justinquilliam Posted February 22, 2009 Author Share Posted February 22, 2009 pulled the transfercase, the tranny, disconnected the wiring. pulled of the intake and exhaust manifold and cleaned it up for paint. Link to comment Share on other sites More sharing options...
DirtyComanche Posted February 23, 2009 Share Posted February 23, 2009 I imagine there really isn't much wiring to that engine, once you boil it all down. Link to comment Share on other sites More sharing options...
justinquilliam Posted March 5, 2009 Author Share Posted March 5, 2009 cut 3 more inches out of the back of the bed. after fitting the engine in and out a few times, i decided to cut out the fire wall to get the engine to set back where it should be and the tranny shifter fell right in where the stock shifter would be and i startedd cutting off all the brackets for the suspension to plate the frame with 1/8 inch plate. Link to comment Share on other sites More sharing options...
WahooSteeler Posted March 5, 2009 Share Posted March 5, 2009 Thanks for posting so many pics, I look forward to all your new posts, awesome project. :thumbsup: Link to comment Share on other sites More sharing options...
justinquilliam Posted March 12, 2009 Author Share Posted March 12, 2009 plateing the front frame stubs to handle the diesel this is the load leveler i borrowed from another shop. when i borrowed it, it was broken so i fixed it and a few days later they came and took it back so i decided to make my own. ill have pics of it this weekend. the ford nine inch found a new and better home Link to comment Share on other sites More sharing options...
pilotblake Posted March 12, 2009 Share Posted March 12, 2009 I had the same idea for the hood only I cut it on the body line. And I cut my side sections from a junk chevelle hood...you know for speed. and painted......... Link to comment Share on other sites More sharing options...
Darren Posted March 13, 2009 Share Posted March 13, 2009 That "frame" you built is badass! I like it. Link to comment Share on other sites More sharing options...
justinquilliam Posted March 21, 2009 Author Share Posted March 21, 2009 the frame plating is done. i have pics of the load leveler that i made. the engine mounts from the nissan were cut down to fit between the mj frame rails, and i made my own mounts on the truck out of 1/4 inch plate. i started my tranny mount with 1/4 inch plate where the old tranny mount bolted on and 2x2 .120 box tubing for the crossmember. the down tube for my turbo won't fit around my newly plated frame and i didnt want to cut it so i need to make a new plate to go in place of the down tube and weld mandrel bent tubing to it clocked at the angle i need. Link to comment Share on other sites More sharing options...
reson46 Posted March 23, 2009 Share Posted March 23, 2009 Are you using a camera phone? Willy Link to comment Share on other sites More sharing options...
justinquilliam Posted March 24, 2009 Author Share Posted March 24, 2009 no just a old and beat up kodak digital camera. Link to comment Share on other sites More sharing options...
reson46 Posted March 24, 2009 Share Posted March 24, 2009 It looks like you are doing some pretty cool stuff, I just can't tell what half of it is from the blurry pictures. :ack: :yes: Willy Link to comment Share on other sites More sharing options...
justinquilliam Posted March 27, 2009 Author Share Posted March 27, 2009 the tranny mount is done. i bought 2 1/2 inch johnny joints to make extended radius arms. Link to comment Share on other sites More sharing options...
Pete M Posted March 27, 2009 Share Posted March 27, 2009 Yay! radius arms! :D If you want any flex in the front axle, I suggest avoiding the poly C-bushings. I've been quite happy with my stock Ford rubber ones. :thumbsup: Link to comment Share on other sites More sharing options...
dakal Posted March 27, 2009 Share Posted March 27, 2009 great build Link to comment Share on other sites More sharing options...
Sir Sam Posted March 29, 2009 Share Posted March 29, 2009 Let me guess, to get the engine to clear the front axle you had to shift it back to the point you needed to cut away on the firewall? Link to comment Share on other sites More sharing options...
justinquilliam Posted March 29, 2009 Author Share Posted March 29, 2009 i had to cut the hole in the firewall just to get the engine to fit. i move the axle ahead 1 1/2 inches to clear the oil pan. Link to comment Share on other sites More sharing options...
WyoCherokee Posted March 29, 2009 Share Posted March 29, 2009 Seems like WAY to much work to me. lol. hope it all comes out for you Link to comment Share on other sites More sharing options...
renOnv Posted March 30, 2009 Share Posted March 30, 2009 Good-God :eek: Tell me your going to fabricate your own badging for that beast as well. At this point it seems unfair to give jeep all the credit for this creation. :popcorn: Link to comment Share on other sites More sharing options...
Sir Sam Posted March 30, 2009 Share Posted March 30, 2009 i had to cut the hole in the firewall just to get the engine to fit. i move the axle ahead 1 1/2 inches to clear the oil pan. Ya I had to do the same on mine, I moved the axle about 1 inch further forward, luckily my engine then cleared the firewall with only minor modifications. Link to comment Share on other sites More sharing options...
justinquilliam Posted December 18, 2009 Author Share Posted December 18, 2009 well its been 6 months since i've been able to get back to my project. but i just got my conversion kit to mount the np231 to the t19 and the box for rocks kit for the np231 dana 300 doubler. plus i got my tires mounted on my wheels i powdercoated copper. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 19, 2009 Share Posted December 19, 2009 nice work. you may want to work on that rear lift... Link to comment Share on other sites More sharing options...
justinquilliam Posted December 19, 2009 Author Share Posted December 19, 2009 the rear springs are broke i need to replace them and i'm gonna make the front sit considerbly lower Link to comment Share on other sites More sharing options...
tmanhollister Posted December 19, 2009 Share Posted December 19, 2009 :popcorn: Link to comment Share on other sites More sharing options...
AutoMoto Posted December 19, 2009 Share Posted December 19, 2009 WOW! Is the motor running yet? Link to comment Share on other sites More sharing options...
justinquilliam Posted December 19, 2009 Author Share Posted December 19, 2009 i got it running before i took it out of the scout and made sure it ran good but i havent been able to even think about starting in the comanche yet. i still have a full gasket set to do on it before i fire it back up. Link to comment Share on other sites More sharing options...
