robfg67 Posted September 17, 2008 Share Posted September 17, 2008 Ok, this is not a big project, but here it is... I recently swapped-out the valve cover gasket with the Fel-Pro product. Let me say that this is a quality product and strongly recommend it. Here is picture of the inside of valve cover gasket. I guess this is what 200K miles worth of crud looks like: I ended up cleaning the baked-on crud off the inside of cover including disassembling the two port elements-unfortunately I neglected to snap a picture of the clean cover. I used a piece of cardboard to keep track of the position of each bolt: Exposed head-fortunately no surprises here: Valve cover painted with heat resistant paint: Head with gasket installed: Painted valve cover installed. Its black-does that mean I have the 190 HP HO engine now? Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 17, 2008 Share Posted September 17, 2008 thats not gunky at all. pretty clean i'd say. hopefully she won't leak Link to comment Share on other sites More sharing options...
Akula69 Posted September 17, 2008 Share Posted September 17, 2008 I had to go after the inside of mine with steel wool and kerosene to clean it up. Yours looked great compared to mine. Link to comment Share on other sites More sharing options...
mvusse Posted September 17, 2008 Share Posted September 17, 2008 :agree: I cleaned mine using a wire brush and gasoline twice before I called it a day. Afterwards it looked almost as clean as yours inside. Link to comment Share on other sites More sharing options...
camjeep3 Posted September 19, 2008 Share Posted September 19, 2008 after an hour of cleaning or so mine finally looked that clean. Link to comment Share on other sites More sharing options...
KillerCOM Posted September 20, 2008 Share Posted September 20, 2008 that's why i love having open access to bead blaster... :chillin: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 20, 2008 Share Posted September 20, 2008 that's why i love having open access to bead blaster... :chillin: haha. yep, 10 minutes scraping, 20 minutes blasting, 15 min. painting, 10 min. sanding. end result. Link to comment Share on other sites More sharing options...
zjrog Posted October 25, 2008 Share Posted October 25, 2008 Those rocker arms don't look to badly discolored. On the motor I just did the headgasket on, the rockers were kind of rough in texture. Like it had been run hot and low on oil frequently in its past. 199,900 miles and counting... Looks like I really need to consider rebuilding the motor from the parts rig to have on hand when the motor in my 90 finally craps out. The parts rig had 220,000 miles under it. Link to comment Share on other sites More sharing options...
IDXJ Posted November 4, 2008 Share Posted November 4, 2008 I found for cleaning baked on oil and grease that oven cleaner works well. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 6, 2008 Share Posted November 6, 2008 haha. yep, 10 minutes scraping, 20 minutes blasting, 15 min. painting, 10 min. sanding. end result. Ugly Pat. Not the valve cover, the pic. I'm geting ready to redo mine - can you focus the pic a little better? Link to comment Share on other sites More sharing options...
jtdesigns Posted November 6, 2008 Share Posted November 6, 2008 Sand blasted... twice.... primed,wet sanded, then totally cheeped out and used a spray can :doh: came out good,, need to re-do with some good paint though.. Tried to buff it with some compound,, spray paint don't likey compound... :doh: :doh: before the rub down. still looks good though here's a prelude VC I did.. toot,toot...... Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 6, 2008 Share Posted November 6, 2008 Thanks JT - but your pic taking skills need work too, like mine. :D Reckon that Honda cover might fit? Oh, 4-banger, never mind. Looks great though. I'm going to have a friend powder coat mine w. the cover the same (or close as I can find) same as my body color, w. polished ribs. I'll do the prep, and the finish. Here's the prep so far on a spare: Image Not Found Link to comment Share on other sites More sharing options...
jtdesigns Posted November 6, 2008 Share Posted November 6, 2008 Thanks JT - but your pic taking skills need work too, like mine. :D Reckon that Honda cover might fit? Oh, 4-banger, never mind. Looks great though. I'm going to have a friend powder coat mine w. the cover the same (or close as I can find) same as my body color, w. polished ribs. I'll do the prep, and the finish. Here's the prep so far on a spare: Image Not Found Looks good so far... I took a die grinder and hit a bunch of spots on my VC. It had alot of burs and flashing on it from casting. The polishing is pretty easy on aluminum I just keep going up in grit starting with 320 till about 1200 then used mothers and a old t-shirt. Oh and those (well most) of my pictures are taking with a phone= $hitty pics.... I found a place near me that does powder coating, but cost is lil too much. I wonder how hard it is to match colors with powder.. I want to get all my window trim pieces PC'd gloss black, and a set of wheels,,, unless I come across some chrome ZJ ones!! :brows: Oh by the way did I tell you suck??? :rant: Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 6, 2008 Share Posted November 6, 2008 Oh by the way did I tell you suck??? :rant: I think you did - several times. :D :cheers: Link to comment Share on other sites More sharing options...
mvusse Posted November 6, 2008 Share Posted November 6, 2008 You can do your own powder coating on small pieces using a regular kitchen over. Just don't use THE kitchen oven, though :roll: Buy a cheap used on at a garage sale or some place and put it in your garage. Link to comment Share on other sites More sharing options...
