tmmoll
tmmoll's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Alright guys. Thanks alot for the help.
  2. So for a SOA its not needed, but couldnt hurt. Got it. My manche is a 86, no rust but alot of dirt and grime with 86000 miles. Should I replace the leafs or just clean them up a little bit, then some new paint? If I should replace them, were can I get new stock springs? Any other small details I should know about an SOA?
  3. Sound like Ill just wait on my 8.8. What about a SYE kit? Would I need one when doing a SOA?
  4. An one have, or heard of somone using there bolt-on SOA kit. The reason I'm going this route is because I'm waiting on a 8.8 for the rear, then I will weld on the perches. But for now i just want to use this kit. Any advice would be great. As for the guys and gals that have used this kit, how much lift did you get in the back?
  5. If you go to a driveshaft shop, they may be able to repair the broken one or build you a new one for around $100.
  6. Look at www.tellico4x4.com. They have the seat brakets from Corrabu. You can use any of there seats with these.
  7. Well it turns out that the hinges are bent back. I got the passenger side on but there is a bigger gap at the bottom of the door. Is this supposed to be thisd way? How do I get the hinges bent back to the right angle?
  8. Thats what I did. However the door doesnt sit right. Like I said there is still about a 6inch gap between the door and the body. Ill post pics tomorrow
  9. I know that. Thats the easy part. I just need to know if the hinges are suppoesed to be swapped as well. The doors are from a 99 cherokee.
  10. Well..... I started to put the driverside door on today and its not fitting right. It doesnt shut all the way, theres about 6inched still left for the door to close. Did I put them on right? I took the bolts off the door and just swapped the doors. Should I have swapped the hinged as well? I wanna make sure I fix this before starting on my passenger side.
  11. I got a sweet deal for a guy and I'm getting both front doors from a 99 cherokee for $100. The only problem is that my manche doesnt have power windows or locks. How do I hook them up with no present wiring there?
  12. Are the rears fiberglass as well? They look stock.
  13. Does any body have pics of fiberglass fender for both the front and rear? I'm trying to decide if thats the look I'm after.
  14. The best place that I can think of would be were the the ash tray is located. Should fit after cutting the dash to make it fit.
