james750 Posted December 27, 2008 Share Posted December 27, 2008 Are there supposed to be 2 speakers behind the cab? There is a vent on the lower b-pillar trim that looks like it is for speakers but on mine there are none there. Thanks, James Link to comment Share on other sites More sharing options...
smartazz19 Posted December 27, 2008 Share Posted December 27, 2008 quick answer.. yup! Link to comment Share on other sites More sharing options...
james750 Posted December 27, 2008 Author Share Posted December 27, 2008 Anyone have the slow answer? I didn't find any wiring or mounts, but I have the base model so was it only offered on higher trim packages? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 27, 2008 Share Posted December 27, 2008 Anyone have the slow answer? I didn't find any wiring or mounts, but I have the base model so was it only offered on higher trim packages? the wiring is tied up to the pillar wires which lead to the dome lights, and the mounts are found few and far between. Link to comment Share on other sites More sharing options...
james750 Posted December 27, 2008 Author Share Posted December 27, 2008 So did the base models not have speakers to begin with or did the PO take them out? EDIT: Also, what size/watt speaker went in that spot stock? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 27, 2008 Share Posted December 27, 2008 So did the base models not have speakers to begin with or did the PO take them out? EDIT: Also, what size/watt speaker went in that spot stock? base likely did not have it. as many have said before though, it's AMC/Jeep...there is no rule set in stone. let's just say that, like as not, there are less jeeps which came with the rear speakers than those which do. I don't remember the size...it is an odd size. 4x3 or some wierd thing like that. watt is whatever $#!&ty stock wattage would be....i toss all factory speakers, regardless of the vehicle or brand. Link to comment Share on other sites More sharing options...
lostissues Posted December 27, 2008 Share Posted December 27, 2008 the stock rear speakers should be a 4x6 size. Jonathan Link to comment Share on other sites More sharing options...
james750 Posted December 27, 2008 Author Share Posted December 27, 2008 I found some stock speakers out of my dads f250, I guess I will wire those in tomorrow. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted December 27, 2008 Share Posted December 27, 2008 I had them (4”x6”) included in my Pioneer package. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 27, 2008 Share Posted December 27, 2008 base likely did not have it. as many have said before though, it's AMC/Jeep...there is no rule set in stone. Exactly...mine is a base model and it has speakers... Link to comment Share on other sites More sharing options...
mvusse Posted December 27, 2008 Share Posted December 27, 2008 My Pioneer had them as well. Or the remains of them as the last 21 years had not been kind to them. I replaced them with a cheap pair off Ebay for the time being. Link to comment Share on other sites More sharing options...
Eagle Posted December 27, 2008 Share Posted December 27, 2008 It all depends on what radio package was ordered. My '88 Chief has them. My '87 Pioneer does not. Link to comment Share on other sites More sharing options...
BREEZE1 Posted December 27, 2008 Share Posted December 27, 2008 i was thinking about doing a little fiberglass work amd making a mold to make some 6x9's look factory.... :brows: I'm getting older and i don't want to have speackers sliding around back there. its all about sounding nice and looking nice too! Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 27, 2008 Share Posted December 27, 2008 I found some stock speakers out of my dads f250, I guess I will wire those in tomorrow. dude, don't cut up the B-pillar trim to fit crappy stock speakers in. find some decent ones, or go without until you can get them, or get some 4x6's and have someone from here send you mounts for them. Link to comment Share on other sites More sharing options...
james750 Posted December 27, 2008 Author Share Posted December 27, 2008 yeah, thats what I am going to do now, I didnt look at how to mount them until this morning, and I definitely don't want to cut up the b pillar trim. Off to Ultimate to get some 4X6s. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted December 27, 2008 Share Posted December 27, 2008 I don’t know if you have a bench seat… If you do, it really doesn’t matter what kind of 4”x6” speaker you use in back as the configuration of the cab and the seat muffles the sound. I would invest more into the front speakers and add some front tweeters. Link to comment Share on other sites More sharing options...
Virginia Posted December 28, 2008 Share Posted December 28, 2008 I need to replace the stock speakers. What would you all recommend? Link to comment Share on other sites More sharing options...
james750 Posted December 28, 2008 Author Share Posted December 28, 2008 got a set of alpine 4X6s for $60. Now I just need to get some mounts. Link to comment Share on other sites More sharing options...
james750 Posted December 28, 2008 Author Share Posted December 28, 2008 I'm thinking that my truck probably didn't have a sound system to begin with as all of the stuff in the front is aftermarket and high quality. But the PO was cheap and lazy and didnt want to buy/install rear speakers. I pulled the lower dash panel today and the tweeters were duct taped in place. :eek: Link to comment Share on other sites More sharing options...
Car RamRod Posted December 28, 2008 Share Posted December 28, 2008 I don’t know if you have a bench seat… If you do, it really doesn’t matter what kind of 4”x6” speaker you use in back as the configuration of the cab and the seat muffles the sound. I would invest more into the front speakers and add some front tweeters. I agree. I was gonna mess with that, but decided it wasn't worth the effort; my front speakers are really plenty. Link to comment Share on other sites More sharing options...
garmj Posted December 28, 2008 Share Posted December 28, 2008 I plan on cutting 5 1/4 holes in the B pillar (metal part) and mounting 5 1/4 speakers there behind the trim and installing speaker grills in the trim panel so they look near factory. :dunno: Link to comment Share on other sites More sharing options...
Pete M Posted December 28, 2008 Share Posted December 28, 2008 I've had several different variations of sound systems in my 88 and the best was a 4way amp powering some quality 5 1/4 + tweeter components in the doors and a small subwoofer behind the passenger seat. Fullrange speakers behind the seats never really did much (even when they were 6x9s being pushed by 75 watts rms) so I eventually dumped them. The 8 inch woofer provides good bass and the door speakers provide excellent sound reproduction. Link to comment Share on other sites More sharing options...
james750 Posted December 28, 2008 Author Share Posted December 28, 2008 yeah, the last guy definitely didn't install the stereo quite right. I noticed today that the passenger speaker in the door doesn't even work right now and the drivers side door speaker only works when the door is closed. The new speakers came with mounts, but IDK if they will work or not. :dunno: Link to comment Share on other sites More sharing options...
james750 Posted December 28, 2008 Author Share Posted December 28, 2008 will all comanches have the wiring for the speakers? Will it always be in the dome light harness? Link to comment Share on other sites More sharing options...
james750 Posted December 28, 2008 Author Share Posted December 28, 2008 I pulled the drivers side b pillar trim off and found old screw holes for the speakers and a connector. Is this the speaker connector/wires, if so, which is positive?Negative? There is a green with yellow tracer and a black with yellow tracer: . Link to comment Share on other sites More sharing options...
