one_bad_MJ
Everything posted by one_bad_MJ
Fuel gauge started playing games! Usual suspects?
one_bad_MJ replied to Jerry's topic in MJ Tech: Modification and Repairs
my fuel light will turn on at 1/4 tank then it drops more then it will be serious and be low fuel whats up with that -
rear wheels lock up when i hit the brakes ?!?!
one_bad_MJ replied to one_bad_MJ's topic in MJ Tech: Modification and Repairs
i wish there was a fix because one day they locked up when i braked for a red light and i was all over the road every which way but upside down -
my 89xj did it to sometimes also -
Dicks New to Me MJ Build
one_bad_MJ replied to dick.breakey's topic in Member Projects: Your Comanches
Liggets auto up here in homer city has 4 comanches for parts if your looking for some. they have a ton of cherokee's also. -
does this look normal?
one_bad_MJ replied to comanche12's topic in MJ Tech: Modification and Repairs
mine looks like that also. my coils are mega bowed out. and my jeep has a gangsta lean to it. if you turn the wheels while sitting there it will level and lean to the other side. i have drop brackets so i doubt my caster is wrong. -
no leaks. rear pads do need changed but no mechanical issues hat i can see. post a pict of this rear porp valve. someone has a T where the lines goes from the front to the rear and it t's back tot he front maby it was there and they deleted it. -
well my rear wheels lock up when i hit the brakes, what causes that. the other day i was going up 119 and it was wet out and it happened i fish tailed and spun out on the highway lucky no one was around. and when i leave my house in the morn after it sits all night my first stop sign the rear tires lock up and drag.
it will be fine. just drive it i drive mine all over pa and ohio and it hasn't let me down
eh no one cares.. @#$% it.
anyone on here have a black comanche short bed lifted with VA or NC plates?? if so i seen ya and i would like to do some wheelin. I'm guessing a wyotech'er
like i said to each his own. but in the long run there all @#$%ing junk and ive worked on like 50 of them and hated every minute of them. you better get a sponsor by penzoil because they leak oil like a siv
haha thats as bad as slowboyracing building a 30,000 evo and they toss it on the dyno with no oil in it. haha i was there that day it was funny. anyways when your 4G63 POS dsm breaks again check out our website. http://www.cimotorsports.net low prices fast shipping tell me why anyone takes a fresh engine to the dyno anyway? slowboyracing because ther idiots i didnt work for them so don't think that. www.cimotorsports.net is our shop
haha thats as bad as slowboyracing building a 30,000 evo and they toss it on the dyno with no oil in it. haha i was there that day it was funny. anyways when your 4G63 POS dsm breaks again check out our website. www.cimotorsports.net low prices fast shipping
sorry about your luck. 1g dsm's are the biggest piece of fukin junk there is that turbo is a Chinese tdh05 knock off of a real 16g i give that 200 miles before the seals blow. i mean to each his own man but you couldn't give me a dsm. there garbage. 6 bolt or 7 bolt crank. both crap and they crank walk due to thrush bearings wear out. i hope you well but in the long run all its going to do is leak oil and blow up non stop.
88 Comanche going to 3.2L turbo diesel
one_bad_MJ replied to justinquilliam's topic in Member Projects: Your Comanches
haha yeah justin isnt the altezza kinda guy. i would see him smashing them before he installed them on his jeep. -
justin i want those 98 cherokee doors!!! call me i will swing by tonight and see how its coming along. its susposto rain so i doubt i will be fishin -
slotted rotors and mud do not mix it will eat your pads right out. I'm just sayin.
....getting the response "when did jeep make a tuck?" and thats a xj cut down and the best one of all. my xj can go through that hole. or climb that hill well half way in/up no luck the general went right through it and right up it. honestly it goes better then my samurai i really enjoy this 30mpg truck on 33's :) saves fuel for road trips to buy stuff and great daily driver plus its a mid size not a death trap samurai that weighs 3 ounces and can't drive on snowy roads due to 360* spin outs non stop
that response there ^
Its the SD33 also the diesel engine used in scouts. Its a good engine, you might be able to find the turbo setup for it online. do you mean this engine viewtopic.php?f=7&t=14123
x2 i need to stop up this weekend and check it out is it running yet? -
justin no updates or picts??? letting us down here ... -
nice mj are those quick disconnects rough country? if so mine are a b*@$£ to get back on did you have any problems?
Bump justin call me friday night we can pull that motor back out ive been busy as hell this week and I'm guessing you are also with work -
screw that get a handgun
