ComancheKid45
    3
Everything posted by ComancheKid45
  1. A Worn out coupling in the front Driveshaft can cause vibration as well....along with a squeaking from the front wheels
  2. Hey man you got 1 helluva Fan right here! ....lol
  3. Start of the Muddest Race of my career so far.....3/11/2007 (I'm on the right)
  4. Did you have the TPS off by any chance?
  5. My 88 has 173xxx on it but had a new motor swapped in at 140774
  6. slight TPS adjustment and a new O2 sensor......all is good now! :D
  7. Ok after alittle research the signs now point to the EGR.....ill dig into it at work later today
  8. My Truck has begun to act up again, i don't have enough time to type a report at the moment but I'm pretty sure its a TPS problem again, i had the thorttle body apart and cleaned it this weekend.....for now though what are some tell tale signs of a TPS issue? Truck is an 88 4.0 Automatic Thanks
  9. The new 4.0 V6 ive only seen in the new Minivans....it is out there though
  10. So is it likely the Factory axle under my 88 is a Dana 35??? I'm looking at getting a new cover b/c the fill/inspection plug in mine is seized and its an excuse 2 upgrade
  11. I'm more into MX vs ATV and Nascar games 8)
  12. I used to have the "Monster" 1 but I lost it, ive never heard of the other
  13. I found these the other night and thought they were pretty cool 8)
  14. I have the same mirrors on mine as well
  15. Stay away from the 6.7.......So far theyve been nothing but trouble in my Dealership, 2 much Emissions crap happening
  16. Ok.....i just think its an issue with wires near the taillights and around the rear bumper.....somethings shorting out and it just occured today, ill see what i can find tomarrow...thanks
  17. Ok....but what about wires in general.....just having the wire coated in ice and being froze to a ground, would that cause it as well?
  18. Brake Lights were operating fine all day, theres been snow on the ground the past 2 days and just tonight ive started blowing fuses for my Hazard/Stop lamps.....i noticed alot of ice buildup around the wires for my taillights.......I'm keepin the MJ in the garage tonight to let it thaw a bit and hopefully tomarrow i can find the problem but is the frozen wires a possible cause?....thanks
  19. 1st Vehicle was my current MJ, been driving it since i was 16 and 1st got my license, Ill be 21 in February and still love jumping in the Truck everyday 8)
  20. Has anyone had any luck in locating a scale model yet? :hateputers:
  21. Na its all good info/stories......don't bother me none ;)
  22. Replaced the front Drive shaft assembly today.....problem solved :D
  23. That most likely what I'm going to do......how complicated does that process become?
  24. Alright this has been bugging me for about 2 months, at speeds between 0 and about 25 theres a fairly constant squeak coming from the area where the front driveshaft connects and enters the transfer case, after i get over 25mph it goes away, ive tried greasing and lubing everything around there but it won't vanish so now its time for some more professional advice.......thanks for any help
  25. I'm diggin the Kyle Petty sticker :D Big Fan here
