BLHTAZ
Everything posted by BLHTAZ
  1. :eek: Can't imagine the cost if it was real rock... Very cool though...and yes...I would want one :cheers:
  2. Guage would cost you $50 shipped. The t-stat is OK from aftermarket as long as it has the little pass through hole in it with the check ball that goes in the 12:00 position...otherwise get OE.
  3. Looks like a great time...but, little cold for camping isn't it :eek: :D
  4. CLICK HERE to learn about picture posting...then show us what you got ;) :cheers:
  5. BLHTAZ
    Before and After
    Baby pic... Now...
  6. From your description...it sounds like yours is just a guage issue. I would make sure that your laser is accurate and check temps on the head, block & t-stat housing just to be sure.
  7. Yep...definitley helped mine and a few others on here have said the same.
  8. X2I use AMSOIL :cheers:
  9. Yeah...you don't want to get them from a JY...you just get the same junk that you already have.
  10. Cool...I gotta give him a call soon...thanks :cheers:
  11. TPS testing procedure is here... http://comancheclub.com/forums/viewtopic.php?t=12260
  12. The Ford Motorsport injectors (that you have obviously seen me promote on here) actually improve MPG. They are not "high flow"...just better spray pattern and flow matched. Definitely an improvement over the stock ones and MUCH better priced than the ones from five-o ;) . http://www.precisionautoinjectors.com/p ... roductId=7 I know this isn't what you are asking about, but I just don't see any reason to get the others when these are so much better. I definitley recommend them over using even original MOPAR injectors. You also get a 10% discount when you use the word "JEEP" as a coupon/discount code ;)
  13. They use automatic transmission fluid and it iwll take a little less than 2 qts to fill it. If you get a fluid pump and fill it when it is in the truck all you have to do is just like a differential and pump the fluid in until it starts to run back out the fill hole then put the plug in. You can buy new chains for them. I don't know where you might get one in your area, but there is a tranny shop near me that sells them. Typically about $50 here. There us no link to remove though...you must remove the main shaft & the front output to change it, but it's not a tough job if you just pay attention to what you are doing and work slowly.
  14. :cheers: That is freakin' awesome...!!! :D
  15. I check that with every part that I look up if I don't have it in stock. There is a Chrysler website that I keep open on my computer all day long to do just that. It's a nationwide locator that shows all dealers and warehouses/depots ;) :cheers: .
  16. Unfortunately...headliners have been discontinued through us. They didn't offer just the backer either...they were complete.
  17. It is essentially "bolt-on". You need to modify your steering (draglink) and trackbar, but everything else will "bolt-on". A "JK" axle will bolt in? Isn't it 4" wider??
  18. I don't know if the manifold is a good deal or not, but you will have to find out if you have LSD. If you PM me the last 9 digits of you VIN I can tell you :cheers:
  19. I like that idea... :D Yes...they still make those. There was a big blow up over it down here the other day because there is a place just a bit north of me that has been flying a giant one for many years and they just replaced it with an even bigger one...something like 30 feet x 60 feet :eek: :D
  20. He would work too... :D
  21. AMEN!!!! :cheers:
  22. Painted, cloth...doesn't matter when it comes to the use of the American Flag, the etiquette is the same ;) . I am not sure of the etiquette in relation to the use of the different Military Brach Flags, but I will be happy to work on that if needed... :D
  23. It is located on the lower part of the steering column..fairly easy to get to :cheers: .
  24. Seems it would be simple enough to do, BUT...In My Opinion...that is a terrible disgrace to our flag to use it in that manner. The flag should not be used as a vehicle decoration, as clothing or in any manner except the way it was intended...to fly in glory on a pole representing our great nations freedom. Any other use of it or it's likeness is an insult & disgrace. Sorry for my rant, but I am very tired of see this type of disrespect. Please CLICK HERE TO READ THE FLAG ETIQUETTE - STANDARS OF RESPECT. This is intended as an education for all to show that it is not "cool" or "Patriotic" to put the flag on your clothes or car as many people seem to think. I just want people to understand what is right & wrong. If you choose to do the wrong thing...that is up to you, but don't expect help or respect from me or people like me that have served this country and have the proper respect for it. :cheers: meatgrinder13 - this is NOT directed specifically at you nor is it said with any hostility...just so happens that you brought it up and I felt it time to express my feelings and hopefully help some folks to understand the correct way of doing things ;) :D
  25. Sounds like a bad ignition switch to me...
