Weezel Posted September 3, 2006 Share Posted September 3, 2006 What is everyone using? ive got my lift (4") in and i am almost maxed out with my stock flex line. Thanks W :Canadaflag: Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted September 3, 2006 Share Posted September 3, 2006 I haven't gotten that far yet, but I think I'm just gonna make a drop bracket and just lower the factory one. When I get to that point I'll know for sure. 8) Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted September 3, 2006 Share Posted September 3, 2006 Use a Mid 90's Dakota line!! Cannot remember the exact legnth. But I am @ about 6" of lift and don't come close to a taught line!! CW Link to comment Share on other sites More sharing options...
Weezel Posted September 4, 2006 Author Share Posted September 4, 2006 sounds good, ill see what i can find at the dealer. thanks W :Canadaflag: Link to comment Share on other sites More sharing options...
JOMJ87 Posted September 4, 2006 Share Posted September 4, 2006 I just used a drop braket also and it works great. Cole Link to comment Share on other sites More sharing options...
M357.5 Posted September 4, 2006 Share Posted September 4, 2006 I am useing a 90's Ford F150 rear flex line........relocated bracket as well. The F150 line is aprox 18" long Link to comment Share on other sites More sharing options...
BrettM Posted September 4, 2006 Share Posted September 4, 2006 dakota line here. worked great even at 7-8" Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted September 4, 2006 Share Posted September 4, 2006 Just curious, how long is the Dakota line? 8) Link to comment Share on other sites More sharing options...
Stumpy Posted September 4, 2006 Share Posted September 4, 2006 sounds good, ill see what i can find at the dealer. thanks W :Canadaflag: most parts stores will have them. Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted September 4, 2006 Share Posted September 4, 2006 Ok, this is kinda a dumb question and I think I already know the answer, but are the F150 and Dakota lines standard or metric? 8) Link to comment Share on other sites More sharing options...
feerocknok Posted September 5, 2006 Share Posted September 5, 2006 I dropped mine with a piece of flat stock. Simple and easy. My rear, though, is only up 2" Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 5, 2006 Share Posted September 5, 2006 Ok, this is kinda a dumb question and I think I already know the answer, but are the F150 and Dakota lines standard or metric? 8) STD Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted September 5, 2006 Share Posted September 5, 2006 Thanks DC :cheers: 8) Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 5, 2006 Share Posted September 5, 2006 '96 Dakota rear line here. Link to comment Share on other sites More sharing options...
Stumpy Posted September 6, 2006 Share Posted September 6, 2006 '96 Dakota rear line here. ^^^ditto...hehe Link to comment Share on other sites More sharing options...
pingpong Posted September 6, 2006 Share Posted September 6, 2006 Custom 36" SS line 45 bucks new Link to comment Share on other sites More sharing options...
hitman72 Posted March 12, 2013 Share Posted March 12, 2013 on the dakota line do you reuse the splitter that is on the jeep already or does the one that comes with the hose work? Link to comment Share on other sites More sharing options...
mjeff87 Posted March 13, 2013 Share Posted March 13, 2013 Metering block/splitter on the axle is different, but you can use the stock one if you want. The later model mopar block incorporates the axle vent into the block and has a larger bore, the stock axle has a separate breather. You can rig the later block to work, but I tapped out the hole in the axle tube to work with it. Link to comment Share on other sites More sharing options...
hitman72 Posted March 13, 2013 Share Posted March 13, 2013 So i can just screw the Dakota hose into the existing splitter? (check to make sure i understand haha) Thanks Link to comment Share on other sites More sharing options...
ComancheKid45 Posted March 13, 2013 Share Posted March 13, 2013 Yep, just go with a 95 Dakota and you should be set :thumbsup: Link to comment Share on other sites More sharing options...
hitman72 Posted March 13, 2013 Share Posted March 13, 2013 cool sounds good. Now Comanchekid you said 95 and the others above say 96. I am guessing they are all the same but just checking, haha thanks Link to comment Share on other sites More sharing options...
