500 MJ Posted October 17, 2008 Posted October 17, 2008 Hey All, I was reading my new issue of JP (November 2008) today and saw the article on page 66. It talks about the leaky fuel injectors that are starting to show up on Renix era engines and lists some part numbers (Bosch PN 02801580444) to replace them with. First off, what are your thoughts on this whole deal. I know that none of them on my two MJs are leaking at the moment... Second, If I do decide to go spend the $$$$ on 12 new injectors I'd like to try and "buy them in bulk" if there is any way to do so - considering when you buy them at the parts store, it is peacemeal and all. Do you guys know of any place that sells injectors "in bulk" or a good place online to get THESE injectors at? ( I know some people get the "aftermarket" high flow ones, not interested in them per say, I like my gas consumption just the way it is ;)) Thanks- Brent
Oizarod115 Posted October 17, 2008 Posted October 17, 2008 i got 6 injectors from five-o motorsports online, i think it was in the neighborhood of 200 bucks maybe 225? theyre a 19lb/hr bosch piece from some year 5.0l mustang. i had to crap on me at the same time and my brother had 1 or 2 leak on his as well... i would wait til they actually leak. its not a major repair... maybe about an hour with a couple snacks in there.
SoloCamo Posted October 17, 2008 Posted October 17, 2008 Can you clearly tell they are leaking besides the obvious way of physically seeing it on the outside? I've got a feeling one or two more of mine are on the way out, as I had one replaced when I picked up it.
ComancheKid45 Posted October 17, 2008 Posted October 17, 2008 Search for "Precision Injectors" on the forum......you can get a set of 6 for just over $100
BLHTAZ Posted October 17, 2008 Posted October 17, 2008 The Ford Motorsport injectors (that you have obviously seen me promote on here) actually improve MPG. They are not "high flow"...just better spray pattern and flow matched. Definitely an improvement over the stock ones and MUCH better priced than the ones from five-o ;) . http://www.precisionautoinjectors.com/p ... roductId=7 I know this isn't what you are asking about, but I just don't see any reason to get the others when these are so much better. I definitley recommend them over using even original MOPAR injectors. You also get a 10% discount when you use the word "JEEP" as a coupon/discount code ;)
jtdesigns Posted October 17, 2008 Posted October 17, 2008 The Ford Motorsport injectors (that you have obviously seen me promote on here) actually improve MPG. They are not "high flow"...just better spray pattern and flow matched. Definitely an improvement over the stock ones and MUCH better priced than the ones from five-o ;) .http://www.precisionautoinjectors.com/p ... roductId=7 I know this isn't what you are asking about, but I just don't see any reason to get the others when these are so much better. I definitley recommend them over using even original MOPAR injectors. You also get a 10% discount when you use the word "JEEP" as a coupon/discount code ;) I got a email from that guy the other day, not a bad deal,, just I's to poor right now.. He said he would be moving back to Fl in a few months Brent.
BLHTAZ Posted October 17, 2008 Posted October 17, 2008 He said he would be moving back to Fl in a few months Brent.Cool...I gotta give him a call soon...thanks :cheers:
jbhill Posted October 17, 2008 Posted October 17, 2008 next time your at the junkyard, snag some from an older ford v6. i think yellow is the color for 19 lb low impedence(bigger,older style) injectors. as newer fords have high impedence with a diff. connector. or buy a set for a v8 and have 2 extra lol. [/img]
MiNi Beast Posted October 17, 2008 Posted October 17, 2008 sure you may not need to just change out the o-rings? When mine leaked I changed out the o rings and that cured the leak. Unless you can see it physically leaking out the top part of the injector, (body), then hit up... http://www.precisionautoinjectors.com/c ... tegoryId=2
BLHTAZ Posted October 17, 2008 Posted October 17, 2008 Yeah...you don't want to get them from a JY...you just get the same junk that you already have.
SoloCamo Posted October 17, 2008 Posted October 17, 2008 The Ford Motorsport injectors (that you have obviously seen me promote on here) actually improve MPG. They are not "high flow"...just better spray pattern and flow matched. Definitely an improvement over the stock ones and MUCH better priced than the ones from five-o ;) .http://www.precisionautoinjectors.com/p ... roductId=7 I know this isn't what you are asking about, but I just don't see any reason to get the others when these are so much better. I definitley recommend them over using even original MOPAR injectors. You also get a 10% discount when you use the word "JEEP" as a coupon/discount code ;) How about power and throttle response? I'm assuming with the better pattern response should have shot up a bit?
BLHTAZ Posted October 17, 2008 Posted October 17, 2008 Yep...definitley helped mine and a few others on here have said the same.
Eagle Posted October 17, 2008 Posted October 17, 2008 sure you may not need to just change out the o-rings? When mine leaked I changed out the o rings and that cured the leak. Unless you can see it physically leaking out the top part of the injector, (body), then hit up... There are two possible places where they leak: (1) the O-rings, and (2) the connection between the metal portion of the body and the plastic portion. If the metal-to-plastic bond lets go, there is no possible repair. This is not a new problem. I watched an XJ burn up in front of my then-GF's house ten years ago, and a couple of years after that a friend in NAXJA knew his injectors were leaking but drove his MJ to the dealership to buy new O-rings. He walked out of the parts department to find his truck in flames.
603Redneck Posted October 17, 2008 Posted October 17, 2008 sure you may not need to just change out the o-rings? When mine leaked I changed out the o rings and that cured the leak. Unless you can see it physically leaking out the top part of the injector, (body), then hit up... There are two possible places where they leak: (1) the O-rings, and (2) the connection between the metal portion of the body and the plastic portion. If the metal-to-plastic bond lets go, there is no possible repair. This is not a new problem. I watched an XJ burn up in front of my then-GF's house ten years ago, and a couple of years after that a friend in NAXJA knew his injectors were leaking but drove his MJ to the dealership to buy new O-rings. He walked out of the parts department to find his truck in flames. OUCH! now THAT is a kick in he @$$!
Eagle Posted October 17, 2008 Posted October 17, 2008 OUCH! now THAT is a kick in he @$$! Oh, yeah. Most definitely. This is NOT something to take lightly. If your injectors are leaking, do NOT drive the vehicle. Do not even start the engine. The fuel from the leaking injectors drips onto the hot exhaust manifold and ... POOF! Crispy critters and roasty toasties. If you think you smell gas around the front of the vehicle ... open the hood and find out where it's coming from before you allow the truck to self-immolate.
Pete M Posted October 17, 2008 Posted October 17, 2008 And always carry an ABC rated a fire extinguisher.
jtdesigns Posted October 17, 2008 Posted October 17, 2008 I burnt my first XJ down because of a leaking injector.. no fun.. I burnt my hand on the hood trying to get it lifted to spray the extinguisher too.. Didnt help much she was up and wasnt really anything to do about it.....
BookspanS Posted October 17, 2008 Posted October 17, 2008 Fter my dad caught my engine on fire, I now have an ABC extinguisher behind both my seats....just in case of the worst-case-scenerio ;)
