MancheKid86 Posted August 27, 2010 Author Share Posted August 27, 2010 gave her some pin stripes Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 29, 2010 Author Share Posted August 29, 2010 tried to fix my gas gauge today, checked the pins, and grounds, here's what i found before tail light off ground had to use a easy out dead center :) p/o when he painted didnt leave a clean surface for a ground all cleaned up installed light back on and the final result what next? :hmm: Link to comment Share on other sites More sharing options...
Unglar Posted August 29, 2010 Share Posted August 29, 2010 Assuming you have a full tank, I hope you find a solution because I have the same problem in my '92. :popcorn: Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 2, 2010 Author Share Posted September 2, 2010 i fixed it, i know what the problem is, when the p/o painted, the ground wasnt good, the gauge stopped at what his tank was at, and then since the ground was fixed, it reads 3/8th's of a tank full for a full tank, so i need to move the needle, and now to the bad stuff things have taken a step back in my build so... what would you guys do :???: Link to comment Share on other sites More sharing options...
Automan2164 Posted September 2, 2010 Share Posted September 2, 2010 Cab looks pretty good. I would take a pic square, from each side, front and rear, and post that question again in the pub. I think its save-able. Next question is, what the hell were you doing? Rob L. Link to comment Share on other sites More sharing options...
freakjeep93 Posted September 2, 2010 Share Posted September 2, 2010 first off glad yor alright. secondly. how in the hexk did ya manage that one. id fix it if the inner fender isnt to FUBAR but from the pics it looks like it migth be. take the drivers fender off if you an. then youll know what ya got. Link to comment Share on other sites More sharing options...
Darren Posted September 2, 2010 Share Posted September 2, 2010 More pics of the girl. :brows: Link to comment Share on other sites More sharing options...
comenschen Posted September 2, 2010 Share Posted September 2, 2010 She doesn't look too impressed! Kinda of an "I told you not to drive up that" look. Cut out all the bent stuff and tube/truggy it! Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 2, 2010 Author Share Posted September 2, 2010 haha and if my gf was in the truck she woulda killed me XD :yes: Link to comment Share on other sites More sharing options...
terrawombat Posted September 2, 2010 Share Posted September 2, 2010 Personally, I think that truck is donezo Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 2, 2010 Author Share Posted September 2, 2010 lookin that way, thinkin about strippin it for parts, and buying another comanche :shake: Link to comment Share on other sites More sharing options...
comenschen Posted September 2, 2010 Share Posted September 2, 2010 With all that sheetmetal cut away, you could fit some nice big tires on it! :yes: Truggy it, and send me your tailgate...I gots none! Link to comment Share on other sites More sharing options...
kastein Posted September 2, 2010 Share Posted September 2, 2010 Looks like the A-pillar is fine, roof is fine, back of cab is fine, etc... ... unless the frame rails are really badly tweaked up past the motor mounts I would rebuild it, you can get the inner fender walls off any XJ at the junkyard with a sawzall and weld them onto yours. The rest is bolt on. Link to comment Share on other sites More sharing options...
mvusse Posted September 2, 2010 Share Posted September 2, 2010 Take the sawzall and salvage the back half as a trailer. Then paint it to match your new MJ. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 2, 2010 Share Posted September 2, 2010 it's fixable. tough, but fixable. Link to comment Share on other sites More sharing options...
wannabeMJ Posted September 2, 2010 Share Posted September 2, 2010 totaly fixable, uts just the front end get a chero and cut the front off you can cut the soptweld on the fire wall to take everything off if the frame is twised a bit call a good welder and get it plated at the same time he fixes it ........ Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 4, 2010 Author Share Posted September 4, 2010 not fixable, its a write off, will never be able to drive it again, entire drive train is forsale, same with my LB factory rollbar Link to comment Share on other sites More sharing options...
wannabeMJ Posted September 4, 2010 Share Posted September 4, 2010 sad to ear but................ how much for the roll bar mouhahahaha Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 4, 2010 Author Share Posted September 4, 2010 still figuring everything out yet :thumbsup: here's what is looks like before the deconstruction (and yes there is a crack in the windshield, you just can't see it) Link to comment Share on other sites More sharing options...
Unglar Posted September 5, 2010 Share Posted September 5, 2010 Bummer, glad your okay! You didn't mention how that happened? :shake: Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 6, 2010 Author Share Posted September 6, 2010 usin my clutch to drift around corners going up/down a mountain, lost it around the last corner, locals seen the pics and knew exactly where i was, said it was a really bad corner, (iffy grade as well)' lmao, i also forgot to mention i was 23 days away from getting my license, now i have a 6 month suspended license and then i get to start my learners (for a year) all over again :wall: :fs1: :headpop: Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted September 6, 2010 Share Posted September 6, 2010 ouch! Link to comment Share on other sites More sharing options...
freakjeep93 Posted September 6, 2010 Share Posted September 6, 2010 usin my clutch to drift around corners going up/down a mountain,lost it around the last corner, locals seen the pics and knew exactly where i was, said it was a really bad corner, (iffy grade as well)' lmao, i also forgot to mention i was 23 days away from getting my license, now i have a 6 month suspended license and then i get to start my learners (for a year) all over again :wall: :fs1: :headpop: you mean you only had your beginners permit... or you were 23 days away from getting your full license? Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 6, 2010 Author Share Posted September 6, 2010 i had my learners XD and i wasnt with somebody the age over 25 Link to comment Share on other sites More sharing options...
Rymanrph Posted September 6, 2010 Share Posted September 6, 2010 i had my learners XDand i wasnt with somebody the age over 25 I have a feeling if you did have this person, you might not be in this situation. :no: for breaking the law. Next time, keep it between the ditches. Good luck on whatever you're going to do with it. Link to comment Share on other sites More sharing options...
