1tuffmj
    nj
  • Interests
    muddin my mj
1tuffmj's Achievements
  1. Yes it cranks.voltage checks ok.cleaned the 101. Have wiring diagram.will check the 101 today.? Is does the cps Fire the injectors.though it only did spark
  2. Owed my87 4.0 auto for 18 years.no spark or injector pulse.what do the two have in common.did grounds,computer,cps,distributer with no change.any info would help
  3. take a look at the fender,yea the tire hit my nice painted fender.even wit 7in of up travel.my 14in travel shock bottem out but i let you know what kind of wheel travel i end up after i brake my springs in a little more but i will go low and say 12in
  4. I'm all about the welding,first any welder knows that a good weld is stronger the the metal is is welded to.then for all the guys that do not go off road wit there mj.what about LOOKS.there is alot going on there and kinda looks like poo.nice idea but clean it up a little and you got sum thing.
  5. does any body know if they make a aftermarket tran pan for a aw4
  6. does it have tilt wheel and if so is it loose.and like blhtaz said make sure ur ignition switch is not loose on ur colum,it slides up and down for adjustment.its dam near on the top so its a pain to get to
  7. the kick down comes off different then the throttle.the kick down slides off where the throttle can be just puled off.be careful and take ur time
  8. hey my mj caught fire a few years back.tranny over heated and spit fluid out the tube.them valve cover is probly cracked.they have a funky gasket set up.get a new one or go metal
  9. ill buy any thing i can put a lift on,kind of hard to do that when you have a house lol
  10. you can buy a 44all done(gears locker brackets for a reasonable price)know a bunch of xj guys that go that way
  11. i went with leaf spring cuz there cheap.250 for spring,100 for shackles and another 100 for metal.front suspension is done.gave me money for my arb...its about 7foot at the top of the cab.the bottom of the rocker in even with the top of my 40s boggers.i just like to see how other mj come up with 14inches of lift
  12. I'm still working on how to do bodt work
  13. i have a 95 block and head wit my 87maniolds,biggest pain is getting the plug out so u can put ur knock sensor in
  14. 87,l6,auto,231,no sye,front is 6in yj springs,f250 axle cut down 7in,513 gears,arb locker comoly axles,rear springs is my own custum made double mains wit add a leaf, 60 35 spline detriot disc brakes wheel base is 108 , 3in snorkel, cut down bed and a aluminum gas tank in bed,will try to put up more pics,it wheels great,owned the truck 10 year,3rd time lifted,great site glad i found it,
  15. i hope this worked dam computers
