89eliminator's 92 Eliminator
  • Replies 174
Don, if you look in that options list wade posted, it lists hunter green metallic as an option... I didn't think they made green eliminators either, but then again, I didn't think longbed eliminators existed either. :D
Custom order for the last comanche ever made maybe.
Rob L.
Yep, they must have pulled out all the stops in 91-92. Knew about the LWD Elims, but not the Hunter Green paint. You gotta restore that thing back to pure pure stock Wade even if it takes years. Then only drive it in the summer, or move south. A piece of Jeep MJ history that's only going to increase in value. :cheers:
92 dealership brochure says that the Hunter Green on available with Eliminators with a "late availability" asterisk. Same with Midnite Blue.
The other colors for 92 Elims were: White, Black, Colorado Red, Grey Mist Metallic, and Dark Cordovan Pearl coat (looks almost like a purple on the tiny color swatch).
Wade, I'll be very happy to take care of it for you during the winter and make sure it gets plenty of exercise. :cheers:
EDIT:
Means that it wasn't available at the beginning of the year. Doesn't say how late is "late". There are similar asterisks in the cherokee section for the Limited trim level.
All the more reason this thing is a gem. :D
The #5 - #8 digits (reading left to right) on the 2nd line of the plate is the primary paint code.
1 2 3 4 5 6 7 8
X X X X X X X
Reason I'm asking is that I didn't think they made HO Elims in green.
:dunce:
got this back from chrysler today.
Dear Wade:
Thank you for contacting the Chrysler Customer Assistance Center
requesting for the build sheet of your 1992 Jeep Comanche.
In response to your recent email, we are glad to provide the vehicle
build information as per your request. As per our records, your 1992
Jeep Comanche (VIN: NL223002) was equipped from the factory with the
following:
Cloth Low-Back Bucket Seats
Light Group
Skid Plate Group
Monotone Paint
Radio AM/FM Cassette
90 Amp Alternator
500 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
Low Back Bucket Seats
Reclining Front Seats
Carpets - Floor and Cargo Area
Full Length Floor Console
All 4-Speed Automatic Transmissions
4-Speed Automatic AW4 Transmission
Lock-Up Torque Converter
Command-Trac Part Time 4WD System
Floor Mount Automatic Shift Lever
Dana M30/181MM Front Axle
3.55 Axle Ratio
175MM Rear Axle
4.0L Power Tech I-6 Engine
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Front Left Side Sliding Window
Rear Sliding Window
Left Remote Mirror
Right Remote Control Mirror
Manual Remote Mirrors
Air Conditioning
Instrument Cluster w/Tach
85 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
STRIPE/BADGE/MOLDING
Headlamps On Warning Chimes
Courtesy Lamps
Glove Box Lamp
Ash Tray Lamp
Cigar Lighter
Underhood Lamp
Headlamp Off Time Delay
Halogen Headlamps
Fog Lamps
Black Front Bumper
Black Front Bumper
Front Bumper Guards
Front License Plate Bracket
Body Color Grille
Black Windshield Moldings
Upper Door Frame Moldings
Belt Moldings
Body Color Drip Trough Molding
Federal Emissions
EVAP Control System
18.5 Gallon Fuel Tank
Speed Control
Hunter Green Metallic
Hunter Green Metallic Clear CoatAll Radio Equipped Vehicles
AM/FM Cassette Radio
4 Speakers
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Standard Duty Shock Absorbers
Rear Shock Absorbers
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
P225/75R15 OWL Wrangler AT Tires
Goodyear Brand Tires
15X7 Aluminum Wheels
All Aluminum Wheels
Pickup Box
Build To U.S. Mkt. Specifications
GVW/Payload Rating
:rotf:
http://www.automotivetouchup.com/choose ... l=Comanche
:thumbsup: :bowdown:
My best friend from high school got a Scrambler back in @1991, it was an 83?, Laredo, full factory gauges including clock and tach, factory air, EVERYTHING. Sitting in the back yard of some middle aged couple that another friend of ours spotted one day. My buddy bought it for $2200. Still had it until he ran into a ditch and bent the frame about 4yrs ago w/about 160k on it, near zero rust and ran great. Wade, I'll give you $1300 for it, that way you make $100! :brows:
i wonder how close that paint would be to the actual color? :hmm:
It will be darker due to the original paint fade. I used the OEM paint on my new cowl hood (the body paint was only four years old and was always garaged), and it was noticibly darker, not bad, but visible looking closely. Metallics are hard to match. Complete all the body work, entirely, then paint the whole thing. :cheers:
that what i had planned. i was just wondering how close it is to factory. sounds pretty close though!
1 2 3 4 5 6 7 8
X X X X X X X
:dunce:
Dear Wade:
following:
Light Group
Skid Plate Group
Monotone Paint
90 Amp Alternator
3.55 Axle Ratio
175MM Rear Axle
Rear Sliding Window
Left Remote Mirror
Air Conditioning
Cigar Lighter
Courtesy Lamps
Glove Box Lamp
Ash Tray Lamp
Cigar Lighter
Underhood Lamp
Halogen Headlamps
Fog Lamps
Black Front Bumper
Black Front Bumper
Front Bumper Guards
Body Color Grille
Belt Moldings
Federal Emissions
EVAP Control System
Speed Control
4 Speakers
Tire Carrier Winch
All Aluminum Wheels
Pickup Box
GVW/Payload Rating
:rotf:
What does "Front left side sliding window" mean?
