MJohnny
MJohnny's Achievements
  1. MJohnny
    pump operators
    i was just wondering to see how the market s else where
  2. MJohnny
    pump operators
    hey yall is any body else on here a concrete pump operator
  3. check the green fusible link it is located near where you saw te smoke this happened to me on my auto when i applied the e brake
  4. wuts the back spacing thanks
  5. what are the specs on your wheels and tire "SUMMER TREAD" Thanks :cheers:
  6. MJohnny
    kia sportage
    its just for my wife no plans to mod in any way just want something reliable and small for her
  7. MJohnny
    kia sportage
    does any 1 here own a sportage what r ur thoughts on it plan on selling a dodge stratus to get a 02 sportage w/ 45000 on odo for the wife what do yall think
  8. MJohnny
    my mj
    well actually i have put 18v on it it runs on 12v i used another battery from the harley they have it has 2-6v batteries all it did was spin tires like crazy cause they are plastic
  9. MJohnny
    my mj
    I'm in san antonio tx
  10. i will be getting a front axle to make my mj 4wd from pnp how can i test the axle to make sure its good thanks in advance
  11. MJohnny
    my mj
    1990 eliminator 2 wd for now 4.0 AW4 260,000+ 95 brake booster, mc, and xj prop valve on the side is my DD I've had the mj 5 yrs. just barely now i have some cash and time to work on it how do you edit the sig and avatar
  12. sorry to jack the tread where r the pics of your new clear corner lights
  13. MJohnny
    my mj
    here's a pic of my $600 MJ my 2 boys jeep
  14. what about the adjustable rod in between the master cylinder and the booster
  15. i did the up grade with a 95 booster and mastercylinder on my 90 MJ I used the original pedal the only problem is that the pedal travels 60 % before i feel the brakes. it stop great though after that any suggestions. :cheers: Thanks for all the info on the upgrade :bowdown: [/b]
