WahooSteeler Posted January 29, 2009 Share Posted January 29, 2009 Don, I was over on jeepforum.com classifieds just sniffin' around and ran across a set of spacers for sale. he also posted a link to the company that machines them. a little late now but they have 1, 1.25, 1.5 and 2" sizes available. http://www.weirdharoldscoolparts.com/new%20page0.htm Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 29, 2009 Author Share Posted January 29, 2009 I saw those Wahoo, but they don't look like they are hubcentric. Sent the guy an email to ask and he never replied. So I went w. the SpiderTracs. Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 29, 2009 Share Posted January 29, 2009 You are correct Don. They are not hub-centric. I had to email them 5 times before he replied. Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 29, 2009 Share Posted January 29, 2009 Good to know. I guess Weird Harold really is weird. I'll be going with SpiderTracs this summer. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted January 30, 2009 Share Posted January 30, 2009 Okay, here's the best I could do mainly because I lacked a good BEFORE pic. BEFORE REAR SPACERS AFTER REAR SPACERS Even so it's pretty easy to see the difference I think. :cheers: Your truck looks good and one of the cleanest i've seen. But, i think i like that narrorer stance. Link to comment Share on other sites More sharing options...
comanche13 Posted January 30, 2009 Share Posted January 30, 2009 i can't see the different i think its cause I'm blinded by the chrome :rotf: Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 30, 2009 Share Posted January 30, 2009 Don, since this whole mod was to satisfy ME, I need you to take a shot from the front looking back. LOL, seriously though, that would be a nice shot to see as it might help answer this question. IYO, are the rears now square with the front or are they a little wider? Or, are they still a little inboard? I'm sure you have nothing to do today, so get to it please. :yes: (You know I'm kidding, right?) Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 30, 2009 Author Share Posted January 30, 2009 Don, since this whole mod was to satisfy ME, I need you to take a shot from the front looking back. LOL, seriously though, that would be a nice shot to see as it might help answer this question. IYO, are the rears now square with the front or are they a little wider? Or, are they still a little inboard? I'm sure you have nothing to do today, so get to it please. :yes: (You know I'm kidding, right?) Yes you crazy bastid. :D Actually the rears are still inboard about 1/4" inboard as compared to the fronts. I cut a straight 1x1 a bit longer than the tire width so I can snug it up to the flare bottom when it is flush w. the tire. The fronts stick out exactly to the outer edge of the flare. I'll get a pic later. :cheers: Link to comment Share on other sites More sharing options...
SuperWade2 Posted February 11, 2009 Share Posted February 11, 2009 Hey Don... I'm getting a pair of the Spidertrax spacers for my Rear End also... MY 29x9.50's on my Gambler Rims already have some "rubbing" on the frame on the driver side. There is only about 1/2"-3/4" gap, max between the top of my tire now and the frame. I'm guessing because of my 5.5" Backspacing on those TJ Gambler Rim's I'm running. I have 31x10.5's on order to get installed later this week or next, but I figured it would be TOO close otherwise. My rear tires are tucked way in the flares now, and I think the 1.25" will help me not rub in the back with the bigger tires and "even" things out. like they did for you. Since I run 4 of them (actually 5 since I needed one to get the spare mounted on my rear tire carrier) on my TJ, having a couple extra in the event of a failure wouldn't be a horrible thing either...just another $100 that I didn't really need to spend. Any update after having them on for a little while now? SW2 Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 11, 2009 Author Share Posted February 11, 2009 Hey Don... I'm getting a pair of the Spidertrax spacers for my Rear End also... MY 29x9.50's on my Gambler Rims already have some "rubbing" on the frame on the driver side. There is only about 1/2"-3/4" gap, max between the top of my tire now and the frame. I'm guessing because of my 5.5" Backspacing on those TJ Gambler Rim's I'm running. I have 31x10.5's on order to get installed later this week or next, but I figured it would be TOO close otherwise. My rear tires are tucked way in the flares now, and I think the 1.25" will help me not rub in the back with the bigger tires and "even" things out. like they did for you. Since I run 4 of them (actually 5 since I needed one to get the spare mounted on my rear tire carrier) on my TJ, having a couple extra in the event of a failure wouldn't be a horrible thing either...just another $100 that I didn't really need to spend. Any update after having them on for a little while now? SW2 Hey Wade; I'm likin' them. Have been hauling 1000 lb. + tile loads the last month or so redoing our house bathrooms and the the spacers really help reduce the body roll w. a full load. I did have some brake squealing shortly after I installed them, but it turned out to be the four year old front disk pads. I replaced them w. non-metallic pads, had the front rotors turned and all is well. Yeah, if you've got frame rubbing now w. 29" tires and your 5.5" BS, 31s will be worse. How wide are your Gambler wheels? You really should have an 8" wide rim w. 31" tires I think. I never had rubbing with my 31s on the 4.5" BS 8" wide Ravine wheels, but the clearance around the rear disk brake caliper was only maybe 1/4"; a bit tight. So the spacers gave me plenty of clearance there, and the tires sit almost square in the flares and the handling is better. Yeah, I'm glad I got them. :cheers: Link to comment Share on other sites More sharing options...
SuperWade2 Posted February 11, 2009 Share Posted February 11, 2009 Hey Don... I'm getting a pair of the Spidertrax spacers for my Rear End also... MY 29x9.50's on my Gambler Rims already have some "rubbing" on the frame on the driver side. There is only about 1/2"-3/4" gap, max between the top of my tire now and the frame. I'm guessing because of my 5.5" Backspacing on those TJ Gambler Rim's I'm running. I have 31x10.5's on order to get installed later this week or next, but I figured it would be TOO close otherwise. My rear tires are tucked way in the flares now, and I think the 1.25" will help me not rub in the back with the bigger tires and "even" things out. like they did for you. Since I run 4 of them (actually 5 since I needed one to get the spare mounted on my rear tire carrier) on my TJ, having a couple extra in the event of a failure wouldn't be a horrible thing either...just another $100 that I didn't really need to spend. Any update after having them on for a little while now? SW2 Hey Wade; I'm likin' them. Have been hauling 1000 lb. + tile loads the last month or so redoing our house bathrooms and the the spacers really help reduce the body roll w. a full load. I did have some brake squealing shortly after I installed them, but it turned out to be the four year old front disk pads. I replaced them w. non-metallic pads, had the front rotors turned and all is well. Yeah, if you've got frame rubbing now w. 29" tires and your 5.5" BS, 31s will be worse. How wide are your Gambler wheels? You really should have an 8" wide rim w. 31" tires I think. I never had rubbing with my 31s on the 4.5" BS 8" wide Ravine wheels, but the clearance around the rear disk brake caliper was only maybe 1/4"; a bit tight. So the spacers gave me plenty of clearance there, and the tires sit almost square in the flares and the handling is better. Yeah, I'm glad I got them. :cheers: Yah the Gamblers are 15x8" with 5.5" BS...so I will be closer to 4.25" BS with the spacers, so should be pretty well set... Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 11, 2009 Author Share Posted February 11, 2009 Yah the Gamblers are 15x8" with 5.5" BS...so I will be closer to 4.25" BS with the spacers, so should be pretty well set... Agree. But be sure to post some pics as directed by Wahoo though, after all this thread is for HIM. :cheers: Link to comment Share on other sites More sharing options...
WahooSteeler Posted February 11, 2009 Share Posted February 11, 2009 Yah the Gamblers are 15x8" with 5.5" BS...so I will be closer to 4.25" BS with the spacers, so should be pretty well set... Agree. But be sure to post some pics as directed by Wahoo though, after all this thread is for HIM. :cheers: Damn straight! Glad we got that cleared up Don. :jump: Link to comment Share on other sites More sharing options...
88MJXLS Posted March 23, 2010 Share Posted March 23, 2010 Okay, here's the best I could do mainly because I lacked a good BEFORE pic. BEFORE REAR SPACERS AFTER REAR SPACERS Even so it's pretty easy to see the difference I think. :cheers: Your MJ looks like it just rolled off the line, wish mine shined like that, looks great!! :yes: Link to comment Share on other sites More sharing options...
kro10000 Posted March 23, 2010 Share Posted March 23, 2010 Sorry I dunno if the original question was answered but... The reason (Ive been told) that the rear tires sit in is to give better highway roadholding while hauling... Makes the truck track straight Link to comment Share on other sites More sharing options...
one_bad_MJ Posted March 23, 2010 Share Posted March 23, 2010 Okay, here's the best I could do mainly because I lacked a good BEFORE pic. BEFORE REAR SPACERS AFTER REAR SPACERS Even so it's pretty easy to see the difference I think. :cheers: Your truck looks good and one of the cleanest i've seen. But, i think i like that narrorer stance. wider looks better Link to comment Share on other sites More sharing options...
DJM/78 Posted March 23, 2010 Share Posted March 23, 2010 The tires do show their teeth a bit more , I think its an improvement over a stock BS any day . Mine rides great with 4" BS wheels . Link to comment Share on other sites More sharing options...
jpnjim Posted March 23, 2010 Share Posted March 23, 2010 the rears are inboard to help with turning, it helps the rear track inside the front and tighten up the radius, but I doubt if you will notice too much of a difference. Weird. I had an 01 XJ I bought new, and the wheels were equally spaced in the wheel wells. So the rears being more inboard than the fronts is an MJ thing? Mine's a LWB; is it same thing w. the SWB MJs? :hmm: Sorry I dunno if the original question was answered but... The reason (Ive been told) that the rear tires sit in is to give better highway roadholding while hauling... Makes the truck track straight There may be some complicated reason Jeep wanted the rear track width narrow compared to the body, but I think it was very simple. XJ's, MJ's, ZJ's & YJ/TJ's all have different size bodies, and different overall widths at the wheel wells, but they all use the same exact width ft & rear axles (& interchangeable shafts). When they wanted to make a pickup truck, they wanted the bed wide enough to be useful, but didn't want to go all the way, and create a unique width rear axle, so they compromised, and the result tucked the wheels a little further into the flare then the tires on XJ/ZJ/YJ & TJ's. :smart: That's my story anyway. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 23, 2010 Author Share Posted March 23, 2010 I think Jim hit the nail squarely on the head. :cheers: Link to comment Share on other sites More sharing options...
Pete M Posted March 23, 2010 Share Posted March 23, 2010 yup. MJs just have a big butt. :D Link to comment Share on other sites More sharing options...
kro10000 Posted March 24, 2010 Share Posted March 24, 2010 I considered that, but... This isnt strictly an MJ thing, i see it on a lot of other trucks, my dakota was the same way Link to comment Share on other sites More sharing options...
Pete M Posted March 24, 2010 Share Posted March 24, 2010 It's true that other trucks have a wider front axle than rear. they say it helps in handling. makes it look even worse looking when you swap a ford 44 and 9" under your MJ. :( Link to comment Share on other sites More sharing options...
kro10000 Posted March 24, 2010 Share Posted March 24, 2010 wait this all makes sense now :dunce: Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 24, 2010 Author Share Posted March 24, 2010 As stated before, the OEM MJ front/rear axle track dimension is identical. If you have excess weight hanging out over the rear axle wheel centerline, there's no way that can help handling. It just creates oversteer. Makes no sense at all to moi. Link to comment Share on other sites More sharing options...
spence Posted March 25, 2010 Share Posted March 25, 2010 I have personally used the Spydertrax for several years on my XJ's running 15x12 MT classics, shoed with 33x12.5 Mud Grapplers. Torqued them to 90PSI and never had ANY problems with loosening, even at 90MPH on the road or blasting through the swamp. Just make sure you get all the crud off of the hub mounting surface first. Link to comment Share on other sites More sharing options...
