6
Everything posted by Limeyjeeper
Comanche Wildernest Trailer project
Limeyjeeper replied to Strokermjcomanche's topic in Member Projects: Your Comanches
Awesome. What is the axle under the trailer. Looks like it fits perfectly? -
1994 engine = 1" crank bore 1994 AX15 = 3/4" diameter input shaft If yours match these measurements you will need Novak Part No PB2001295. The year of the truck is irrelevant if the complete drivetrain is a 94 it is easy. If your crank bore is 1 1/16" then you have a pre 92 engine or crankshaft. If your AX15 input shaft is 19/32 then it is a pre 1992. Novak has a pilot bearing for any combination of sizes. When I did my AX15 conversion on my stroker they came to the rescue as my crank was early and the AX15 was a 1998.
Comanche Dawn
Limeyjeeper replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Wipers are working. Delay module swap did the trick. The little victories...... -
Novak has some great info on all the various pilot bushings and sizes. Finding pics of bushings is tough. They have all the measurements. https://www.novak-adapt.com/catalog/pilot-bushings/amc-ax15/
Team Cherokee timely response?
Limeyjeeper replied to 87MJJeep's topic in MJ Tech: Modification and Repairs
I have bought a ton of stuff from them over the years. I think sometimes the shipping is slow because they have to order the part, even though they say it is in stock. Particularly Mopar OEM stuff. Can't comment on their customer service as I have never used it. However they are pretty liberal on their definition as to what years an item fits. Sometimes it is completely wrong. -
another another another another another JEEP TRIP
Limeyjeeper replied to krustyballer16's topic in The Pub
I would go to the Corvette museum in Bowling Green,(a bit off course but a pretty impressive place even if you are not a Corvette lover). Wellborn MuscleCar Museum is really good. Out of your way a bit in Alexander City. Lane Motor Museum in Nashville has a bunch of quirky, mainly European vehicles. -
I have always run Amsoil Z-Rod in my strokers. Has zddp in it too. Works well. 10w30.
88 MJ Rear Main Seal
Limeyjeeper replied to Rotten Ralphy's topic in MJ Tech: Modification and Repairs
All 4.0 engines including your 1988 have a 2 piece rear main seal. I would use a Victor Reinz seal part no 191006301. They improved the design a bit. -
Rockauto.com. $46
Unlike the White Supremacists who are just sitting at home making lego White Houses. Really, I deal with this stuff everyday. Yes the left are instigating so are the white supremacist cops and others. This country is tearing itself apart and what is so sad is we condemn the Communist Chinese for cracking down on the Hong Kong people who just want justice and democracy but the images from this country look eerily similar. This is a lot more sinister and widespread than Antifa. This is becoming Germany in 1932. Same MO, deflection, find a bad guy to target, discredit the media (who are far from perfect) and watch how the sheep buy into it. It is a pity most of us have no clue about European history. If we actually read about the rise of Fascism in Germany, the signs are eerily similar.
Comanche Dawn
Fighting through the wiring. Figuring out really quick how inaccurate Jeep wiring diagrams are. All LS wiring looks good. No voltages where they shouldn't be. Headlights, taillights, turn signals, backup lights, fogs, high beam all good. Brand new Standard Products headlight switch lasted about 8 hours. Got a Mopar one on order. Why do we think the Chinese can build anything that has even remotely good quality? Got an issue with the wipers. Only working on high speed. Gota be the delay module Instrument panel working well. All gauges except tach and speedometer working. Can't test those until I fire the motor. Interior lights coming on with headlights grrrr. Just gotta keep maintaining my patience. I will get to the bottom of every issue. It is just so time consuming. However with so much new and modified wiring I am not naive enough to think it would be perfect. I would just like to thank who ever invented the power probe. Pure genius. -
Comanche Dawn
I had to notch the hidden bumper mount. I still need to notch the Front bumper -
Comanche Dawn
I took a piece of 1/2 x 1/2 aluminum and cut one side in four places so I could bend it to contour the door frame. I then drilled holes to match the existing holes in the door frame. I used plastic retainers to hold the strip. At the top it is very tight so I clipped one side off the top of the retainer so the hole could be tight up against the bend on the aluminum angle. You need enough space for the back of the trim. Also because the retainers have a low profile it let's the seal sit down properly on the aluminum edge. -
Comanche Dawn
Another month and she will be running....Dealing with a $#!& load of electrical issues. -
Comanche Dawn
Refurbished the wipers with a new motor and bushings and reinstalled them. Had to change the motor connector with a Deutsch connector as my harness and motor had different plugs. Also decided to upgrade the secondary door seals to the 97+ version. They are much more substantial and should help reduce the door pillar noise. Had to mount a 1/2 x 1/2 strip of aluminum on the A Pillar. Then mounted the seal. It is basically the same as the door seal. Front Clip is on. Just waiting on the "Jeep" sticker for the Front Clip from Spencer PRP seats in final installed position. Haven't fully locked in the dash in case I need to get to the harness. Engine fully buttoned up. Next job testing the wiring harness then exhaust. Once that is done she will be ready to fire up. Getting closer.... -
Wiring Harness- Options?
Limeyjeeper replied to Runninn's topic in MJ Tech: Modification and Repairs
Or let Aeromotive rebuild it. Not sure what they would charge. https://aeromotive.us -
Rubber Windshield Molding
Limeyjeeper replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
I have a 91 and fitted a new Mopar one with no issues. -
interior arm rest fix
Limeyjeeper replied to 70barracuda's topic in MJ Tech: Modification and Repairs
You need part no 6502112 armrest screw retainers. That holds the armrest to the door panel with a screw. They get worn and loose. Team Cherokee has them. About $4 for one armrest including the screw. Very common problem -
Here is the parts page for the 97 XJ steering column. Not seeing that as a separate part. 1997 XJ Steering Column Parts.pdf
