6
Everything posted by krustyballer16
24.5" at this body line. Should be able to compare to your long bed.
Finally figured out my "no clutch" problem after almost a month, and a new slave cylinder and new clutch! My clutch pedal was broke! This is after my dad bent it back straight. The pedal arm was bent in almost a 90. It cracked right below the factory weld and when he pushed it down originally, it stayed on the floor but the arm to the master cylinder came back up. It was actually working, just not with the pedal...[emoji58] We warrantied everything out (even though it had been 4 years since I bought it all) So now everything is brand new even though the old stuff was only 17,000 miles old...Yay!
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Krustyballer Fabrications
krustyballer16 replied to shelbyluvv's topic in Vendors- members making products for MJs
SALE! $20 OFF! Jeep Comanche hitch. Was $190+shipping. NOW $170+shipping! $20 OFF! Set of Jeep Comanche sliders with tube step. Was $280+shipping. NOW $260+shipping.(Currently don't have the step plates on them but can be added for $40 more.) Buy hitch and sliders and save additional $10! That's $50 savings! I ONLY HAVE 1 OF EACH. SO FIRST PERSON TO WANT/PAY FOR THEM GETS THEM AT THIS PRICE!- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I'm with you on the BerenstEin Bears thing And all the door jambs, underside of the hood and bed and inside panel of the doors and ALL the body work was done in my parents little 1 car garage. It sucked.
Well come to find out the new slave cylinder we put on wasn't any good. Got a 2nd replacement...but we had already dropped the tranny to look at the clutch. Couldn't find anything wrong with it. BUT, the pilot bearing came out with the tranny. When they machined my flywheel adapter, the bearing wasn't tight in it. So we used shim paper and that didn't hold. But the bearing wasn't going to come out so we left it. Well 17,000 miles later and a lot of spinning, and it has wore a groove in the adapter. So we took it off and I ordered a pilot bushing that is a tiny bit bigger (biggest we could find) which is actually a 4.0L to NV4500 adapter bushing...but I still don't think it'll be big enough. Because I have to have the groove machined out and the groove is bigger than the bushing... so might have to have another steel sleeve machined to go between the adapter and the bushing.... lot of stupid work. But while the adapter is out I'm going to have the engineers at work draw it up so I can have them machine one out for my other cummins swap.
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Kinda got distracted from the bedsides and messed with my new metal Shrinker and attempted some tail light housings. Close but they're still very far from perfect. Also looked at roll pan ideas- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
And up until last night, I thought the mj bedsides were double walled so I'd have to use nutserts to mount these...nope. I drilled a hole for a nursert and could see ground. So I look up from the bottom side and see my hole. So I just drilled a couple 1/4" holes and ran some bolts through win washers and nuts on the back. Will be more solid than nutserts. The only place nutserts will be needed are the 4 (or eventually 2, might delete 2 holes) above the center of the wheel well. You can't reach up that high. Mounting these is definitely a two person job. I had to lay on the ground and reach up behind the bedside and use a magnet on the front side to secure the bolt so it wouldn't come out when I put the nut on it. Once you drill and bolt the first 2 holes on the top, with the 1:1 scale paper pattern provided, you. Can just mount the bedside and use it as the pattern for the other holes... If I can do it by myself, anybody can do it with a buddy. And I think you can cut the wheel well opening out all the way up to the bedside armor basically. Up to the body seam. If anybody has done it and it didn't work, let us know... I'll mess with flares tonight. I'm ordering a mini press break tonight so I can bend the flares myself at home.- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I thought about just bending the flat part out if 1/8" and welding just it on with some gussets. Since I'll have to bend/roll the flat part anyways to follow the tube radii- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
Yep! I did those like a month ago before I had the metal sides formed. Not sure if I'm going to use round tubing or not. Might need some ideas here...- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
Bed armor and quarter panel armor Not 100% completed yet but very close. Almost exactly what finished product will look like- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
O ya, I've thought about this idea. Shelbyluvv on here wanted me to build him a hitch mounted carrier at one point that he could switch between vehicles- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
LED headlights I've never seen before.
krustyballer16 replied to krustyballer16's topic in MJ Tech: Modification and Repairs
They are ugly but are a DRL and the lows and brights both look really bright but not sure if any brighter than my halogen setup -
Diesel (TDi) conversion discussion & research
krustyballer16 replied to A-man930's topic in MJ Tech: Modification and Repairs
17,000 miles. Brand new. I'll know next week some time [emoji53] -
Talked it all up and the clutch went out in my cummins mj yesterday... (stock clutch) -
Yes, unfortunately... Perfect time too, NOT. fuel pump went out in my sisters xj so gotta fix that too. Plus it's cold and snowy here and I don't wanna have to heat my shop that long. Blah!
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Replaced master/slave cylinder. Still no clutch and pedal won't come back up? Any ideas?
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
My square tube bumpers could possibly hold a tire carrier. Not sure what you mean by flipping down instead of swinging it open. I can see one or the other but not both in one...- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I've started on all that...- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
My ax15 is holding up well behind my cummins. And the tdi is less power and torque -
So the mj broke down this morning and the xj had to haul her home... I've got no clutch. Might be slave cylinder. Didn't look into it much today. The xj didn't have to haul it, I've got the '16 cummins for that but we thought we might have to winch the mj on with the xj 's winch... First time I've had to trailer it home.
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
It has been extremely cold here and I haven't wanted to heat the shop.Plus I'm waiting to get the bedsides bent at work on the press brake. The flares will be close to the hooligan flares but not quite. I don't think...haven't been able to do any actual tubing bending. The hooligan front flares go about 2 inches lower on the body than mine will. They'll be about the same as the xj rears. And I'm still trying to figure out nutserts for mounting them. The bottom quarter panel armor is almost figured out though... Same Here. -38 on saturday and never got above 0 for the last 4 days. The whole bedside would be good, but spendy to ship i would think. I'm thinking almost just a half bed from the fuel filler rearwards.Good thing I planned ahead for half sides and had a line laser etched on it and bolt holes for mounting a half [emoji6]- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
It has been extremely cold here and I haven't wanted to heat the shop. Plus I'm waiting to get the bedsides bent at work on the press brake. The flares will be close to the hooligan flares but not quite. I don't think...haven't been able to do any actual tubing bending. The hooligan front flares go about 2 inches lower on the body than mine will. They'll be about the same as the xj rears. And I'm still trying to figure out nutserts for mounting them. The bottom quarter panel armor is almost figured out though...- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
Project Sweet Cherry Blue
krustyballer16 replied to Knucklehead97's topic in Member Projects: Your Comanches
What front hitch is that?
