Is it possible to relocate the heater/AC control to make room for a larger stereo/GPS unit...like possibly in the open area at the front of the center floor-console? Sorry in advance if this is a stupid question...
Thanks,
:cheers:
Paul
Obviously, this was a stupid question...
Why, because you didn't get fifteen responses in less than four hours?
Patience is a virtue, grasshopper.
Anything is possible.. I don't think it would be to hard.. A few wires, might have to extend some vac lines, and theres only one cable to reroute. The hardest part I think would be rerouting the cable.. And,, maybe the new mount.
Where would you put it? The dash is pretty small. :hmm:
He suggested the spot in the front of the floor console, but there is not enough room there. I can't really imagine a way to do it myself, but with some creativity and probably a good bit of work, you may find a way.
The best place that I can think of would be were the the ash tray is located. Should fit after cutting the dash to make it fit.
I was looking at a Dodge Dakota and they have a real small AC control. Also vac operated.. Might get one of those and make it fit better.. Years 91-96 I think. The Dakota also uses a AC push button switch which I wish the Jeeps did.. I hate having the AC turn on when you switch to defrost.
just switch places with the radio, radio in middle, heat on top.
EDIT: Maybe you could remove the vent below the heater controls, that is if you don't really mind not having it and put the heater control there.
I have seen the remove the lower vents and drop the heater controls down. A local shop did it for a guy for a double din touch screen I'll see if they will email me some pics. but the cut the vents out for clearance then fabbed a block off plate. It seemed straight forward enough. I am ripping that vent out in the next week or so ill take some pics to show whats all back there.
Cheers, Jesse
" I hate having the AC turn on when you switch to defrost...."
I noticed that too, and my guess is that the design folks intended to
dehumidify as part of defrosting. Since RH goes down as temp goes
up anyways, I don't think AC is needed for defrost, and I don't like
running the compressor any more than I have to. Next time I'm
inside there, I'm going to see if there's some obvious and reversible
way to change controls so that AC is not switched on in the defrost
setting. Anyone done this before?
The A/C system drys the air, and drier air defrosts the glass faster. :thumbsup:
Yeah I know, but it should be our choice to let it do that.. All my Honda's have the switch and I only use it when its really humid out. Most the time in the cold morning it only needs warm air.
Have you confirmed that by looking at the compressor? It might do it without your knowledge. The AC switch might just be for when you want to turn the AC on.
My 91 Geo Prizm (rebadged Toyota Corolla) gave me the selection of using AC with the defrost or not. But other vehicles with AC in my past (81 Caprice, 84 Caprice, 84 Olds 98, 84 Chevy 20 conversion van, 94 Suburban) all turned the AC on with the defrost setting with no option to turn it off. But by looking back at the list, they are all GM.
