Outlaw wheels. At the time I bought them (20 yrs. ago) I didn’t even know what backspacing was. I just searched on-line and apparently the backspacing is 3 ¾. There's your problem. The B/S is causing your wheels to stick too far out in the wheel wells. Best is 4.0 - 4.5 for our MJs. Thanks for your feedback. Now when I think about it; they do stick out past the fenders quite a bit even when the wheels are pointed straight Ok, so say I found a similar looking wheel with 4 or 4.5 backspacing, wouldn’t I then have possible clearance issues with the LCA’s? Or would it just be better to deal with the fender flares and not worry about chasing the problem around…? Link to comment Share on other sites More sharing options...
Eagle Posted September 28, 2009 Share Posted September 28, 2009 They’re American Racing, Outlaw wheels. At the time I bought them (20 yrs. ago) I didn’t even know what backspacing was. I just searched on-line and apparently the backspacing is 3 ¾. There's your problem. (I see Hornbrod beat me to it.) Ok, so say I found a similar looking wheel with 4 or 4.5 backspacing, wouldn’t I then have possible clearance issues with the LCA’s? Or would it just be better to deal with the fender flares and not worry about chasing the problem around…? Nope. Stock OEM Jeep rims are 5-1/4" backspacing, and 30x9.50s just barely rub on the lower control arms at full steering lock. I'm currently running 31x10.50s on stock alloy rims on my '88 XJ with no lift. Minor rubbing on the LCAs at full lock turning one way, no rubbing turning the other way. 4-1/2" of backspacing should take care of it for you. Link to comment Share on other sites More sharing options...
mvusse Posted September 29, 2009 Share Posted September 29, 2009 With 4.5" lift springs, 1.75" spacers and the longest cheap shocks in the catalog running 33x12.50 tires on 8" wide rims with 4" backspacing I cut the front of the fenders straight level with the top of the bumper/bottom of lights, then at the edge of the flat part where the raised part for the flares starts. Then cut a little more off the bottom front corner as it was still catching at full stuff. have not decided on what to do for flares yet. Link to comment Share on other sites More sharing options...
Darren Posted September 29, 2009 Share Posted September 29, 2009 I cut my up real high, and used MJ rear flares up front since they're a little bigger. Link to comment Share on other sites More sharing options...
holeski Posted March 15, 2010 Share Posted March 15, 2010 Has anyone seen the Cherokee Country Edition fender flares? I am guessing thats what they are. I stripped a 96 County XJ and noticed the the front flares are wider then the norm but only towards the top and rear. The back flares looked the same. I have a few options and not sure what I really want to do yet. I have a front set of Bushwhacker cut outs, the wider country ones and the stock ones on there now. Link to comment Share on other sites More sharing options...
mvusse Posted March 15, 2010 Share Posted March 15, 2010 All 95 and 96 Cherokees have the front flairs that are wider at the front. Link to comment Share on other sites More sharing options...
holeski Posted March 15, 2010 Share Posted March 15, 2010 OK, cool thanks for that tidbit. Thinking I might put those on the MJ. Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 16, 2010 Share Posted March 16, 2010 on the same note I'm redoing my own MJ and I'm wondering what I will put as for flares I know that some XJ owners put YJ or TJ flares on theirs to widen them and cover more of the tires is that a common mod to do on MJ to? Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted March 16, 2010 Author Share Posted March 16, 2010 on the same note I'm redoing my own MJ and I'm wondering what I will put as for flares I know that some XJ owners put YJ or TJ flares on theirs to widen them and cover more of the tires is that a common mod to do on MJ to? I think i've seen more MJ's with cut fenders and/or moved up. Still need to do something with mine... :hmm: Link to comment Share on other sites More sharing options...
Darren Posted March 16, 2010 Share Posted March 16, 2010 Just get a set of MJ rear flares and run them in the front, it's amazing how much more room they offer. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted March 16, 2010 Share Posted March 16, 2010 (On my XJ) I have 3.5 lift, 31's, 3" BS, aftermarket LCA's and TJ flares. No rubbing, anywhere at full lock and stuffed. I can crank the wheels without ANY rubbing and I have a wicked tight turning radius. On the MJ I have 2" lift (came that way), 31's, stock alloy wheels, 1.5" wheel spacers. No rubbing, yet. Since it's non-op and a work in progress I can't tell you about any rubbing off road, but when I crank the wheels it all looks good. When I flex it (on ramps) the wheel does stuff, but does not hit anything. Of course this is in my driveway, no "real world" action yet. Link to comment Share on other sites More sharing options...
Jeepyjeepy Posted March 20, 2012 Share Posted March 20, 2012 Looking for a place to buy stock style mj fender flairs Link to comment Share on other sites More sharing options...
xjrev10 Posted March 20, 2012 Share Posted March 20, 2012 Looking for a place to buy stock style mj fender flairs Junkyard for the rear fenders. (OE) Fronts are same as a XJ obviously. Link to comment Share on other sites More sharing options...
Boots Posted March 21, 2012 Share Posted March 21, 2012 Wouldn't the rear flares be the same as an xj also? Link to comment Share on other sites More sharing options...
mvusse Posted March 21, 2012 Share Posted March 21, 2012 No. The Comanche has a much larger rear wheel opening than a Cherokee does, Link to comment Share on other sites More sharing options...
Incommando Posted March 21, 2012 Share Posted March 21, 2012 Rear TJ flares at all four places look good IMHO31x10.5's on factory wheels with 1.25" spacers on a no lift 2wd with no rubbing: After SOA & fine tuning the fit Image Not Found Link to comment Share on other sites More sharing options...
Blue XJ Posted March 21, 2012 Share Posted March 21, 2012 You could always make your own like I did Image Not Found Link to comment Share on other sites More sharing options...
