64 Cheyenne Posted September 3, 2009 Share Posted September 3, 2009 Rob L. What axle/axles are you getting out of the ZJ,and what are you putting them in? Quote:I am taking out roasted D30/D35 3.55's, and putting in D30/D44 limited slip with 3.73's. Why? Rob L. Just asking cause I got a D30 for free out of a 94 ZJ ,No CAD,has 297x u joints. This is where I learned about the differences in a "high" or "low" pinion D30.(Mine was "low"=bad). Link to comment Share on other sites More sharing options...
whowey Posted September 3, 2009 Share Posted September 3, 2009 Rob L.What axle/axles are you getting out of the ZJ,and what are you putting them in? Quote:I am taking out roasted D30/D35 3.55's, and putting in D30/D44 limited slip with 3.73's. Why? Rob L. Just asking cause I got a D30 for free out of a 94 ZJ ,No CAD,has 297x u joints. This is where I learned about the differences in a "high" or "low" pinion D30.(Mine was "low"=bad). All ZJ D-30s are low pinion. And I'm fairly certain that the rear is a D-44A.. But I don't think either of us put a magnet on it to check. Link to comment Share on other sites More sharing options...
reson46 Posted September 3, 2009 Share Posted September 3, 2009 As far as I know, the only D44s that came in ZJs were aluminum. Willy Link to comment Share on other sites More sharing options...
jpdocdave Posted September 3, 2009 Share Posted September 3, 2009 Rob L.What axle/axles are you getting out of the ZJ,and what are you putting them in? Quote:I am taking out roasted D30/D35 3.55's, and putting in D30/D44 limited slip with 3.73's. Why? Rob L. Just asking cause I got a D30 for free out of a 94 ZJ ,No CAD,has 297x u joints. This is where I learned about the differences in a "high" or "low" pinion D30.(Mine was "low"=bad). All ZJ D-30s are low pinion. And I'm fairly certain that the rear is a D-44A.. But I don't think either of us put a magnet on it to check. i have a 97 v8 zj in the shop rigth now and the d44 is not aluminum. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 3, 2009 Author Share Posted September 3, 2009 i have a 97 v8 zj in the shop rigth now and the d44 is not aluminum. This titbit of info is promising. Rob L. Link to comment Share on other sites More sharing options...
jpdocdave Posted September 3, 2009 Share Posted September 3, 2009 i have a 97 v8 zj in the shop rigth now and the d44 is not aluminum. This titbit of info is promising. Rob L. if i remember right you should be able to tell just by looking, the aluminum tubes are easy to tell the difference, i'd hold out to find a non aluminum Link to comment Share on other sites More sharing options...
Automan2164 Posted September 3, 2009 Author Share Posted September 3, 2009 i have a 97 v8 zj in the shop rigth now and the d44 is not aluminum. This titbit of info is promising. Rob L. if i remember right you should be able to tell just by looking, the aluminum tubes are easy to tell the difference, i'd hold out to find a non aluminum I don't know how long I can hold out... The howling is getting worse and worse. I'll take my chances. This is just going to be basically stock, maybe a 1-2 lift, and 30's or something at most. Rob L. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted September 3, 2009 Share Posted September 3, 2009 D30 low pinion = increased F/driveshaft angle with lift. Thats why I scratched the low pinion axle idea.I am going to use the 1 piece axles with my CAD style axle though. Larger 297x Ujoints.High pinion. Link to comment Share on other sites More sharing options...
whowey Posted September 4, 2009 Share Posted September 4, 2009 D30 low pinion = increased F/driveshaft angle with lift.Thats why I scratched the low pinion axle idea.I am going to use the 1 piece axles with my CAD style axle though. Larger 297x Ujoints.High pinion. More importantly the decrease in strength of the R&P set in a low pinion set-up. But... Rob and you are talking about two different kinds of projects. Rob is replacing his toasted axle. He is getting 3.73 gears as a bonus. But everything else is staying the same. You are working on a Jeep with a good sized lift and much larger tires. Different project requiring different needs... Link to comment Share on other sites More sharing options...
whowey Posted September 4, 2009 Share Posted September 4, 2009 BTW... its 25% off weekend at LKQ-Rockford. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 4, 2009 Author Share Posted September 4, 2009 25% off?!?!?!?!?!?!?!?!?!? You just made my day Will! :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: That will save me $67.50 on the axles alone! Score! So are you down for some debotchery at 9 am? Rob L. Link to comment Share on other sites More sharing options...
whowey Posted September 4, 2009 Share Posted September 4, 2009 25% off?!?!?!?!?!?!?!?!?!? You just made my day Will! :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: That will save me $67.50 on the axles alone! Score! So are you down for some debotchery at 9 am? Rob L. Yup.... I saw the commercial on tonight during the Bears game I knew you would be thrilled... I can easily afford some more parts now.... I'll be there. But don't expect me to be sunny.... Link to comment Share on other sites More sharing options...
dfreeman616 Posted September 4, 2009 Share Posted September 4, 2009 that LKQ looks even better than the one here, at least with how the ground is packed. The one by my place has some pretty good ruts developing in spots. But I'd recommend them. Link to comment Share on other sites More sharing options...
Geonovast Posted September 4, 2009 Share Posted September 4, 2009 Lemme know if you find a good XJ trailer hitch. I'll find someway to pay for it.. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 4, 2009 Author Share Posted September 4, 2009 Lemme know if you find a good XJ trailer hitch. I'll find someway to pay for it.. Like maybe a discount on a certain HO engine? :brows: Rob L. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 4, 2009 Author Share Posted September 4, 2009 I'll be there. But don't expect me to be sunny.... Sunny? Rob L. Link to comment Share on other sites More sharing options...
Geonovast Posted September 4, 2009 Share Posted September 4, 2009 Lemme know if you find a good XJ trailer hitch. I'll find someway to pay for it.. Like maybe a discount on a certain HO engine? :brows: Rob L. That's what I was thinking. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 4, 2009 Author Share Posted September 4, 2009 That's what I was thinking. Sounds good. I will see what I can do. Rob L. Link to comment Share on other sites More sharing options...
Geonovast Posted September 4, 2009 Share Posted September 4, 2009 Oh, and by "good" I mean; 1. Intact 2. 2 inch receiver. If it's smaller, don't bother. :ack: Link to comment Share on other sites More sharing options...
whowey Posted September 4, 2009 Share Posted September 4, 2009 I'll be there. But don't expect me to be sunny.... Sunny? Rob L. Good mood... and for whatever wierd reason...A regular hitch is $10 a reciever hitch is $30.... But I saw a couple of hitches when we were looking around... Link to comment Share on other sites More sharing options...
Automan2164 Posted September 4, 2009 Author Share Posted September 4, 2009 I'll be there. But don't expect me to be sunny.... Sunny? Rob L. Good mood... and for whatever wierd reason...A regular hitch is $10 a reciever hitch is $30.... But I saw a couple of hitches when we were looking around... Why no good mood? Do ya hate me that much? I planned on helping you pull what you wanted/buy ya lunch at least... Rob L. :( Link to comment Share on other sites More sharing options...
Pete M Posted September 5, 2009 Share Posted September 5, 2009 I have a feeling he might not be a "morning person". :D Link to comment Share on other sites More sharing options...
whowey Posted September 5, 2009 Share Posted September 5, 2009 I'm normally a little slow moving on the weekends. Me getting much of anywhere before 9 or 10 doesn't generally happen(Unless I'm going wheeling). Link to comment Share on other sites More sharing options...
Automan2164 Posted September 5, 2009 Author Share Posted September 5, 2009 Oh, I figured as much. Well we are all ready to go here on my end. I just have to put the toolbox together, but so far in the ZJ I have: Angle grinder, 2 grinding blades, 5 cutting blades Sawzall, 25 Steel blades, 3 Fire/Rescue specialty blades Electric impact 2 Cans "Free" super penetrant smells like nail polish, works awesome ($10 a can) 2 Cans "PB Blaster" penetrant 2 Cans Brake clean Honda Generator 24 PK water Safety glasses Gloves Flashlight We should be good to go. Don't hurry if your not a morning person. I'll get started without ya, and you can jump in whenever. No hurry. Just as long as I get out with my axles by 6PM. Be nice to get some "extra" goodies at 25% off too. :D Rob L. Link to comment Share on other sites More sharing options...
whowey Posted September 5, 2009 Share Posted September 5, 2009 We scored a big pile of stuff.... Rob will add pics.. if his camera didn't break when he got me in the picture..... I am sore and tired... and I had to take a shower as soon as I got home..My wife wouldn't let me sit on anything... Link to comment Share on other sites More sharing options...
